Old May 23, 2012, 04:14 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
The smaller .049 Cox engines all use a 5x40 thread screw or stud for the props. I need to check and see if a 5x40 screw is about the same size as the Mills engine crankshafts I have or not. I had not thought about trying a Cox 8x4 prop to see if it fit or not.
5x40 is about 1/8 inch size.
earlwb is offline Find More Posts by earlwb
Old May 23, 2012, 08:18 PM
fiery is online now
Find More Posts by fiery
fiery's Avatar
Hervey Bay, Queensland, Australia
Joined Mar 2008
Mills .75 Propellers
Images of three different propellers suitable for a Mills .75 engine, if you don't mind it being a little thirsty.
All are 7x4. An 8x4 is probably a better size for most applications.
Two, the Tornado and the Top Flite, are translucent white nylon. The Tornado was also commonly made in an opaque yellow nylon.
The surprise is the "dark horse" of the three. It's a JXF fibre propeller. Nicely made and balanced. It has a thin hub, the same width as the Top Filte propeller. Great performance, though liable to break in the event of an "arrival". It is available from HobbyKing and well priced.
fiery is online now Find More Posts by fiery
Old May 23, 2012, 09:39 PM
scruffy1 is offline
Find More Posts by scruffy1
looking up down under
scruffy1's Avatar
Australia, NSW, Fairlight
Joined Feb 2008
i still have the tornado yellow nylon in 5x3, 5x4 and 6x3, left over from my initial fits for the dc dart
they do really well on the hobbyking c10 micro brushless 2900kv
pardon my hijack, but you've all given me a bad attack of nostalgia, so please excuse the slightly off-topic attached pics, which some of you will enjoy
for all their attraction, i have to confess diesels are nowhere near as practical as electric for this late convert to powered r/c
but the smell and sound are still wonderful when i fire them up
scruffy1 is offline Find More Posts by scruffy1
Old May 24, 2012, 02:50 AM
DeeBee1 is offline
Find More Posts by DeeBee1
DeeBee1's Avatar
United Kingdom, England, Brighton
Joined Apr 2007
No need to apologise scruffy, I sometimes fire up a diesel for no other reason than that it reminds me of the fun I had messing about with model planes when I was young.
DeeBee1 is offline Find More Posts by DeeBee1
Old May 24, 2012, 11:19 PM
TLyttle is offline
Find More Posts by TLyttle
TLyttle's Avatar
Keremeos, BC Canada
Joined Mar 2004
Hahaa! I was flying a diesel (haven't owned a glow since 1968) one nice afternoon, whan I heard a great intake of air behind the model. I turned, and a gent with a UK accent smiled and said, "Ahhh!! Reminds me of my youth! Thank you very much!" and walked away...
TLyttle is offline Find More Posts by TLyttle
Old May 25, 2012, 12:14 AM
scruffy1 is offline
scruffy1's Avatar
Joined Feb 2008
gotta confess my box also holds 2 cox .049's, an enya 2.5cc and an o.s. max 6cc - all glow plugs of course
except i haven't fired up a glowie since the late 70's - no fuel, battery or spares for the plugs
and i still have most of a 500ml bottle of still potent enough "pro-glow diesel"
Old May 28, 2012, 02:20 AM
fiery is online now
fiery's Avatar
Joined Mar 2008
Mills .75
My Mills .75 from posts 72 and 101 on the stand for it's first run since renovation.
Easy starting on my standard sports diesel brew.
First pic shows it being introduced to my "Millski". Boris, meet Nigel
Old May 28, 2012, 02:31 AM
DeeBee1 is offline
DeeBee1's Avatar
Joined Apr 2007
Great job fiery, fantastic to see the engine running again
Old May 28, 2012, 05:07 AM
gossie is online now
Find More Posts by gossie
Gold Coast Australia.
Joined Jan 2005
Lovely. It looks new. Terrific job done on the head.
gossie is online now Find More Posts by gossie
Old May 30, 2012, 09:44 PM
fiery is online now
fiery's Avatar
Joined Mar 2008
Russian Doonside Mills
Here is my "Millski" giving a sparkling performance on a classic white nylon Tornado 7x4.
The 10,500 rpm reading was not sustainable hot. Steady rpm's were mid to high 9,000's.
Old Oct 09, 2012, 02:52 AM
robinson727 is offline
Find More Posts by robinson727
robinson727
USA, MS, Byhalia
Joined Nov 2010
All..
I have written Hans at CS and he has sent me enough .075 parts to build a Mills inline twin. Has anybody measured the CS copy co I can verify my dimensions?
What I need are crankpin dia, shaft journal dia and stroke. Rather than hassle with a new block this is going to be a siamese with a modified rear case and a new design crank, (like the Sparey twin) so it's essentally 2 back to back cases with the snout cut off the rear casting and a threaded outer housing to tie them together in the threaded back plate area. CS also sent me an RC carby for a 1.3 for it, they have been very helpful and seem interested in our results.
Al
robinson727 is offline Find More Posts by robinson727
Old Jan 28, 2013, 01:06 AM
fiery is online now
fiery's Avatar
Joined Mar 2008
Flat Twin Mills
Here is a video of what looks to be a home made flat twin, using first series "Boddo" Mills .75 top end parts.
It becomes over compressed as it warms up, and slows.
Boddo Mills Twin (2 min 8 sec)
Old Apr 16, 2015, 11:12 PM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
I have what looks to be a Mills 0.75cc
It may be a replica. It is from my father's estate and I want to know what its value is.
Any ideas?
feathermerchant is offline Find More Posts by feathermerchant
Old Apr 16, 2015, 11:51 PM
scruffy1 is offline
scruffy1's Avatar
Joined Feb 2008
priceless
you should keep it as a family heirloom
Old Apr 17, 2015, 12:07 AM
fiery is online now
fiery's Avatar
Joined Mar 2008
Not quite Scruffy ...
That is an Aurora "K-Mills" .75 with and Aurora "K-Mills" 1.3 NVA and tank assembly on it. It is missing it's correct spinner nut as well.
A good Aurora Mills is not finished as nicely as the original and materials can sometimes be sub-par but most are quite satisfactory. Some are not so good. They do not bring the prices of an original English Mills.
Discussion didn't someone build and fly a Coro Delta with small diesel engine earlwb SPAD - Simple Plastic Airplane Designs 15 May 27, 2011 08:56 PM
Discussion Help on Mills Diesel Assembly NX-687 Engines 2 Dec 22, 2008 02:46 PM
Wanted Mills 75 Diesel Tag1260 Aircraft - Fuel - Engines and Accessories (FS/W) 3 Feb 28, 2006 06:54 PM
Mills 0.75 Diesel RC mlbco 1/2A Planes 10 Apr 02, 2005 08:20 PM
