Espritmodel.com Heli Air
Old Apr 04, 2011, 08:52 AM
Joined Dec 2005
Antonov AN-225 plans needed
Hi
I was thinking on starting to build a Antonov AN-225.
I was planning on using 6 x 55mm edf's.
The matirial i wnat to use is depron and balsa.
I have searched the web but could't find any downloadable plans por this plane. Only found 3 views draws.
Can someone help me on this?
Chaparro1973 is offline Find More Posts by Chaparro1973
Old Apr 04, 2011, 11:19 AM
Vozdushno Desantnie Voiska
specnaz's Avatar
Croatia
Joined Jun 2010
have you tried this?
http://airwar.ru/
http://airwar.ru/other/draw/an225.html
specnaz is offline Find More Posts by specnaz
Old Apr 04, 2011, 11:57 AM
Joined Dec 2005
Thanks for your help. I have seen the images, but i'm new at building and i was looking for some more detailed plans.
Old Apr 04, 2011, 05:59 PM
specnaz's Avatar
Croatia
Joined Jun 2010
If you're new at building, i suggest you make some simple aircraft for beginning , some Cessna or a glider. I'm afraid that is the most detail plans you can find on the Net , it has bulkheads and all surfaces you need to build , rest is on your craft
Old Apr 04, 2011, 10:46 PM
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
yeah, you aren't going to find plans for this airplane, just some good 3 views with formers. unless of course, you can find someone who is building one already and might be willing to share what they have. I know there's a few builds going on, so check out the search bar and see what you come up with. other than that, you are probably SOL if you don't have the experience to scrachtbuild from 3 views. of course, the good thing about these forums is that there's always people to help you out if you choose to scratch from a 3 view.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Apr 05, 2011, 03:26 PM
Adrianh's Avatar
Chatteris, Cambs, UK
Joined Dec 2005
Hi,
Have a look at GAD and their AN225: http://www.greenairdesigns.com/lab2/...id=85&Itemid=1
Adrian
Adrianh is offline Find More Posts by Adrianh
Old Apr 06, 2011, 12:23 AM
Scale Modeler
Concordefan's Avatar
Canada, ON, Mississauga
Joined Feb 2006
I'll double what Rich said about An225.....
Concordefan is offline Find More Posts by Concordefan
Old Apr 08, 2011, 04:06 AM
Joined Dec 2005
Ok
I could'nt find any plans for this plane
But i found a nice 3d model of it for google sketch.
Can someone point me in the right direction so i can use the 3d model to make the plans?
Old Apr 08, 2011, 08:51 AM
Joined Dec 2005
Sorry, i should have used the search option before posting.
I found some posts with instroction on using google sketch.
What i am planing on doing (in a general line) is to cut some section on google sketch then use them to creat a plan. I'm o thinking writh?
Old Apr 08, 2011, 02:59 PM
Avoid The Ground!
Flexserve's Avatar
United States, FL, Lutz
Joined Sep 2008
Just get a card model of the thing and make it from depron and carbon rods...
Flexserve is offline Find More Posts by Flexserve
Old Apr 10, 2011, 01:57 AM
domll's Avatar
Norwich.uk.
Joined Oct 2007
As Flexserve says, heres a link:
http://www.paper-avia.com/en/modelz/...w4_t/1379#top3
Go with the 21mb one, better suited due to detail. heres acouple of picture of her builtup.
domll is offline Find More Posts by domll
Old Apr 12, 2011, 01:25 AM
mjblack's Avatar
Norwich, Great Britain (UK)
Joined Jan 2004
HI all,
I would like to thank Ady for mentioning us about the AN-225.
If it helps, we have been working on the updates to the kit last week and now in the process of proving these.
The kit is also 10% bigger at 1.7m span and can now carry either 40 or 50mm EDF`s
If all goes well i see no reason why it could not be released either late April or early May. We know that airframe flies superbly, we just needed to make it easier to manufacture and i hope that we have now done that!
Here are a few pics also with the 'Buran' Attached. Also a couple of VERY poor pics of the Buran being released from the AN-225 (the Buran was also RC)
Best regards,
Mike.
Dr Mike Black M.D Green Air Designs
mjblack is offline Find More Posts by mjblack
Old Apr 12, 2011, 03:25 PM
Joined Jan 2009
I say buy and build the GAD 225. if it's anything like the rest of their lineup, you won't be disappointed. the Lightning was cake to build, as I'm sure this one will be.
Old Apr 17, 2011, 12:48 PM
Skilled crasher
Ukraine, Kyiv city, Kiev
Joined Oct 2010
The best 3d models are here: http://www.buran.ru/htm/3d-model.htm
Use them!
sashaNar is offline Find More Posts by sashaNar
Help! Antonov An-225 edf. Salvador Lazca Mexico 77 Jan 26, 2011 04:43 PM
Question RC X-15, nasa space shuttel, bumble bee II, Antonov An-225. pirate cat Electric Plane Talk 27 Mar 27, 2008 08:52 AM
Cool Aero Ace Scale Antonov An-225 catman529 Micro RTF 3 Mar 16, 2008 03:16 PM
Antonov AN-225 aids Electric Ducted Fan Jet Talk 12 Jan 17, 2005 06:03 PM
