Old Sep 26, 2011, 08:27 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
The coaxial cable can be any length you want. It's fairly easy to build a turnstile and they work great.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Oct 12, 2011, 07:19 PM
marcin.gala is offline
Find More Posts by marcin.gala
marcin.gala's Avatar
Joined Jun 2010
What is best AWG wire to build turnstile antenna ?
It can be silicone wire ?
marcin.gala is offline Find More Posts by marcin.gala
Old Oct 12, 2011, 10:51 PM
Kev.au is offline
Find More Posts by Kev.au
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
18-22 AWG, i've used the silicone wire from HobbyKing without any problems.
Cheers, Kev.
Kev.au is offline Find More Posts by Kev.au
Old Oct 13, 2011, 04:18 AM
mr..speed is offline
Find More Posts by mr..speed
mr..speed's Avatar
near Stgt/Germany
Joined Feb 2003
Could I use this antenna type for my 2.4GHz VTx ?
mr..speed is offline Find More Posts by mr..speed
Old Oct 13, 2011, 09:08 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I'm still developing the 2.4GHz version. Currently looking at 9.5dbic gain for it.
-Alex
Old Nov 09, 2011, 08:31 AM
max1 is offline
Find More Posts by max1
Team Basement RC
max1's Avatar
Toronto, Canada
Joined Jul 2004
Hi Alex. I love the antenna tutorials you have here, and I thank you for what you and others have taught me here.
I have already built a few of your antennas for my FPV systems and I love how much they have improved my video quality and range.
My question:
I have a 900mhz Video system, and have built Inverted Vee for my VTX and have been using HugeOnes Virvent for my VRX. I also jsut completed building Huge ones Turbine for my VRX, which I will try this weekend.
So: Can I use this turnstile for my VTX? It would have to be 910 Mhz.
I am curious about the math for this design, I cant figure how you got 6.75" and 5.85" for you 433Mhz system. The math is not that obvious. Is it that complicated? If it is, can you give me the numbers for a 910 system?(assuming it is worth doing?)
I plan on using 0.85mm wire, if that helps.
Cheers,
Max
max1 is offline Find More Posts by max1
Old Nov 09, 2011, 10:16 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
No. The circularity shifts across the Z-axis. Hugo and I are using it as part of an experimental antenna: the Crosshair.
Tutorial coming soon
-Alex
Old Feb 18, 2012, 09:00 AM
wootenelli is offline
Find More Posts by wootenelli
Michael W.
wootenelli's Avatar
United States, TN, Cleveland
Joined Nov 2011
Alex, I have an EZuhf system with diversity...would there be any benefit to using diversity if I am usingthis type of antenna? If yes, then should I keep a sanders style on the plane as well (Skywalker) in a different position? Or should I stick with the bunny ear set up I currently have? thanks ahead of time, and by the way, Our church in TN is considering a mens interest group to teach RC flying, as well as possibly helping point them toward FPV!
wootenelli is offline Find More Posts by wootenelli
Old Feb 20, 2012, 09:07 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Yes there is a benefit. Use the turnstile laid flat and the Sander style upright. You now have no way to lose polarization
_Alex
Old Feb 20, 2012, 03:27 PM
Michael W.
wootenelli's Avatar
Joined Nov 2011
_Alex
nice! I will give that a shot. thanks Alex, hope all is going well for you
Old Feb 21, 2012, 06:28 AM
Blue Chip is offline
Find More Posts by Blue Chip
Honey Badger
Blue Chip's Avatar
United States, FL
Joined Oct 2005
Assuming this antenna is the only one being used for 433 control - does anyone have any kind of testing on it at range?
I'm curious as to why most antennas need to be mounted vertically to maintain polarization - yet this one can be laid flat...
Blue Chip is offline Find More Posts by Blue Chip
Old Feb 21, 2012, 06:39 AM
Kev.au is offline
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
This out performed my stock DragonLink antenna during ground tests, i haven't tested it with ezUHF, but i will soon as i have a turnstile embedded into my ZII's right wing.
I have flown 3km above myself with zero problems and over 5km away.
Old Feb 25, 2012, 11:44 AM
flow303 is offline
Find More Posts by flow303
Joined Apr 2011
I must have done something really wrong because my turnstile antenna performed just a bit better than the tiny stock OpenLRS antenna. Had a Nagoya NA-711 on my TX. Used 20 AWG wire.
OpenLRS is two-way and I use this feature for telemetry. Mostly for getting alerts when packages fail to send/receive. Maybe stupid question but in combination with the two-way telemetry and the turnstile antenna - could that be causing the bad range?
flow303 is offline Find More Posts by flow303
Old Feb 25, 2012, 07:19 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
If you used a known good antenna and your range was bad, and then built a turnstile and the range didn't improve much, I would say the problem isn't the antenna. It could be noise floor, or perhaps the TX isn't putting out as much power as it is supposed to.
-Alex
Old Feb 25, 2012, 07:22 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
The beauty of dual polarization my friend You need to put your tX antenna flat and pointed out to the side (thus matching polarization and also giving full strength where you need it). The turnstile has no nulls and is polarized on 2 axes. Waves propagate with less loss when horizontally polarized rather than vertical. Thus you lay the turnstile flat and you have your TX antenna flat as well.
-Alex
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV Equipment (FS/W) 8 Jul 22, 2011 03:55 PM
Mini-HowTo Build a performance antenna for your LRS radio IBCrazy FPV Talk 18 Apr 11, 2011 09:57 PM
Question UHF LRS Pro Antenna Question CageHound FPV Talk 4 Apr 04, 2010 09:47 AM
Discussion For Sale: Spektrum DX7 for use with UHF/LRS jeff1068 FPV Talk 0 Mar 31, 2010 07:24 PM
Discussion Scherrer UHF LRS x Futaba 12FG/R6014FS Cr_Conrado FPV Talk 2 Dec 20, 2009 07:35 AM
