Old Apr 03, 2011, 04:23 PM
teopbako is online now
Find More Posts by teopbako
Ikaruswannab
Joined Sep 2009
Opinions on 2.4GHz Antenna
Hi,
Can i use this to extend my RC range of a Corona DSSS module?
Anyone ever used one?
Teo
teopbako is online now Find More Posts by teopbako
Old Apr 03, 2011, 05:36 PM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Originally Posted by teopbako View Post
Hi,
Teo
Teo,
Yes and no. Gain with an antenna always means directivity. The antenna is omnidirectional, but the gain can then only come from a more flat (in the z axis) radiation pattern. Normally a regular omni directional antenna has a radiation scheme that resembles an apple sitting in front of you on a table.
With this antenna you can think of that apple being flatened more and more. In the end it looks more like a disc. So, you gain range in the horizontal direction but if you fly high or above yourself, you loose range.
HTH
Markus
markus123456 is offline Find More Posts by markus123456
Old Apr 04, 2011, 01:29 AM
Ikaruswannab
Joined Sep 2009
Originally Posted by markus123456 View Post
Teo,
HTH
Markus
Hi Markus,
Your example with the apple made your point clear.
So what do you suggest?
A patch maybe?
All antennas are suitable for both ends (Tx/Rx)?
Thank you
Teo
Old Apr 04, 2011, 02:41 AM
Registered FPVer :)
Joined Aug 2006
Hi Markus,
A patch maybe?
Thank you
Teo
I do not really suggest something else. You must know that antenna gain always comes with this limitation. It thus depends on how you intend to fly. A patch has to be adjusted to point to the plane. So does any directional antenna. The one you refer to is ok if you fly around yourself and fly higher the farther out you are (thus staying within the pattern) and only low near you.
The "final" solution is to buy a long range system. Wether you like it or not but that's the only safe way to fly far out. So think twice if it makes sense for you to invest in your regular RC system or if you are not better off buying a LRS.
Markus
Discussion 4 channel 2.4ghz heli, need opinions. candy76man Coaxial Helicopters 15 Mar 14, 2011 08:09 AM
Discussion Add patch antenna on to my Futaba 6ex 2.4Ghz????? bobmaxiao Radios 4 Oct 18, 2010 06:01 AM
Discussion Optima 6 2.4Ghz - is longer antenna possible ?? omega2498 Hitec/Multiplex USA 7 Sep 13, 2010 07:48 PM
Help! Broken Antenna on 2.4GHz RC Man Radios 19 Aug 29, 2009 02:41 PM
Question User opinions on Futaba 10C 2.4GHz abenn Radios 16 May 11, 2009 02:34 AM
