Old Apr 03, 2011, 06:30 AM
Ryleh is offline
Find More Posts by Ryleh
Black Box hogger
Ryleh's Avatar
London
Joined May 2009
thrust angle on motor mount - a bit more scientific approach to offsets etc
Hi Guys,
I'm currently doing my first electric conversion of a glow plane and as many of you know, electric motors unlike their glow counterparts need a down and left thrust angle (around 2deg) to work properly.
This did kind of yield a simple yet interesting problem - if you get a rigid metal motor mount which doesn't have the thrust angle built in you will have to mount the whole metal motor mount at an angle.
Now with electric conversions motor mount will be quite long so this means you will have to offset the whole motor mount in order for the shaft to come out in the middle!
Now I'm not a person that likes to do it based 'on the feel and looks' - I'd rather properly calculate the offsets and number of spacers I need to put in (I'm an math whore!)
There is plenty of engineers here so they might share an better approach - anyways - my motor mount is a bit funky in a sense it's not square based (rectangle) and that the motor is not mounted in the smack middle but on the upper (picture attached).
The approach presented here can be generalized to any kind of firewall (starfish, pentagram, circle, euclidean geometry of Cthluhu stronghold)
The idea is - we measure (in this case) 5 points of interests of the firewall - 4 base points where the screws come in and the point where the shaft should come out of the cowling.
With those 5 points we construct a simple mesh within 3d euclidean space which we then transform with two rotational matrices around the X and Y axis.
This yields new point coordinates - and voila - we got X, Y offsets for the whole motor mount and thinness of spacers we need to put in 3 of the base screws to get the thrust angles right.
So:
step 1) - measure the motor mount (between the screws):
In my case
- width wise the base screws are 80mm apart
- height wise the base screws 60mm apart
- the shaft from base to where it comes out of the firewall is 130mm deep
- the center section of the motor shaft from the top screws is 14.5mm apart (as mention and seen on picture - it's not central)
step 2) - create the mesh
In this case it's just going to be 5 points.
Because we are rotating around the base points will be at the Z = 0 depth.
Because we want the offset of the center piece the point on the shaft will be at (X,Y) = (0,0)
So in my case we have the following (X, Y, Z) coordinates:
P1 - upper left corner of the motor mount
P1 = (-40, 14.5, 0)
P2 - upper right corner of the motor mount
P2 = (40, 14.5, 0)
P3 - lower right corner of the motor mount
P3 = (40, -45.5, 0)
P4 - lower left corner of the motor mount
P4 = (-40, -45.5, 0)
P5 - point on the shaft where the whole thing is coming out
P5 = (0, 0, 130)
As seen on screen (I'm bad with pictures sorry):
Now let's rotate this little construct to get the right thrust angle - first rotate it right around Y axis with Alpha degrees to get the right thrust angle and then against the X axis with Beta degrees to get the down thrust angle.
(The formulas here are for counter-clockwise rotation).
So a bit math here:
The transformation rotation matrix around Axis Y (Ry) and X (Rx) have the following formulas.
In order to get the transformation matrix for rotation against Y axis first (for left thrust) and then X axis (for down thrust) we multiple Matrix Ry by matrix Ry and get the following product (keep in mind Ry * Rx is different from Rx * Ry)
To get the coordinates of the new point we multiple the old coordinates by the transformation matrix (formula bellow):
So let's put some numbers in (because now it's easy)
I'm going for standard 2 deg down and left thrust (So both Alpha and Beta are 2 deg)
sin(2deg) = 0.034899497
cos(2deg) = 0.999390827
So the formula roughly looks like:
Now putting in the numbers I get
P1 = (-40, 14.5, 0)
P1' = (-39.95, 14.49, 1.9)
P2 = (40, 14.5, 0)
P2' = (39.99, 14.49, -0.89)
P3 = (40, -45.5, 0)
P3' = (39.92, -45.57, -2.98)
P4' = (-40.03, -45.47, -0.019)
P5 = (0, 0, 130)
P5' = (4.53, -4.53, 129.84)
Rounded it up to two digits.
Ok so those are nice numbers but what do they tell us?
The important one is P5 - it tells us that after applying the 2 deg down and 2 deg left thrust the point will move by 4.53mm left and 4.53mm down from the original location:
This means that I have to offset the whole motor mount by 4.53mm to the top and 4.53mm to the left in order for the shaft to still come out of the middle of the cowling.
Another important information is how many spacers I need to add to each of the point on the mount to get the 2 deg left and 2 deg down downthrust!.
If we look at the P3 which is the 'lowest one' - if we treat it as a zero (touching the firewall)
It means that:
- on the upper left corner (P1) I need to add 4.88mm of spacers (1.9mm + 2.98mm)
- on the upper right corner (P2) I need to add 2.09mm of spacers (-0.89mm + 2.98mm)
- on the lower left corner (P4) I need to add 2.961mm of spacers (-0.019mm + 2.98mm)
Hope this helps someone
OK - mistake on my side - it should be right side thrust so it should be Ry(-2deg) not Ry(2deg) - case is symmetric so no problems there but will amend!
Ryleh is offline Find More Posts by Ryleh
Old Apr 03, 2011, 06:51 AM
BrotherBloat is offline
Find More Posts by BrotherBloat
London RC Project
BrotherBloat's Avatar
London
Joined Apr 2009
ITT: hardcore matrix and trig. be warned
nice one
BrotherBloat
London RC Project
www.rc-forc3.com
BrotherBloat is offline Find More Posts by BrotherBloat
Old Apr 03, 2011, 09:43 AM
LesUyeda is offline
Find More Posts by LesUyeda
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
"electric motors unlike their glow counterparts need a down and left thrust angle (around 2deg) to work properly."
Based on what, I may ask. My scratch designed and built Jungmeister (my avatar) used neither, and flies like it is on rails.
Les
LesUyeda is offline Find More Posts by LesUyeda
Old Apr 03, 2011, 10:54 AM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
I've never noticed that electric power models need any more or less down and right thrust compared to glow (there is no logical reason why they would).. Both types often benifit from thrust offset but it's not necassarilly two degrees, it could be more it could be less, it could be nothing.
The calculations look ridiculously overly complex it you ask me.. It's just simple schoolboy trig (or it should be):
The amount you need to pack between mount and firewall is:
Packing = sine(thust offset angle) x distance between mounting bolts
The amount you need to offset the mounting points upwards or to the left:
Offset = sine(thust offset angle) x firewall to prop length
That's a whole load simpler than a page of calculation
Steve
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Apr 03, 2011, 12:10 PM
Ryleh is offline
Black Box hogger
Ryleh's Avatar
London
Joined May 2009
Steve
Not accurate thou - what works on a plane doesn't if you have 3 dimensions.
Old Apr 03, 2011, 01:19 PM
Aberdeen
Joined Mar 2006
It's perfectly accurate, or perfectly accurate enough for those who dont build with a micrometer..... If you have offsets in two planes (down and side) then you just add together the packing thicknesses
For example.. say you want 3 deg down thrust and 2 right thrust and lets say the bolts are 50mm apart.
The two top bolts get packed by: sine 3Deg x 50 = 2.6mm
The two left bolts get packed by: sine 2Deg x 50 = 1.7mm
The top left bolt gets both packings added together: 2.6 + 1.7 = 4.3mm
Simple as it gets.....
PS... unless your prop is spinning the opposite way to normal your calculations are wrong because you would need rightthrust, not left thrust, which would mean P4 should be flat against the firewall??
Old Apr 03, 2011, 01:35 PM
Ryleh is offline
Black Box hogger
Ryleh's Avatar
London
Joined May 2009
For example.. say you want 3 deg down thrust and 2 right thrust and lets say the bolts are 40mm apart.
PS... unless your prop is spinning the opposite way to normal your calculations are wrong because you would need rightthrust, not left thrust.....??
Yeah already got that - it should be -2deg- case is perfectly symmetric so no worries
Old Apr 03, 2011, 01:48 PM
Aberdeen
Joined Mar 2006
Using my simple method to check your calculations.....
I confirm your up/left offset exactly (or within a micron or two):
sine 2Deg x 130mm = 4.53mm (up and left)
However your spacer calcs are wrong:
P4 should be flat on the firewall.
P3 should have 2.8mm spacer
P1 should have 2.1mm spacer
P2 should have 4.9mm spacer
Steve
Old Apr 03, 2011, 01:57 PM
Ryleh is offline
Black Box hogger
Ryleh's Avatar
London
Joined May 2009
Yeah and I noticed the mistake thx
Steve
Old Apr 06, 2011, 12:52 PM
alex26i is offline
Find More Posts by alex26i
United States, MI, Portage
Joined Oct 2010
Cool
I will just get the same motor and set it up the same as you got. No need to make my brain smoke from all this Calculator punching.
alex26i is offline Find More Posts by alex26i
Old Apr 09, 2011, 05:06 PM
DanSavage is offline
Find More Posts by DanSavage
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Hi Guys,
What about p-factor?
The need for side thrust is to counteract the asymmetrical thrust caused by the prop rotation. The descending blade produces more thrust than the ascending one. This is why helicopters have cyclic.
Because our props rotate counter-clockwise (when viewed from the front) the descending blade is on the right side of the prop disc. Right-thrust is needed to neutralize this asymmetric condition.
If the prop rotated the other way, then left thrust would be needed.
Dan
DanSavage is offline Find More Posts by DanSavage
Old Apr 29, 2014, 12:15 PM
dorin is offline
Find More Posts by dorin
Joined Feb 2012
Ok, digging up an old thread, I need exactly the same, 2 degrees down and 2 right, so can you guys confirm the below calcs are ok?
Many thanks,
Dorin
dorin is offline Find More Posts by dorin
Old Apr 29, 2014, 06:57 PM
L.A. is offline
Find More Posts by L.A.
Joined Jan 2014
A few comments. Most of my glo and gas R/Cs from 20+ years ago, had offset thrust. A whole lot of full size airplanes have offset thrust. Some full size aerobatic planes use side thrust, while some don't.
The real advantage of side thrust in a full size, is that you won't be constantly stepping on the right rudder pedal, or trimming..............to fly straight. Otherwise, the plane will be in a constant side ways flight (yaw), while at cruise speeds. The forces that create this yaw, vary with power output. More power, and more yaw. Side thrust is just more automatic, than relying on foot pressure or trims. Side thrust can be used, as well as an offset vertical stabilizer or rudder trim tab. The disadvantage of side thrust, is the way it can effect some aerobatic manuvers. As an example, an Extra 300 has it, while the Pitt's does not. Flying a Pitts across country is no fun. It wears your leg out!
L.A. is offline Find More Posts by L.A.
Old Apr 30, 2014, 09:16 AM
LesUyeda is offline
LesUyeda's Avatar
Joined Dec 2004
OK! I went out and looked at what was in my hanger (garage). Out of 10 planes hanging ( 8 have been flown). Only one has right thrust, none have down; and they do just fine.
I probably include that these range from .049 fuel up through, and including .91 fuel, and up to 120 size (equivalent??), electric.
Les
Old Apr 30, 2014, 10:11 AM
ampmaker is offline
Find More Posts by ampmaker
Sleepy Hollow, IL
Joined Dec 2008
I have 11 planes and all are electric powered. All of them are balsa, ply and no foamies. 48" SBach, assorted Sticks from 40 size to 160 size, 74" Extra, 76" Sukhoi, 96" Storch, etc.
Eight have between 1.5 and 2 degrees of right thrust and ZERO down thrust and three have 1.5 to 2 degrees down thrust and ZERO side thrust.
All fly fine.
There is no predetermined required amount of side and down thrust for a model plane. Each plane is different and will be determined by the design and flying characteristics.
ampmaker is offline Find More Posts by ampmaker
Help! HELP! Gee Bee 40 motor mount angle??? sugat_805 Fuel Plane Talk 46 May 31, 2011 04:42 PM
Discussion how to mount this motor on to my funjet motor mount? bobmaxiao Electric Plane Talk 11 Oct 30, 2010 10:53 AM
Motor mount thrust angle Mad186227 3D Flying 0 Oct 17, 2005 04:36 PM
Question Shock Flyer motor mount thrust angle??? CactusJackSlade 3D Flying 5 May 13, 2004 04:54 AM
