Old Apr 03, 2011, 01:12 PM
RCBRUSKI65 is offline
Find More Posts by RCBRUSKI65
United States, MI, Saginaw Charter Township
Joined Feb 2007
Wind S 50e
I want to try to do a build thread on the new plane I'm putting together right now. The Wind S 50e. I'll be using a hacker A50-16s, Ice 75 controller and JR and Airtronics servos.
Tim
RCBRUSKI65 is offline Find More Posts by RCBRUSKI65
Old Apr 03, 2011, 01:13 PM
Joined Feb 2007
I chose the Yellow version
Old Apr 03, 2011, 01:18 PM
Joined Feb 2007
Here's some of the equipment I'll use.
Old Apr 03, 2011, 01:37 PM
r/cdawg is offline
Find More Posts by r/cdawg
r/cdawg's Avatar
Grandville, MI
Joined Dec 2003
I'm really looking forward to following this thread. I've had my eye on one of these and am hoping to get one later this summer. I really like the black, red, and yellow scheme. My eyes see the yellow base color better than the white.
r/cdawg is offline Find More Posts by r/cdawg
Old Apr 03, 2011, 03:41 PM
Joined Feb 2007
I wanted to change the smaller hinges out to normal size. Just had to open some of the slots a little bit. Then on the control horns rough up the base and glue them in.
Old Apr 04, 2011, 06:51 AM
Doug Cronkhite is offline
Find More Posts by Doug Cronkhite
2015 USA F3K Team Manager
Doug Cronkhite's Avatar
San Diego
Joined Feb 2002
Pay close attention to the stab tube fit in the fuse. Most if not all of them are very loose.
Doug Cronkhite is offline Find More Posts by Doug Cronkhite
Old Apr 04, 2011, 07:51 AM
Joined Feb 2007
The tube is loose, so I will most likely just glue it to the fuse once I get further along and make sure everything is straight.
Old Apr 04, 2011, 01:00 PM
jlachow is offline
Find More Posts by jlachow
Bridgewater, NJ
Joined Nov 2004
Nothing a little tape can't fix.
jlachow is offline Find More Posts by jlachow
Old Apr 04, 2011, 02:35 PM
San Diego
Joined Feb 2002
I tried tape Joe.. but it wouldn't stay firm. I ultimately glued mine into the fuse to keep it from moving around.
Old Apr 04, 2011, 02:58 PM
jlachow is offline
Bridgewater, NJ
Joined Nov 2004
I forgot the other alternative, iron on covering like monokote.
Old Apr 04, 2011, 10:30 PM
3Deranged is offline
Find More Posts by 3Deranged
Aerodynamically challenged
3Deranged's Avatar
3D World, Florida
Joined May 2005
Going to use pin hinging on my Wind. Did my buddy's Miss Wind the same way. Also adding Central Hobbies ball bearing control horns and ball links. Still waiting on a Scorpion 4025-12 to arrive. They've been on intergalactic backorder for a few months.
3Deranged is offline Find More Posts by 3Deranged
Old Apr 05, 2011, 01:30 PM
San Diego
Joined Feb 2002
The CA hinges work fine. Not sure why you'd want to change to something else honestly. In my 35 years of flying R/C I've never had a CA hinge come loose.
Old Apr 05, 2011, 03:03 PM
Mr. Wiz is offline
Find More Posts by Mr. Wiz
Time for me to Fly...
Mr. Wiz's Avatar
United States, MI, Fenton
Joined Jan 2000
I have. They weren't ones I installed however. You have to do them properly or they can fail. Not the hinge itself so much but more the installation thereof. If you don't get the glue to wick properly, for instance or if you cut too loose of a hinge slot, they can let go.
Mr. Wiz is offline Find More Posts by Mr. Wiz
Old Apr 05, 2011, 03:11 PM
jfetter is offline
Find More Posts by jfetter
HAL... Open the damn doors!
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
I just picked up one of these for SEFF, would have had it done today but the servos I had planned on using in the stabs didn't fit (stupid mini, micro mini, mini micro, sub-mini designations!) so I'll pick up a few new ones and finish this evening. The usual, easy Sebart build, perhaps 10 hours start to finish.
I saw the issue with the stab tube, mine is a little loose, I plan to just glue the tube in with ca, then hit it with some Aeropoxy inside the fuse so it doesn't move, I can live with removable stabs but not tube. I feel it would work fine as-is, the stabs (if put on firmly) will do most of the work holding everthing solid in-place.
Oh, one more note, I am opting for the rear-mounted rudder servo, not the pull-pull configuration. I personally have small to full 2M planes and can't tell the difference when done correctly, so in this case, I want to use the servo area for the RX so it's not jammed up against the battery or side-wall mounted, I like that option better. The plane comes setup for either BTW...
Jack
jfetter is offline Find More Posts by jfetter
Old Apr 05, 2011, 04:26 PM
San Diego
Joined Feb 2002
Jack, I thought the same about the tube initially, but the stabs just don't hold it tightly enough to remain solid. I glued my tube in.. problem solved.
Sold Sebart Miss Wind 50e hjcolman Aircraft - Electric - Airplanes (FS/W) 3 Feb 05, 2011 08:40 PM
Discussion Wind S 50E 3d-harrier Sport Planes 1 Jun 24, 2010 12:43 PM
Discussion Sebart Katana S 50e or Sukhoi 29S 50e for 5s 4900 sideway5 Electric Plane Talk 0 Nov 26, 2009 12:23 AM
Sold Sebart Miss Wind 50E Bieplane Tommyb240 Aircraft - Electric - Airplanes (FS/W) 7 Sep 18, 2009 11:50 PM
