Old Apr 04, 2011, 05:08 PM
alz3abi is offline
Find More Posts by alz3abi
Joined Oct 2010
Mini-HowTo
Using XBee Explorer USB for FTDI application モU-blox GPSヤ
i want to thanks all of your for you assist with my project specialy Happykiillmore and other people who tried or even helped so today i would like to post my experience with Xbee explorer connected to Ublox GPS for changing config and firmware update.
In case if you forget to order FTDI or you think the IMU board is enough to configure through USB this is good solution to get use of Xbee exporer USB to connect the GPS to FTDI for configuration .
here step by step how I wire my explorer to U-blox GPS
1- Use male pin to solder the 4 holes in the Ublox GPS as it showing in this picture
2-
Use 4 jumper wire
make it similar to this [IMG]http://api.ning.com/files/OGBMlmuY2HoUzhVuuv*RA0SIcK1pdR1ORDXUygDPem0kAeuB1f cAOrGzgRxjqfgxFMkLfSYfkXp8UqY1jlMbmRC8Vg6eVx1B/IMG_4715.JPG?width=500[/IMG]
"posted by Chris Anderson"
you can use any method you like to connect.
3-below Ublox Adapter you will (GND,+,IN and Out) connect all these to Xbee explorer as show in this picture
GND from GPS connected to GND in the Xbee explorer
+ connected to 3.3V in the explorer
IN connected to DIN in the expolorer
out connected to Dout in the explorer
4-connect it to USB cable and you are DONE , you might see The RX LED blinking which mean it working fine
if you have any inquire feel free to ask. you can also try it and documented it the way that you want .
alz3abi is offline Find More Posts by alz3abi
Build Log Low cost DIY XBee/GPS plane locator rich smith DIY Electronics 258 Aug 28, 2013 09:15 AM
Build Log USB cables - the ultimate GPS wire! llamero FPV Talk 16 Mar 28, 2011 12:44 PM
Mini-HowTo Low cost XBee/GPS plane locator plans rich smith UAV - Unmanned Aerial Vehicles 5 Feb 04, 2009 02:57 PM
Discussion U-Blox GPS module w/internal antenna & datalogger for sale CrashingDutchman UAV - Unmanned Aerial Vehicles 1 Mar 22, 2006 09:40 AM
Sold U-Blox GPS module w/ internal antenna and datalogger CrashingDutchman Non R/C Items (FS/W) 1 Mar 22, 2006 08:02 AM
