Old Nov 12, 2012, 10:05 AM
picard10th's Avatar
United States, FL, Marco Island
Joined Jan 2007
Originally Posted by Ducati Monster View Post
My english just sucks, but here I go:
Is it possible to mount the turnstile antenna vertically on the rudder and keep the TX antenna vertical?
My Nagoya NA-774 is omni directional, so if I mount it horizontally will I need to "point" it to where the plane is? If the tip of the antenna is pointing to my right for example and the plane head to there will the radio lose signal strength?
Works best horizontally. Alex explains in this thread.
picard10th is online now Find More Posts by picard10th
Old Nov 13, 2012, 08:16 AM
United States, FL, Palm Beach
Joined Jan 2011
Originally Posted by FabioBrazil View Post
Hi Alex, once again, thanks for your tutorials.
May you could help me on a little doubt here
I want to make a dipole antena for my DragonLink that can be feeded by the botton part. like on the right image
Using the stock dipole feed by the center, I guess I´ll have a no good geometry if I place it like the image on the left.
And it will be a pain to take off some elapor to dig the cable and antenna.
Using an antenna like the one on the right image, I just drill a hole on the rudder, and everything goes straight.
I know the measures to built a 433 mhz antena, but dont know how to make the ground part.
Thanks a lot
Why not just let the ground side of the DL antenna dangle free. Works well for me.
viper522 is offline Find More Posts by viper522
Old Nov 13, 2012, 12:05 PM
Joined Mar 2009
Hi Viper, thanks for replying.
I´m afraid the ground part hanging loose will distort the radiation pattern.....
But I´m not a specialist
FabioBrazil is offline Find More Posts by FabioBrazil
Old Nov 13, 2012, 12:30 PM
Joined Jan 2011
Fabio - the hanging loose method is one of the suggested methods straight from DragonLink. This is documented on their website. Have a look.
http://www.dragonlinkstore.com/v2/node/20
For sport flying, and for shorter range electric FPV planes with no landing gear and limited space to mount an antenna, the antenna should be mounted as in the second picture, with the ground side just hanging below the fuselage. This will reduce performance a little bit, but not a whole lot. Unless you fly more than 10 KM away, you will never even notice the performance reduction you get from this free wire hanging in the wind. The wires I use to construct the antenna are very strong and flexible, so this installation will last many years on the tail of an electric plane like this without breaking, even though the wire drags along the ground in landing.
Old Nov 14, 2012, 12:07 AM
picard10th's Avatar
Joined Jan 2007
Alex does it again!!!
I was a little concerned with the RSSI% I was showing with the Rangelink stock dipole Rx antenna. So I built a IBC Turnstile to see if it would help. I set the RL Tx on micro mode an put the plane in the garage, I was getting 0-5% RSSI with intermittent Fail Safes. I switched to the TS and got a 15-20% RSSI, Sweet!!
I switched back and forth standing in different positions with the same consistent results. The I remembered HORIZONTAL..The RSSI%shot up to 29-30% Huge!! Back to stock 0%, IBCTS 30% Unbelievable. Can't wait to see how it translates in the air. Used 18 Gage and It sits on the tail of my Skywalker.
THANK YOU ALEX!!!!
Old Nov 14, 2012, 04:05 AM
FPV in Hawaii
iskess's Avatar
United States, HI, Kailua
Joined Feb 2012
THANK YOU ALEX!!!!
Please post a photo of your antenna installation so we can see how you fit the big horizontal turnstile on the tail.
Thank you.
iskess is offline Find More Posts by iskess
Old Nov 14, 2012, 11:49 AM
picard10th's Avatar
Joined Jan 2007
Thank you.
Any issues here IB?
I made the feed to long, I'll rearrange soon.
Leaving to fly now!
Old Nov 14, 2012, 04:50 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Looks good to me. Enjoy your flight
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Nov 18, 2012, 08:28 PM
Joined Dec 2006
How critical is any particular orientation of tx antenna? ie is conventional straight up ok for most purposes?
doonunder is offline Find More Posts by doonunder
Old Nov 19, 2012, 06:12 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Orientation for the turnstile isn't very critical because it is dual polarized with no nulls. Laying it flat is generally preferred, but not necessary.
-Alex
Old Nov 19, 2012, 02:47 PM
Joined Dec 2006
-Alex
Thanks Alex.
Old Nov 19, 2012, 03:50 PM
Joined Dec 2006
Hi Alex sorry forgot to add in last question, is it best like in the crosshair build to measure the elements from the same point in the middle or from the first bit of exposed shield/middle conductor?
Also does it matter if the feed is only 5cms long?
Old Nov 20, 2012, 11:16 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Yes, measuer all points from the middle. a 5cm feed is ok.
-Alex
Old Nov 20, 2012, 01:21 PM
Joined Dec 2006
Thanks Again
Old Dec 14, 2012, 11:45 AM
Joined Dec 2005
hey would this work as transmitting antenna?
skygizmo is offline Find More Posts by skygizmo
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV/RPV - Equipment and Vehicles (FS/W) 8 Jul 22, 2011 03:55 PM
Mini-HowTo Build a performance antenna for your LRS radio IBCrazy Video Piloting (FPV/RPV) 18 Apr 11, 2011 09:57 PM
Question UHF LRS Pro Antenna Question CageHound Video Piloting (FPV/RPV) 4 Apr 04, 2010 09:47 AM
Discussion For Sale: Spektrum DX7 for use with UHF/LRS jeff1068 Video Piloting (FPV/RPV) 0 Mar 31, 2010 07:24 PM
Discussion Scherrer UHF LRS x Futaba 12FG/R6014FS Cr_Conrado Video Piloting (FPV/RPV) 2 Dec 20, 2009 07:35 AM
