Chennai, Tamil Nadu, India
Joined Sep 2003
DeeBee
Sorry if I was not clear The DB case was settled and you are also right that they were allowed to clear the stocks but no new manufacture. The Kumar's of Calcutta (Aurora Models) are also on the tails of CS as CS has not stopped manufacturing the Mills even after demise of Boddo. Name change from Mills to Miller is of no consequence as far as IP/Trademark rights go. Except Aurora no one has the original dies so manufacturing would be done by them. I am at this moment not clear on who is ordering those engines in to UK. The quality should improve because the quality problem was not with the crankcase casting but the metallurgy, machining and quality of fit and finish. Hence if some one were to either get the CKD kits or just the cast cases and assemble or machine the rest I am sure a better quality would be assured. As for rights to Mills no it has not been purchased yet, but is still up for sale should some one want to from Kumar's of Aurora. |
A while back I had acquired a Mills 1.3cc model diesel engine. it looks like someone had made a new intake venturi for it, as it doesn't seem to look like the correct one for the engine. Anyway it looks like the real thing and not a replica.
Latest blog entry: My Low Wing plane
Thanks for the photos. The first engine does indeed look like an original Mills 1.3 Mk I Series I. As you have noted, the original fuel bowl and needle valve assembly has been replaced, possibly to allow the use of a bigger external tank.
The 0.75cc is also very nice. I really like Mills engines, even though a .75 took a slice out of my finger this week and I had to have it glued back together by a nurse (the finger, not the engine!). The Mills family can turn big props for their size and can be under-compressed or throttled back to run slowly if required. There were many models of all types designed around the Mills and they are arguably the best and most popular of all the British diesels! |
here is a video of when I ran one of my Mills engines a while back. I had accidentally left the switch on 3 blades for the tachometer at the time.
In this video I got the switch correct on the tachometer though.
Hervey Bay, Queensland, Australia
Joined Mar 2008
Mills .75
Lady luck does smile upon you occasionally.
I have been fortunate enough to have been given a somewhat grubby, but otherwise good, used English Mills .75. Compression, bearing and connecting rod fits are fine for further running. The tank is not original, and is badly perished. I would like to restore this classic. Are original pattern tanks available for purchase as spares? If so, contact details would be greatly appreciated. |
Southampton, UK
Joined May 2007
peter rose in england does mills spares see http://www.rcgroups.com/forums/showt...e#post17930019
actually earlier posting in this thread john |
| Thread Tools | |
| Discussion didn't someone build and fly a Coro Delta with small diesel engine | earlwb | SPAD - Simple Plastic Airplane Designs | 15 | May 27, 2011 08:56 PM |
| Discussion Help on Mills Diesel Assembly | NX-687 | Engines | 2 | Dec 22, 2008 02:46 PM |
| Wanted Mills 75 Diesel | Tag1260 | Aircraft - Fuel - Engines and Accessories (FS/W) | 3 | Feb 28, 2006 06:54 PM |
| Mills 0.75 Diesel RC | mlbco | 1/2A Planes | 10 | Apr 02, 2005 08:20 PM |
