Old Apr 03, 2011, 10:26 AM
Hooks is offline
Find More Posts by Hooks
Hooks's Avatar
Joined Jun 2009
New Product
UHF Long range JR / Futaba module
Yet another new UHF RC system for Long range FPV flying.
Comes as:
UHF JR module
UHF Futaba module
Parameters:
RF output:1000mw-2200mw
Power comsumption: 300-600mA
Range: 20-60km in the air
Failsafe: Yes
High and low power selection: 1000mw or 2000mw output
Highspeed control: yes
Transmitter parameters:
Hardware frequency Range 400MHz to 470MHz
Frequency stability :2.5ppm
Output low-pass Filter :NONE
Band 1
Start frequency:415Mhz
Step frequency:480Khz
Channel :70
Band 2
Start frequency:433Mhz
Step frequency:30Khz
Channel :70
Output Power : 30DB Peak / 33DB Peak
Rate : 40Hz/66Hz
RF interface impedance :50 Ohm
Supply Voltage : 8.4V to 16V
Reverse battery protection:NONE
Logic Voltage :3-12V
Current :
330mA/520mA (@50 Ohm load,12V Supply Voltage)
250mA/440mA (@No-load,12V Supply Voltage)
950mA/1.6A (@RF Short circuit,12V Supply Voltage)
Temperature:-20 to 70 Degrees Celsius
Receiver parameter:
Frequency Range 400MHz to 470MHz
Sensitivity : -112 DBM @0.1EBR(40Hz Refresh rate)
-111 DBM @0.1EBR(50Hz Refresh rate)
-110 DBM @0.1EBR(66Hz Refresh rate)
-108 DBM @0.1EBR(90Hz Refresh rate)
-104 DBM @0.1EBR(125Hz Refresh rate)
-104 DBM @0.1EBR(166Hz Refresh rate)
-101 DBM @0.1EBR(250Hz Refresh rate)
F/S turn on condition : >0.99EBR
Antenna gain : 2.15DBM
Step frequency :10kHz
Bandpass filter:Chip integration
Out-of-band rejection :No specific data
It can work with video and audio transmitter which frequency less than 300Mhz or higher than 500Mhz .
Refresh rate :40Hz50Hz66Hz90Hz125Hz166Hz250Hz
Hopping rate :40Hz50Hz66Hz90Hz125Hz166Hz250Hz
Hopping cycle:13Hz16Hz22Hz30Hz41Hz 55Hz 83Hz
Recover time :77mS62mS45mS33mS24mS 18mS 12mS
Response Time : 4mS to 25mS
PWM Output accuracy :0.5uS step ERROR<20PPM
PWM Output range : 0.5mS-2.5mS
PWM output cycle :55Hz @Normal mode
192Hz @Fast mode
PPM Output accuracy :0.5uS step ERROR<20PPM
PPM Output range : 0.5mS-2.5mS Each channel
PPM output cycle :50Hz@Normal mode & 1mS to 2mS Output
42Hz to 50Hz @Normal mode & 0.5mS to 2.5mS Output
50Hz to 83Hz @Fast mode & 1mS to 2mS Output
42Hz to 125Hz @Fast mode & 0.5mS to 2.5mS Output
PPM sync pulse width:4mS to 16mS Automatic adjust @Normal mode
4mS Locked @Fast mode
Recommend Supply Voltage : 3V to 8.4V
Shutdown voltage :2.1(+-0.15)V
Damage voltage :>15V
Power supply noise cancellation :<=15 VPP
Reverse breakdown voltage : >-15V
Output ports withstand voltage : >12V
Normal Current : <110mA
Operating Temperature :–40 to +80 °C
Price: 265.00 USD
Hooks is offline Find More Posts by Hooks
Old Apr 03, 2011, 10:53 AM
vertcnc is offline
Find More Posts by vertcnc
Illinois, USA
Joined Aug 2009
Looks really nice, except it sure would be nice if receiver had rssi out.
vertcnc is offline Find More Posts by vertcnc
Old Apr 03, 2011, 10:59 AM
Hooks is offline
Hooks's Avatar
Joined Jun 2009
Analog : The default setting is RSSI output
Working with higher version RF module, Analog port control data can configured as
your radio output CH1-CH10.1-2 ms pulse width corresponding to 0-3.3V voltage
Old Apr 03, 2011, 11:03 AM
vertcnc is offline
Illinois, USA
Joined Aug 2009
Analog output is Ok. I didn't see it at first on the receiver pins. Very good.
Old Apr 03, 2011, 11:34 AM
NDw is offline
NDw
Find More Posts by NDw
NDw
Ireland, Limerick, Kilmallock
Joined Aug 2010
What are others opinions on these posts from Mictronics
Originally Posted by Mictronics View Post
What I would worry about is the statement about the filter:
Without an LPF on the RF output the TX will generate a lot EMI on upper harmonic frequencies. And since it uses FHSS a broad spectrum will be disturbed.
Let's take the given frequency range 400-470MHz, that's the base band. Now you simply multiply this by 2,3,4 etc. to get the upper harmonics.
1. Harmonic: 800-940MHz
2. Harmonic: 1200-1410MHz
3. Harmonic: 1600-1880MHz
4. Harmonic: 2000-2350MHz
5. Harmonic: 2400-2820MHz
6. Harmonic: 2800-3290MHz
7. Harmonic: 3200-3760MHz
8. Harmonic: 3600-4230MHz
9. Harmonic: 4000-4700MHz
10. Harmonic: 4400-5170MHz
11. Harmonic: 4800-5640MHz
12. Harmonic: 5200-6110MHz
The RF output power will be reduced for each harmonic band by several dB but, since you operate the TX near your video receiver I would expect serious problems with video reception.
NDw is offline Find More Posts by NDw
Old Apr 03, 2011, 02:28 PM
Hooks is offline
Hooks's Avatar
Joined Jun 2009
No matter what I say! There will always be a nerd claiming this wont work in any way....
I'm not the builder or behind the product but I know it have been tested for some time, also with Video link 900, 1.2 Ghz and 2.4 Ghz in the FPV setup without any problem.
Old Apr 03, 2011, 02:32 PM
bracky72 is offline
Find More Posts by bracky72
Questionable judgement
bracky72's Avatar
Charles Town, WV
The specs and product look good. I hope it is the real thing.
bracky72 is offline Find More Posts by bracky72
Old Apr 03, 2011, 03:01 PM
Funjet2008 is offline
Find More Posts by Funjet2008
plus vite plus loins
Funjet2008's Avatar
Canada, QC, Trois-Rivières
Joined Jun 2008
I will make a FULL REVIEW soon.
http://www.foxtechfpv.com/product/Rm...0manual%20.pdf
some errors in the manual.
A. Keep receiver antenna straight, and about 90 degrees to each other
picture reads 180 degrees
Funjet2008 is offline Find More Posts by Funjet2008
Old Apr 03, 2011, 03:19 PM
bracky72 is offline
bracky72's Avatar
Charles Town, WV
I love my lrs but to not have a big metal box attached to my radio would be very very nice.
Old Apr 03, 2011, 05:51 PM
PnoT is offline
Find More Posts by PnoT
PnoT's Avatar
USA, NV, Las Vegas
Joined Jan 2011
The integration does look good but has anyone ordered it yet?
PnoT is offline Find More Posts by PnoT
Old Apr 04, 2011, 02:46 AM
levteros is offline
Find More Posts by levteros
Moscow, Russia
Joined Mar 2009
Turningy ?
Does anyone know if this can click into Turnigy 9x? Seems like they are visually compatible?
levteros is offline Find More Posts by levteros
Old Apr 04, 2011, 02:53 AM
NDw is offline
NDw
NDw
Joined Aug 2010
It says it can on the page(the JR version) and yes any JR module will fit into the 9x radio.
Old Apr 12, 2011, 08:33 PM
AeroM'ck'y is offline
Find More Posts by AeroM'ck'y
Australia, VIC, Melbourne
Joined May 2009
Does anyone know if it is possible to use 9ch + rssi output?
AeroM'ck'y is offline Find More Posts by AeroM'ck'y
Old Apr 13, 2011, 11:17 AM
liteglow is offline
Find More Posts by liteglow
Joined May 2005
Give it one more week and I should have mine in my plane
I will also test this on the ground with my car to see how long range I can get on ground.
liteglow is offline Find More Posts by liteglow
Old Apr 13, 2011, 05:17 PM
VaZ is offline
VaZ
Find More Posts by VaZ
VaZ
TheFlyer_PT
VaZ's Avatar
Portugal
Joined Feb 2011
lol... when you can beat them, join them! good though, a quite range of UHF modules already, competition is always good, a nice way for every supplier to make better improvements.
Vaz.
VaZ is offline Find More Posts by VaZ
Wanted Scherrer UHF long Range or Dragon Link patrick21x FPV Equipment (FS/W) 6 Dec 24, 2015 03:50 AM
For Sale RMILEC 2.4 long range JR module + Receiver Talajouy FPV Equipment (FS/W) 5 Mar 15, 2011 12:33 PM
Discussion PMR Walkie Talkie or cheap UHF module for long range control? cloudy FPV Talk 3 Dec 09, 2010 12:09 PM
Discussion Long range flight, UHF TX antenna optimisation Ian Davidson FPV Talk 9 Nov 09, 2010 02:23 AM
Discussion Long range UHF compatibility question wingsuitdude FPV Talk 5 Sep 20, 2010 05:31 PM
