Old Mar 06, 2012, 02:07 AM
zkilzz is offline
Find More Posts by zkilzz
Joined Sep 2011
How will this antenna affect my gps? Can i have my turnstile on bottom of the Z2 and GPS ontop? Or will the RX antenna cause to much interferance with the GPS?
zkilzz is offline Find More Posts by zkilzz
Old Mar 06, 2012, 08:22 AM
IBCrazy is online now
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
It is a receiving antenna. It will have no effect on GPS.
-Alex
IBCrazy is online now Find More Posts by IBCrazy
Old Mar 06, 2012, 03:13 PM
zkilzz is offline
Joined Sep 2011
-Alex
Thanks. Can i cut the foam of my Z2 to get the turnstile wires flush with the foam? So they dont stick out.
Old Mar 09, 2012, 12:18 PM
zkilzz is offline
Joined Sep 2011
Can I have my turnstile antena like this? Im worried since it goes ontop of the carbon rod? Check blue lines for turnstile location. Should i use another antenna?
Old Mar 09, 2012, 10:51 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
That's fine. The rod won't bother it.
-Alex
Old Mar 25, 2012, 10:39 PM
Shadrack is offline
Find More Posts by Shadrack
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
When you say lay your transmitter antenna flat, to you mean pointed straight away from you vs being pointed up, or do you mean turned to the side?
A little confused.
Shadrack is offline Find More Posts by Shadrack
Old Mar 25, 2012, 11:11 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Turned to the side.
Old Mar 26, 2012, 12:06 AM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
Hate to ask stupid question, but are the antenna on uhf not a whip style of antenna that don't have a hinge or rotation to turn them sideways?
Won't it be uncomfortable to hold your radio at that angle?
Old Mar 26, 2012, 03:26 AM
pyrojets is offline
Find More Posts by pyrojets
Joined Apr 2011
Attempt at the turnstile UHF RX antenna
pyrojets is offline Find More Posts by pyrojets
Old Mar 26, 2012, 06:24 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
^Looks good to me. Pretty simple, isn't it?
-Alex
Old Mar 26, 2012, 06:25 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Most people would turn their bodies sideways instead of just the radio.
-Alex
Old Mar 26, 2012, 07:02 AM
pyrojets is offline
Joined Apr 2011
-Alex
Compared to the cloverleaf, it is far much easier. Shall try it out tomorrow. Thank you for the great tutorial.
Just to clarify some questions, picture speaks a thousand words.
Old Mar 26, 2012, 10:34 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
^That works! A bit over the top on the stiffening of the turnstile, but not a problem if you can do it.
-Alex
Old Mar 30, 2012, 12:43 PM
Corocrumpler is offline
Find More Posts by Corocrumpler
Watch This!
Corocrumpler's Avatar
United States, LA, Washington
Joined Feb 2007
Bad idea. The element thickness is critical. The lengths are actually quite loose but you must use 20-24AWG wire.
-Alex
Hi Alex, again THANKS for sharing...
The video states 18-22AWG, your Quote is 20-24, which is correct? Because I was going to use wire that was right in the middle of the thickness range. You did state that element thickness is critical.. Or is the range really 18-24AWG?
Coro
KF5PAM
Corocrumpler is offline Find More Posts by Corocrumpler
Old Mar 30, 2012, 01:00 PM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
-Alex
Alex
If the wires are past the wing, is it ok to curve them a bit to make them fit or do they need to be perfectly aligned.
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV Equipment (FS/W) 8 Jul 22, 2011 03:55 PM
Mini-HowTo Build a performance antenna for your LRS radio IBCrazy FPV Talk 18 Apr 11, 2011 09:57 PM
Question UHF LRS Pro Antenna Question CageHound FPV Talk 4 Apr 04, 2010 09:47 AM
Discussion For Sale: Spektrum DX7 for use with UHF/LRS jeff1068 FPV Talk 0 Mar 31, 2010 07:24 PM
Discussion Scherrer UHF LRS x Futaba 12FG/R6014FS Cr_Conrado FPV Talk 2 Dec 20, 2009 07:35 AM
