Old May 09, 2011, 07:29 PM
United States, MI, Saginaw Charter Township
Joined Feb 2007
Also got a A50-16s version 2.the main differences were the weight
Version 1 403.3g with 4mm connectors
Version 2 337.8 with bare wires
length
Version 1 57 mm
Version 2 53 mm
Version 2 also has an internal fan.
RCBRUSKI65 is offline Find More Posts by RCBRUSKI65
Old May 09, 2011, 09:35 PM
Time for me to Fly...
Mr. Wiz's Avatar
United States, MI, Fenton
Joined Jan 2000
Version 2 looks like helicopter motor.
Mr. Wiz is offline Find More Posts by Mr. Wiz
Old May 12, 2011, 02:24 PM
Dylan_Anderson's Avatar
Joined Nov 2006
Your servos ( rudder )
Tim,
The 8411a's are the perfect f3a servo ; nice one.
Quick explanation; the 8411 has an all metal gear train and develops a little slop over time. It's minimal though and on any other plank/ Heli you would not be aware. But coming back to centre is obviously critical in pattern. The 8411a is an F3A specific servo with a nylon gear train except for the final gear that the servo horn is fitted on which is metal. They really are crisp and smooth. There are new 'a' servos out now and come in two sizes the last time I checked, the second being for individual ele or for the 2x2's I run the 8411a on the ail and an 8511 on the rudder. So, if your looking for new servo's it's worth checking these out. I just happen to run JR gear. It's just my opinion, that Futaba & JR are both excellent brands. Futaba have for the last ten years 'owned' the Heli market in gyro's (401/611) and their native servos 9254/9256/9267. Lot's more competition now but only in the last three years. Much respect to both brands.
D
Dylan_Anderson is offline Find More Posts by Dylan_Anderson
Old May 12, 2011, 05:17 PM
Frontenac, KS
Joined Jan 2003
Even after getting the Osiris ready to fly. I still have the feeling for the Wind.
Never heard of 8511. there never was 8411A in the state (maybe you meant 8611A). 8411SA was the special application that you mentioned as 8411A. All SA or A servos have been discontinued although it is still possible to find a few. Most people I know change the gears (not the top gear) with 811/8101 gears to make SA.
I am still using DS8411 on rudders of my planes.
ok. there is 8511 in Japan (may be Europe also?) I just looked over the JR Japan site. You should be using the Japanese version servos.
PatternFlyer is offline Find More Posts by PatternFlyer
Old May 13, 2011, 02:29 PM
Joined Nov 2006
Crazy that...
You'd think they would have things all lined up globally.
Did a google effort and the 8411a servos popped up on a Uk site. Looks pretty old
http://www.fcflyers.com/forsale.html
It's in the QQ Yak ad
I bought this servo from HeliKraft.com, a DS 8911 was that ever available in the states ?
Cheers
D
Old May 14, 2011, 02:58 PM
Frontenac, KS
Joined Jan 2003
D,
We never get the identical servos from Japan or Europe.
Somehow, a lot of JR servos have different part # here in the states. I occasionally get the servos from Japan, but never had one that matching the US servos.
DS8911 picture seems from Japan also. It is none-high voltage servo which is not available in the state.
http://www.jrpropo.co.jp/jpn/product...&db_flg=jp_db1
DS8911HV in the US is High Voltage servo. http://www.horizonhobby.com/Products...dID=JRPS8911HV
Old May 21, 2011, 06:34 PM
Joined Feb 2007
Got the maiden flight done today. Took a couple of clicks of aileron and 4 clicks of up elevator. But I knew it was a little nose heavy. With an APC 16x12 the A50-16s pulled 71.1 amps right at 1600 watts. Some very serious power in the air.Plane takes off and lands awesome. Has great rudder authority for as small as the rudder is. Only put in easy flights to get batteries broken in. Can't wait to open it up and see what she will do.
Tim
Old Jun 11, 2011, 10:09 AM
United States, TX, Houston
Joined Apr 2011
Hacker 50-16S V1
Is anyone haveing trouble with a V1 verison getting too hot?
tomtheman is offline Find More Posts by tomtheman
Old Jun 11, 2011, 09:18 PM
Joined Feb 2007
I've never had a problem with mine getting hot but the warmest I flew it was in the 90's.
Old Jun 13, 2011, 06:20 AM
Joined Apr 2011
Any more flight information
Anyother information you can share and the flights you had after the first one?
Bob
Old Jun 13, 2011, 06:22 AM
Joined Apr 2011
Wondering
These are such GREAT planes it is hard for me beleive that we don't have more posts about them.
Old Jun 17, 2011, 10:36 PM
Joined Feb 2007
I've gotten a few more flights on the plane now and it is flying great. I think I have a good c/g, I will have to check and see where it is. I have the throws were I like them and only have to get the throttle curve a little better. If you carry power over the top of manuevers it can speed up in a hurry. But I do like the way it flies. Now I can't wait to get my miss wind done.
Old Jun 20, 2011, 10:13 PM
Anything that gives me a High
super kupfer's Avatar
Canada, BC, Richmond
Joined Jan 2010
Just finished one of these about 3 months ago:
My setup is:
Motor: Rimfire 1.20 on a 16x10 prop.
ESC: CC 100amp ICE.
Battery: Flight Power 30C 6S 5000mAh.
Receiver: Futaba R6008HS
Servo's: Rudder (Futaba BLS451), Elevator (x2 Futaba BLS153), Aileron (x2 Futaba BLS551).
After setting up the plane and putting about 30 flights my 2cents is:
I have unlimited vertical and has great speed, plane is very stable even on windy days, Plane tracks like a dream in the air (just point it), Aerobatics are solid and crisp all around A++++++.
The only thing I was not happy about is the flimsy gear struts, I wish they would be stiffer (Still trying to find a carbon substitute), I also wish they would have designed the canopy with a latch system instead of screws.
EVERY TIME I GO UP IT'S LIKE ROCK & ROLL IN THE SKY.........I LOVE IT
super kupfer is offline Find More Posts by super kupfer
Old Jun 21, 2011, 10:38 AM
Joined Apr 2011
Which Way?
Originally Posted by dcronkhite View Post
Jack, I thought the same about the tube initially, but the stabs just don't hold it tightly enough to remain solid. I glued my tube in.. problem solved.
Did you glue the tube to the stab or to the fuse?
Thanks,Bob
Old Jun 21, 2011, 02:42 PM
Joined Jan 2010
Here are some pictures I took with my Phone
Sold Sebart Miss Wind 50e hjcolman Aircraft - Electric - Airplanes (FS/W) 3 Feb 05, 2011 07:40 PM
Discussion Wind S 50E 3d-harrier Sport Planes 1 Jun 24, 2010 11:43 AM
Discussion Sebart Katana S 50e or Sukhoi 29S 50e for 5s 4900 sideway5 Electric Plane Talk 0 Nov 25, 2009 11:23 PM
Sold Sebart Miss Wind 50E Bieplane Tommyb240 Aircraft - Electric - Airplanes (FS/W) 7 Sep 18, 2009 10:50 PM
