Old May 10, 2012, 05:58 AM
JarandLT is offline
Find More Posts by JarandLT
Norway, Hordaland, Vaksdal
Joined Nov 2011
I have recently purchased the Turnstile antenna, and have a question: Does it matter which way the antenna parts point, eg: Ground points backwards, and + points forwads?
Thanks !
Jarand
JarandLT is offline Find More Posts by JarandLT
Old May 10, 2012, 08:41 AM
Vintabilly_NS is offline
Find More Posts by Vintabilly_NS
..in a Johnny Cash voice.
Vintabilly_NS's Avatar
Canada, NS, Beaver Bank
Joined Aug 2010
^^^ He mentioned a spherical radiation pattern so it shouldn't matter how it's aligned as long as the polarization matches. sum- Flat is ok in any direction because it's radiating equally in all directions.
~V
Vintabilly_NS is offline Find More Posts by Vintabilly_NS
Old Jun 22, 2012, 01:23 AM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Alex,
I built a turnstile and put it on my hexacopter.
Man that thing works good...
-Mike
m_beeson is offline Find More Posts by m_beeson
Old Sep 30, 2012, 01:49 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Alex,
What would the results be; If this antenna were built with
.035 mig wire?
-Mike
Old Oct 01, 2012, 12:08 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
It would perform just a bit better, actually. Ideally you'd use .062" wire.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Oct 01, 2012, 02:42 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Thank you Alex,
I'll find some .062 wire, and build one.
I can't wait to see the results.
-Mike
-Alex
Old Oct 08, 2012, 01:11 PM
Mike_Tosen is offline
Find More Posts by Mike_Tosen
Joined Jun 2009
-Alex
Hi,
Sorry, maybe I am just missing something.
I am busy getting all the stuff to build one of these for my 433mhz system.
Also looking at using mig wire.
But now the spec and this is confusing me - originally it calls for 18-24 awg - which is 0.04 - 0.02 inch diameter or 1.02mm - 0.51mm diameter.
The 0.063 mig wire is 1.6mm diameter.
Am I reading this correct that 1.6mm diameter mig wire would work just fine ?
Or is it better to go for something thinner - like 0.8mm or 1mm wire ?
Thanks for the excellent writeup.
Mike_Tosen is offline Find More Posts by Mike_Tosen
Old Oct 08, 2012, 01:48 PM
HunnerBunner is offline
Find More Posts by HunnerBunner
HunnerBunner's Avatar
United States, UT, Salt Lake City
Joined Dec 2003
Is there any chance of this working for 2.4ghz radio rx? I would like to get better performance from my stock system. What I think my real question is, what would the measurements be for 2.4ghz?
HunnerBunner is offline Find More Posts by HunnerBunner
Old Oct 08, 2012, 03:33 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
For 2.4GHz, the specs are on FPVLAB. I thin it's post #179 or so.
@Mike - You are over thinking this. The wire makes almost no difference at all. You can use 30AWG and it will work fine. I just had to put some kind of constraint on it, that's all.
-Alex
Old Oct 08, 2012, 11:29 PM
Joined Jun 2009
-Alex
Cool - Thanks
Old Nov 11, 2012, 05:47 AM
Ducati Monster is offline
Find More Posts by Ducati Monster
Joined Apr 2012
My english just sucks, but here I go:
Is it possible to mount the turnstile antenna vertically on the rudder and keep the TX antenna vertical?
My Nagoya NA-774 is omni directional, so if I mount it horizontally will I need to "point" it to where the plane is? If the tip of the antenna is pointing to my right for example and the plane head to there will the radio lose signal strength?
Ducati Monster is offline Find More Posts by Ducati Monster
Old Nov 11, 2012, 01:48 PM
FabioBrazil is offline
Find More Posts by FabioBrazil
Joined Mar 2009
DL Antenna - Dipole?
Hi Alex, once again, thanks for your tutorials.
May you could help me on a little doubt here
I want to make a dipole antena for my DragonLink that can be feeded by the botton part. like on the right image
Using the stock dipole feed by the center, I guess IŽll have a no good geometry if I place it like the image on the left.
And it will be a pain to take off some elapor to dig the cable and antenna.
Using an antenna like the one on the right image, I just drill a hole on the rudder, and everything goes straight.
I know the measures to built a 433 mhz antena, but dont know how to make the ground part.
Thanks a lot
FabioBrazil is offline Find More Posts by FabioBrazil
Old Nov 12, 2012, 08:58 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
The right hand picture is an unbalanced antenna. The radiation pattern would be distorted. How much depends on how much skin effect the signal has. Hard to really say.
-Alex
Old Nov 12, 2012, 09:38 AM
Joined Mar 2009
Hi Alex, thanks for the fast reply.
So the recomended setup is the first image? Even using the feed cable almost like a "S" shape. I mean, not straight ? Thanks
Old Nov 12, 2012, 10:03 AM
picard10th is offline
Find More Posts by picard10th
picard10th's Avatar
United States, FL, Marco Island
Joined Jan 2007
Originally Posted by fabiobrazil View Post
hi alex, thanks for the fast reply.
So the recomended setup is the first image? Even using the feed cable almost like a "s" shape. I mean, not straight ? Thanks
yes!
picard10th is offline Find More Posts by picard10th
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV Equipment (FS/W) 8 Jul 22, 2011 03:55 PM
Mini-HowTo Build a performance antenna for your LRS radio IBCrazy FPV Talk 18 Apr 11, 2011 09:57 PM
Question UHF LRS Pro Antenna Question CageHound FPV Talk 4 Apr 04, 2010 09:47 AM
Discussion For Sale: Spektrum DX7 for use with UHF/LRS jeff1068 FPV Talk 0 Mar 31, 2010 07:24 PM
Discussion Scherrer UHF LRS x Futaba 12FG/R6014FS Cr_Conrado FPV Talk 2 Dec 20, 2009 07:35 AM
