Old May 21, 2012, 07:54 PM
Jim Thomerson is offline
Find More Posts by Jim Thomerson
I have Aurora Mills 75 and 1.3. They took a bit of breaking in, but now start and run as one would expect. The compression screw on the 75 is loose and I've been holding it while running on the bench. I've been intending to re tap and put in a setscrew. However, I have been contemplating trying park flier sort of RC. I read of the idea of moving the compression screw as a throttle. This would work with my 75, I think. So I'm not going to get excited about fixing it.
I think I read in an Aeromodeller that some of the early Indian Mills were superior runners compared to the originals.
Jim Thomerson is offline Find More Posts by Jim Thomerson
Old May 21, 2012, 09:36 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
It figures that some people would have all the luck. The magazine probably got a "cherry picked" engine to review.
I would simply make a small locking lever for the adjustment screw. No sense getting all that fancy making it up better.
Actually they seem to work fairly well using the compression screw as a throttle of sorts. The problem though is when you are increasing the compression it might take more force than the servo can provide.
earlwb is offline Find More Posts by earlwb
Old May 22, 2012, 03:37 AM
brokenenglish is online now
Find More Posts by brokenenglish
Sticks, Tissue & old Diesels
brokenenglish's Avatar
France, Centre, Amboise
Joined Nov 2011
Jim, when you say the compression screw is loose... This shouldn't be a problem... Do you actually mean that the contra-piston is loose?
RC throttles exist for the Mills .75 and 1.3. I've also read that the Tarno TD 049 throttle fits a Mills .75.
Using compression adjustment in flight seems unrealistic to me. A servo arm in linear motion couldn't apply more than about one quarter of a turn on the screw, and this would probably by insufficient for worthwhile throttling.
It seems to me that, whenever a new repro is released, there's always great enthusiasm about its quality and performance...
Remember when the CS Tigers were first produced. I remember reviews (Australian, I think) claiming that they were "at least as good as the originals"... After a year or two, everyone realizes that this is nonsense, and that the repros are way below the quality of the originals.
I've owned one Doonside and two Irvine Mills that all had the cylinder rotation problem. They would run OK for a minute or two, and then the cylinder would rotate and the engine would no longer run.
I've also owned several Indian Mills that were all good runners with no particular problem.
The bottom line is that the originals are best (the only ones that are reliably trouble-free), and my own preference would be for the Mark I.
brokenenglish is online now Find More Posts by brokenenglish
Old May 22, 2012, 05:49 AM
DeeBee1 is offline
Find More Posts by DeeBee1
DeeBee1's Avatar
United Kingdom, England, Brighton
Joined Apr 2007
Jim, last Aurora Mills I bought has a small spring running outside the comp. screw (see awful sketch attached!). I assume this is to try and stop the thing uncompressing itself - seems to work. The other Auroras I've had didn't have this spring.
DeeBee1 is offline Find More Posts by DeeBee1
Old May 22, 2012, 06:57 AM
scruffy1 is offline
Find More Posts by scruffy1
looking up down under
scruffy1's Avatar
Australia, NSW, Fairlight
Joined Feb 2008
wow, what a blast from the past
as per my memory, ivor f. (aka ivor stowe) produced a run of "doonside mills" with the assistance of gordon burford - two great australian legends of modelling
i had the job of being ivor's gofer in the scramble at the 1976-7 bunbury nats, where i chased his mills powered model for the event
i was too young and impecunious to buy one after i blew my $ on a dc dart 0.5cc that i still have today (along with a collection of taipan diesels )
scruffy1 is offline Find More Posts by scruffy1
Old May 22, 2012, 09:35 AM
Joined Nov 2011
Other engines (Micron 2.5R) had such a spring as standard, without actually needing it. Whether it works or not depends on just how loose the contra-piston is, and how tight the comp screw threads are in the head, but the fact remains that a properly fitted engine shouldn't need a comp screw lock...
Old May 22, 2012, 09:51 AM
DeeBee1 is offline
DeeBee1's Avatar
Joined Apr 2007
Agreed. I had a PAW 55 where the needle valve and the comp screw both used to adjust themselves due to vibration. Needle valve was easy enough to tighten, but the comp screw was a pain.
Old May 22, 2012, 10:02 AM
On my Mills, it is about a quarter turn range from just right to slow undercompressed, and doesn't take much to turn it. I may try the spring idea.
Old May 22, 2012, 04:13 PM
fiery is offline
Find More Posts by fiery
fiery's Avatar
Hervey Bay, Queensland, Australia
Joined Mar 2008
Doonside Mills .75
My understanding is the Doonside Mills replica had it's cylinder pinned to prevent rotation when tightening the cylinder jacket.
fiery is offline Find More Posts by fiery
Old May 23, 2012, 07:00 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Some people will discover that the 8x3 props usually have a hole in the center that is too large for the engine, so they can't center the prop correctly. What I have done in the past was to use some short lengths of heat shrink tubing and put the tubing on the crankshaft shoulder and heat shrink it, to build it up to center the prop better.
More recently I made some small metal spacers to fit into the rear recess on the Master Airscrew props. If you use that rear molded in recess you don't have to balance the props or anything as that is what the factory used to set the props up in the first place.
The basic method was to chuck up a piece of aluminum in a lathe, then drill the center hole with a slightly undersized drill bit. What I did was drill a hole in some scrap aluminum and check the crankshaft shoulder fit on the hole and get a drill bit to match that just right. Then I machine down the outside to be a snug fit on a MA propeller. Then I used a cut off tool to cut the short spacer off the rod. You might have to chase the small part across the floor when it comes loose so be prepared for that too.
Old May 23, 2012, 09:18 AM
DeeBee1 is offline
DeeBee1's Avatar
Joined Apr 2007
Nice job earlwb, I use a short piece of fuel tube screwed onto the prop shaft and then push the prop onto that. It works but your idea looks much more professional.
Can you start selling the inserts so we can buy them? - I've never found a prop that comes with just the right hole for a Mills .75.
Old May 23, 2012, 10:01 AM
Joined Nov 2011
That's probably because you're using modern propellers.
Modern thinking dictates that (say) an 8x4 corresponds to a .15 size TBR engine, and the modern G/F and C/F props are made based on that assumption.
Really, if you want to use old engines (which is all I use), you need a good stock of old props. For example, the KK, DC, Topflite and Tornado props of the sixties were sold with holes that suited the older engines, i.e. the original hole in a KK, DC or Topflite 8x4 fits a Mills fine... and you have to ream it out a bit for an ED Bee or an Amco!
The thought has never occurred to me, as I only use old wood or plastic props, but I don't think I'd like to fly an original Mills .75 with a carbon prop...
Old May 23, 2012, 10:31 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I need to think about it. I also need to check to see if the spacer inserts work Ok on my other Mills engines and replicas too. I don't know how close they all followed the specs, so to speak. Some of the different engine replicas may have used different crankshaft sizes.
Old May 23, 2012, 10:39 AM
DeeBee1 is offline
DeeBee1's Avatar
Joined Apr 2007
Yeah you're right, although I've never had a problem running any of my vintage engines with newer props and it's only the smaller ones that have the smaller prop shaft. Bit of a pain having to fit a bit of fuel tube but it doesn't take long.
No problem with my old Cox engines as you can still get the props!
Old May 23, 2012, 10:59 AM
Joined Nov 2011
One of the best props for gentle Mills flying is the Cox 8x4 TD15 prop.
I thought of Cox props after my post. They all have small holes because all Cox engines (except the Conquest I think) use the hollow shaft prop/bolt principle.
I often use the old TD15 props on old diesels around 0.75 to 1cc.
In any case, the props I mentioned frequently come up on eBay, and often new.
Discussion didn't someone build and fly a Coro Delta with small diesel engine earlwb SPAD - Simple Plastic Airplane Designs 15 May 27, 2011 08:56 PM
Discussion Help on Mills Diesel Assembly NX-687 Engines 2 Dec 22, 2008 02:46 PM
Wanted Mills 75 Diesel Tag1260 Aircraft - Fuel - Engines and Accessories (FS/W) 3 Feb 28, 2006 06:54 PM
Mills 0.75 Diesel RC mlbco 1/2A Planes 10 Apr 02, 2005 08:20 PM
