Old May 25, 2011, 09:48 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Hmm, how to describe this?
The turnstile works by reactive phase shift vectoring. This is a fancy way of saying that the elements "fire" at different time intervals. Imagine the tips of the antenna going hot in a rotational sequence. Nice and circular. Now imagine two side by side pairs going hot together instead. The resultant vector is linear. Changing the thickness of the wire disturbs the firing sequence and makes it look more like the second case.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old May 30, 2011, 07:04 AM
Pixturethis is offline
Find More Posts by Pixturethis
Pixturethis's Avatar
Wichita
Joined Dec 2008
How would this work on the Thomas system that has 2 antennas ? Would it give longer range than the 2 dipole antennas that come with the receiver ?
Thanks Marc
Pixturethis is offline Find More Posts by Pixturethis
Old May 30, 2011, 06:09 PM
Wichita
Joined Dec 2008
Here's a picture of it. Name: ImageUploadedByTapatalk1306796920.192661.jpg
Description:
Old May 30, 2011, 06:14 PM
i3dm is offline
Find More Posts by i3dm
RC pilot by soul
Israel
Joined Apr 2005
any pics of this antenna mounted on a Funjet ?
i3dm is offline Find More Posts by i3dm
Old May 30, 2011, 06:16 PM
Wichita
Joined Dec 2008
Sorry wrong thread.
Old May 31, 2011, 10:51 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Thanks Marc
It could. What the turnstile does is limit loss of signal due to random drop outs. While this often means longer range, that isn't necessarily the case all the time.
-Alex
Old Jun 01, 2011, 05:30 PM
Blue Chip is offline
Find More Posts by Blue Chip
Honey Badger
Blue Chip's Avatar
United States, FL
Joined Oct 2005
Alex -
Is there any issues with covering the Turnstile or the dipole 433 antenna wire with something like nyrod?
I would like to experiment with a couple of the antennas - but need the structural support of tubing....
Blue Chip is offline Find More Posts by Blue Chip
Old Jun 02, 2011, 06:29 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
You can cover the turnstile with little penalty. A standard dipole will react a bit worse, but not much. Just don't support it with anything metallic or carbon fiber.
-Alex
Old Jun 15, 2011, 09:43 PM
FabioBrazil is offline
Find More Posts by FabioBrazil
Joined Mar 2009
Hi Alex, once again thanks for sharing your knoledge with us
The turnstyle goes horizontal on the plane, do I have to lay the Tx antena horizontal too ? or it is fireproof to polarization missmatch?
See Ya
FabioBrazil is offline Find More Posts by FabioBrazil
Old Jun 16, 2011, 12:00 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Yes, your TX antenna needs to be flat too. Horizontal polarization is better for distance anyway
-Alex
Old Jun 16, 2011, 03:00 PM
airbagit13 is offline
Find More Posts by airbagit13
Plane Destroyer / Life Enjoyer
airbagit13's Avatar
Miami, FL
Joined May 2009
O.o Glad I read this, I was going to use a Turnstile Antenna on my dragon link RX laying horizontally. For my VTX I was going to use a bluebeam SPW antenna if I can figure out how to mount it properly, which I don't think I will be able to do. If I can't i will be using a Vee antenna, so you are saying that I am going to have to mount my Vee antenna horizontally as well?
airbagit13 is offline Find More Posts by airbagit13
Old Aug 21, 2011, 05:16 PM
i3dm is offline
RC pilot by soul
Israel
Joined Apr 2005
I built a turnstile for my Funjet and its a little too big - what will happen if i shorten the elements to about 80% length ?
Old Aug 22, 2011, 02:45 PM
doggit is offline
Find More Posts by doggit
doggit's Avatar
northenden, manchester, england
Joined May 2009
i have just made a turnstile, but not sure if i have made it well enough, is there any way of testing it, other than flying with it ?
carl
doggit is offline Find More Posts by doggit
Old Aug 22, 2011, 04:17 PM
crash821 is offline
Find More Posts by crash821
Huntsville, AL
Joined Nov 2009
It won't work. The length is determined by 1/4 wavelength calculations. Changing the length changes the frequency it's tuned to. Making it 20% shorter would move it from being tuned to 433mhz to ~541mhz.
crash821 is offline Find More Posts by crash821
Old Sep 25, 2011, 07:24 PM
MOdesigner is offline
Find More Posts by MOdesigner
MOdesigner's Avatar
USA, MO, Smithville
Joined Oct 2008
Mod DL dipole
I would like to mod my original DL 1/2 wave dipole into a turnsile if possible. I dont know what the coax oHm is and I watched the video twice and didn't see Alex mention a specific length for the coax.
Respectfully posted,
Scott
MOdesigner is offline Find More Posts by MOdesigner
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV Equipment (FS/W) 8 Jul 22, 2011 03:55 PM
Mini-HowTo Build a performance antenna for your LRS radio IBCrazy FPV Talk 18 Apr 11, 2011 09:57 PM
Question UHF LRS Pro Antenna Question CageHound FPV Talk 4 Apr 04, 2010 09:47 AM
Discussion For Sale: Spektrum DX7 for use with UHF/LRS jeff1068 FPV Talk 0 Mar 31, 2010 07:24 PM
Discussion Scherrer UHF LRS x Futaba 12FG/R6014FS Cr_Conrado FPV Talk 2 Dec 20, 2009 07:35 AM
