Old Apr 03, 2011, 03:54 AM
richos is offline
Find More Posts by richos
richos's Avatar
United Kingdom, England, Wells
Joined Mar 2008
New Product
Plug and play Miniaviation 190mha 25c Platinum Edition Battery.Post your results here
Wow! Check this one cell Lipo out
'Kyosho Minium / E Fligh' MCX style 190mha 25c Platinum Edition Battery
Our new range of Miniaviation 25C batteries deliver a big boost in performance over the standard 110mah – 150mah ParkZone & Eflite batteries making them a great upgrade for your aircraft.
As well as the extra capacity, these cells are capable of 25c discharge which translates into a higher voltage under load than most cells available for these models, which gives more lively performance. Give them a try, we're sure you'll agree they are the best plug and play battery you've put in your micro plane.
Suitable for use with:
•Parkzone’s Ember, Cub, Mustang, Vapor, Sukhoi, Trojan, Corsair
•E-flite’s Micro,
http://www.miniaviation.com/KM_190P.html
richos is offline Find More Posts by richos
Old Apr 03, 2011, 05:17 AM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
This is great new miniavation is 10 minutes from me thanks for posting
Kris... is offline Find More Posts by Kris...
Old Apr 04, 2011, 10:55 AM
richos is offline
richos's Avatar
Joined Mar 2008
Well iv just ordered some to try out iv got a extra on the way in the post
Wish i was 10 minutes away from Miniavation wouid save on post and packageing also hope thay fit my MSR
Old Apr 06, 2011, 05:17 PM
SoaringOstrich is offline
Find More Posts by SoaringOstrich
United Kingdom, England, Poole
Joined Nov 2010
I've just got some myself, and they do fit easily into the MSR. I used the spacer that came with an EFlite 150 mAh battery (1 cm wide) to get the correct CG.
The best part is... just over 10 minutes of flight time before low voltage cutout! I think in future I will try to land after about 8 minutes to be safe.
SoaringOstrich is offline Find More Posts by SoaringOstrich
Old Apr 06, 2011, 10:54 PM
Kris... is offline
Registered Addict
Kris...'s Avatar
Joined Jul 2010
how you getting on with yours richo?
Old Apr 07, 2011, 06:43 AM
richos is offline
richos's Avatar
Joined Mar 2008
Miniaviation 190mha 25c on digital scales.
My 190mha lipos have terned up so i put them on my scales .
Looking at them i was a bit disappointed thay look much bigger than the original old Miniaviation 180mha 15c so i thort that the 190mha would weigh mutch more!
I then wondered if thay would fit my little old MCX . Yes as you can see thay fit no probs
Time to weigh them now... thay weigh the same as the old Miniaviation 180mha 15c5g , can this be true i had to get my 10g calibration weight to check my digital scales.
Yep the are Miniaviation 190mha 25c Platinum Edition Batterys are 5g
Hang on! The Hyperion G3 CX 25C 160mAh is 4.8g thats only 0.2g less than the Miniaviation 190mha but you get 30mAh more with the same
25c punch
Looks like we have a new kid on the block with this 190mha 25c Lipo
Old Apr 08, 2011, 07:00 AM
richos is offline
richos's Avatar
Joined Mar 2008
KRIS to be honest iv had no time to try them out yet ! Work gets in the way of micro flying . But tomorrow im going to the sports hall to give them a try out in my extra i got for my birthday will see how thay perform compaired to my stock E-flite 150mah 12c lipos.
Everyone seems to be going on about the HYPERION G3 CX 180MAH LiPO 25C SINGLE CELL LIPO but the weight is 5.65g compaired to 5.00g of the Miniaviation 190mha 25c and you get an extra 10mah to .
And you dont have to gouge out a hole in the belly of you PZ Mustang, Sukhoi, Trojan , to make it fit like i had to do with my little old Mk 1 Sukhoi .
Roll on the release date of the PZ Corsair this looks the Lipo made for it .
HYPERION G3 CX 180MAH LiPO 25C Dimensions mm ( L x W X H ): 32.3 x 20.2 x 5.2 Weight: 5.65g
Miniaviation 190mha 25c Platinum Edition Battery Dimensions mm ( L x W X H ): 42.2 x 11.1 x 6.2 Weight: 5.00g
Old Apr 08, 2011, 09:58 AM
Kris... is offline
Registered Addict
Kris...'s Avatar
Joined Jul 2010
Interested to see how they compare. I love my HYPERION G3 CX 180MAH's in my ultra-micros they really bring these planes to life.
Old Apr 09, 2011, 06:51 AM
richos is offline
richos's Avatar
Joined Mar 2008
SoaringOstrich iv just got a 13min 40 sec time before low voltage cutout on my little old MCX .
Is that good for a plug and play Lipo? not into Micro choppers much so i will ask the boys over in the Micro chopper forum thread .
Its a beautiful day in the village im looking over cottage roofs and i can see buzzards thurmalling at 500 feet or so over the moors , what a beautiful site buzzards are the Kings of thurmalling .
Ive got my little Kyosho citabria with a PZ vapor brick in her so im going to put her in a box on the back of my bike and see if i can join the buzzards thurmalling its to good a day to take the 4-site to the sports hall and traffics to bad on the main road into town. I HATE STRESS
Im off on me push bike to see if i can make it to where the buzzard saw
And on the way back i have to pass a lovely little pub . It would be rude not to pop in and have a pint or two
Old Apr 09, 2011, 04:49 PM
Joined Nov 2010
I'm not really an expert either, since the MSR is my only chopper (unless you count the Silverlit PicooZ 2-channel toy). With the original 120 mAh batteries I used to get about 5 minutes, but they wore out quickly. I decided to get some new lipos when the run-time went down to 30 seconds!
I also had some cheap Overlander brand 150 mAh batteries which were about the same size as the E-Flite 120s. They used to run for seven minutes when new, but only last for four now.
I've also tried the new 190 mAh in my Champ now: 25 minutes to LVC. That was mostly low-throttle cruising, but with a few loops and lots of practice landing approaches thrown in.
Old Apr 10, 2011, 06:50 AM
richos is offline
richos's Avatar
Joined Mar 2008
(Quote) from SoaringOstrich
25 minutes to LVC thats good for a plug and play Lipo in a Champ :eek
Looks like the old Hyperion G3 CX 25C 160mAh that used to be the biggest and powerfull plug and play 25c Lipo has had its day.
Looks like the Miniaviation 190mha 25c Platinum Edition Battery is now the King of the plug and play 25c Lipos
Old Apr 12, 2011, 01:56 PM
richos is offline
richos's Avatar
Joined Mar 2008
Richard Barnett Proprietor of Miniaviation...
(Quote)
Weights for the Platinum range
130mah is 38x12x6.5mm = 3.9 gram
160mah is 45x12x6mm = 4.6 gram
190mah is 45x12x6.8mm = 5.1 gram
Enjoy!
Noticed in a couple of threads people saying that we didn't include the hyperion 160 on the graph. The intellect UM cells i'm 99% sure are the same cells. The discharge curve, the look of them etc are the same.
Discharge curves for 160 190mAh
http://www.miniaviation.com/images/d..._curve_25c.jpg
130mAh
http://www.miniaviation.com/images/d..._curve_130.jpg
Old Apr 15, 2011, 01:54 PM
richos is offline
richos's Avatar
Joined Mar 2008
Swoosh.... swoosh .. tumbleweed !!!!!!
Only three of us have tried out the Miniaviation 190mha 25c Lipo
So thats Me, SoaringOstrich, and KRIS, thats only three of us in the whole world who have tried out the plug and play 190mha 25c Lipos
Well im off to see if i can hover me little old MCX for more than 13min 40 sec before LVC .
SoaringOstrich have you done more than 25 minutes to LVC in your Champ yet ??
Just over 10 minutes of flight time before low voltage cutout on a MSR micro chopper !!!!
Hay why not a E-flite Series Y Harness Adapter on a UMX Beast that would be two x Miniaviation 190mha 25c Lipos at only 10.2g all up Weight..
A stand alone 180mAh Hyperion G3 180mAh 25c 2S (7.4V) is 13.6g Weight..
Or 2 x 160mAh Hyperion G3 25C on a Y Harness Adapter would be 9.6g Weight and you would be 60mha down on power on the Miniaviation 190s
Start posting your results here.. we need to see how these little gems stack up against the other lipos on the market
Old Apr 15, 2011, 04:52 PM
Joined Nov 2010
Probably something to do with the fact that we live in the same country where Miniaviation is based. I'd imagine that shipping a £4 battery across the Atlantic isn't particularly economic for Americans.
I haven't had a chance to fly my Champ again since my last post, because I'm supposed to be writing a PhD thesis at the moment. I wouldn't really want to fly for much longer than 25 minutes at a time anyway, and from now on I will be trying to land well before LVC so that I don't kill the cells like my old E-Flite ones.
As for the MSR, the motors get pretty hot after eight minutes, so it's probably best not to push it much beyond that. With such long flight times, I'm starting to think that buying the 5-pack might have been a bit over the top...
Old Apr 16, 2011, 04:30 AM
richardbarnett is offline
Find More Posts by richardbarnett
UK
Joined Sep 2009
Just a little note.
Our shipping to the USA or anywhere in the world outside Europe is $2.95 USD.
We try to keep our shipping costs as low as we can.
richardbarnett is offline Find More Posts by richardbarnett
Discussion New Miniaviation 25C cells now available richardbarnett Micro Helis 5 May 28, 2011 12:19 PM
Discussion New Miniaviation 25C UM cells now available richardbarnett Micro Ready-to-Fly 14 May 22, 2011 12:43 PM
For Sale Traxx Slash 4x4 Platinum edition 53"SuperGator Cars - Trucks and Parts (FS/W) 7 Dec 06, 2010 04:40 PM
Sold Traxx Slash 4x4 Platinum edition 53"SuperGator Cars - Trucks and Parts (FS/W) 0 Nov 27, 2010 12:33 PM
For Sale Team Orion Platinum Edition 4800 LiPo RC Car Battery Bud Morrison Cars - Cars and Parts (FS/W) 0 Dec 31, 2007 01:25 PM
