Old Apr 04, 2011, 04:54 AM
czirh is offline
Find More Posts by czirh
Use your imagination....
czirh's Avatar
Greece, Dafni
Joined Oct 2007
Build Log
Short Skyvan SC-7
I started a new project, Skyvan...
czirh is offline Find More Posts by czirh
Old Apr 04, 2011, 05:14 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
There are a few Skyvan threads, (around 18), if it helps determine, solve, any problems.
Nice old workhorse.
eflightray is offline Find More Posts by eflightray
Old Apr 04, 2011, 07:04 AM
czirh is offline
czirh's Avatar
Greece, Dafni
Joined Oct 2007
I started fuselage. 3mm balsa, plywood and pine..
Old Apr 04, 2011, 02:17 PM
czirh is offline
czirh's Avatar
Greece, Dafni
Joined Oct 2007
I drew Corel.. Wingspan: 2m.
Old Apr 05, 2011, 01:46 AM
czirh is offline
czirh's Avatar
Greece, Dafni
Joined Oct 2007
What airfoil should I use in this model?
Old Apr 05, 2011, 12:36 PM
czirh is offline
czirh's Avatar
Greece, Dafni
Joined Oct 2007
Fuselage...
Old Apr 05, 2011, 12:43 PM
Wolpertinger is offline
Find More Posts by Wolpertinger
Formerly "vonJaerschky"
Wolpertinger's Avatar
Canada, BC, Comox
Joined Nov 2003
I don't know what the full size aircraft used. I would choose an airfoil that gave good lift at low speed, something like a NACA2415 which is semi-symmetical, or perhaps even a simple Clark-Y if you prefer a flat bottom airfoil. A Clark YM-15 is a bit thicker and might be a good choice, too.
Wolpertinger is offline Find More Posts by Wolpertinger
Old Apr 05, 2011, 05:23 PM
James Frolik is offline
Find More Posts by James Frolik
Long-Time Member
James Frolik's Avatar
Cologne, Germany
Joined Dec 1996
I would simply use a Clark-Y profile. That's what was used on the nice design and free plans provided in the German magazine FMT back in 1998, when I built mine.
From you photos, it appears you will have detachable wings. With a 2-meter wing span this might be nice, but most versions (mine has a 1.5m span) have a one-piece wing where the upper fuselage hump deck—the fuel tank on the real plane—is part of a removable wing. This makes construction easier, and the general strength of the wing's mid-section is tougher.
My model uses simple Speed 400/7.2v direct-drive motors with 6x4 props and 7 x NiCd cells. Construction is all balsa and controls are aileron, elevator, rudder, and [brushed| motors. The ESC is a 35A Schulze. I have not flown the model in over 10 years—it simply hangs on display—and therefore have never tried a 2s LiPo pack, but I'm sure it would fly fine with one. The model is very light.
James Frolik is offline Find More Posts by James Frolik
Old Apr 05, 2011, 10:55 PM
pr0ject42 is offline
Find More Posts by pr0ject42
CEL abuser
USA, CO, Denver
Joined Dec 2010
To really enhance the scale feel, make sure your model at least smells like Jet A. Bonus points for leaking it and vibrating badly as well.
Oh yeah make sure the tailgate is closed for takeoff!
It's a fun one to jump out of though
pr0ject42 is offline Find More Posts by pr0ject42
Old Apr 06, 2011, 12:29 AM
czirh is offline
czirh's Avatar
Greece, Dafni
Joined Oct 2007
Thanks for all comments..
Old Apr 06, 2011, 12:56 AM
czirh is offline
czirh's Avatar
Greece, Dafni
Joined Oct 2007
Wing: 1.5mm balsa over foam and 40gr of glass fabric coating, then paint.
Fuselage : Balsa over 40gr of glass fabric, then paint.
Rudder, elevator: Balsa construction, the normal film coating, then paint.
1 - Any suggestions on the above process?
2 - 8 mini servos will be used. Is it OK to use normal ESC?
Thank you ...
Old Apr 06, 2011, 09:05 AM
czirh is offline
czirh's Avatar
Greece, Dafni
Joined Oct 2007
Yes, Clark-y good idea..
Old Apr 06, 2011, 09:15 AM
Canada, BC, Comox
Joined Nov 2003
Thank you ...
Probably not. 8 mini servos will be too much for most ESC's. You will need a seperate BEC, like this or this. Most ESC's have a what is called a linear voltage regulator, and 8 servos would overload them. Some ESC's (Like the Phoenix Ice Series) have a built in switching type regulator, and they can handle more servos.
Old Apr 06, 2011, 09:20 AM
czirh is offline
czirh's Avatar
Greece, Dafni
Joined Oct 2007
I started the construction of the nose. This is the difficult part for me. I use the lost foam method.
Old Apr 06, 2011, 01:44 PM
czirh is offline
czirh's Avatar
Greece, Dafni
Joined Oct 2007
Thank you for your reply. I have got this, but I think deficient...?
Discussion Short Skyvan Plans Vagabond324 Scale Kit/Scratch Built 33 Sep 10, 2016 06:08 AM
Discussion Full scrathbuilt Short Sc-7 skyvan wing span:90" THEYONK Scale Kit/Scratch Built 22 Apr 16, 2011 04:40 AM
Discussion Short Skyvan Warbird@home Scratchbuilt Indoor and Micro Models 3 Feb 21, 2011 11:08 PM
Build Log Short SC-7 Skyvan airkid Scale Kit/Scratch Built 57 Jan 04, 2010 03:36 AM
Discussion SHORT sc7 SKYVAN Aluminium edition weerasakmusyo Scale Kit/Scratch Built 3 Jul 27, 2008 04:44 AM
