Old Apr 03, 2011, 05:13 PM
motoguy1 is offline
Find More Posts by motoguy1
MO, USA
Joined Jun 2010
What are you using for your (non-goggle) display?
Looking at putting together my ground station. I currently have a pair of HeadPlays, but I haven't gotten around to doing...well...-anything- with them. LOL While I intend on using them, I think having a panel display on the ground station is a good idea as well.
Soo...what are you guys happy with, for a ground display? TV's running on inverters? Something that runs on 12v dc? What sizes are you using? I've seen mention of as small as 7", and as large as 22" (iirc).
Can those who have actually used these set ups discuss their pros and cons?
motoguy1 is offline Find More Posts by motoguy1
Old Apr 03, 2011, 06:27 PM
Po73 is offline
Find More Posts by Po73
Thou who know not
Po73's Avatar
USA, MI, Mason
Joined Jul 2010
Cheap and easy way to do it is 7-9" 12vdc lcd non-hd tv. If you have a recorder in line like the Aiptek MPVR you'll have no blue screen issues. You can get a MPVR for $40-60 and a cheap SD TV for $40-80. It makes a pretty solid easy to use combo.
Po73 is offline Find More Posts by Po73
Old Apr 03, 2011, 09:24 PM
CrashMeUp is offline
Find More Posts by CrashMeUp
Crashomatic
CrashMeUp's Avatar
United States, CA, SF
Joined May 2010
i use a laptop with a non-reflective screen as recorder + 2nd screen.
It's a Panasonic R3. 10", "cheap", old, indestructible and it can compress the video in real time as long as you dont use a too demanding codec. Theres an ezcap on it.
When I'm not on the go or in town however I use whatever TV is around, usually 40" or so (parents place in the middle of nowhere with a big tv for example :P)
CrashMeUp is offline Find More Posts by CrashMeUp
Old Apr 08, 2011, 06:23 PM
chuck99z28 is offline
Find More Posts by chuck99z28
Mongolia, Ulaanbaatar, Khan Uul
Joined Jan 2011
44 inch plasma monitor
chuck99z28 is offline Find More Posts by chuck99z28
Old Apr 08, 2011, 07:25 PM
zaguruinzasky is offline
Find More Posts by zaguruinzasky
Smoke on , go !
zaguruinzasky's Avatar
Verona - Italy
Joined Jan 2007
I'm using a DP6 for work (video documentaries) and it's an excellent hi-end field monitor with lots of features. Maybe too much for just fpv but that's up to you...
http://www.smallhd.com/
zaguruinzasky is offline Find More Posts by zaguruinzasky
Discussion What are you using to record your flights? Flying-Monkey FPV Talk 64 Nov 29, 2010 02:33 PM
Discussion What RC TX are you using? Or prefer? or recommend? Escpecially for pan/tilt? badinstincts FPV Talk 13 Nov 23, 2010 03:21 PM
Question what UBEC are you guys using for a Plane using 5 servos total? rclab1 FPV Aircraft 2 Nov 14, 2010 07:28 PM
Poll What Batteries are you using? Battlepack Racing Boats - Electric 25 Sep 30, 2010 02:10 PM
Discussion What are you using for a display? scolen3 FPV Talk 20 Dec 12, 2009 03:18 PM
