Old Apr 02, 2011, 07:48 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
New Product
Turnstile UHF RX antenna for your LRS
If you own a flying wing, you know what a pain it is to find a place to mount your LRS antenna upright for proper polarization. Now you don't have to. The turnstile antenna is a dual polarized antenna that is designed to lay flat where it is convenient.
I designed this antenna specifically for flying wing pilots, but it works just fine for any airplane. Mount the antenna flat on the bottom of the wing. The radiation pattern has no holes in it and is almost a perfect sphere. I use this with my Dragonlink, but it will work with any UHF radio system. While I tend to use it as an RX antenna, it also works as a TX antenna.
Admittedly, I need to give credit to MR. RC-CAM for this one. He challenged some of us on the RC-CAM forum to figure it out and build one.... So I did It uses the reactive impedances to match a proper 50 ohm load hence the mist matched leg lengths.
You can buy one from Video Aerial Systems
Or of course, you can build your own. But I won't force you guys to figure out the math. Instead, here's a video to show you how it's done:
Build IBCrazy's 433MHz Turnstile antenna for FPV (6 min 5 sec)
Why am I giving away the details? Because I want to, that's why I encourage you who have fair soldering skill to try one.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Apr 02, 2011, 07:53 PM
Po73 is offline
Find More Posts by Po73
Thou who know not
Po73's Avatar
USA, MI, Mason
Joined Jul 2010
Have you done a range test in the air yet? I've been contemplating using these for both video and rc on the flat side on a raidian.
Po73 is offline Find More Posts by Po73
Old Apr 09, 2011, 11:12 AM
Kev.au is offline
Find More Posts by Kev.au
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
Thanks for offering this design, Alex.
Cheers, Kev.
Kev.au is offline Find More Posts by Kev.au
Old May 21, 2011, 06:38 AM
Kev.au is offline
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
And one mounted on my bros quad.
Cheers, Kev.
Old May 21, 2011, 09:43 AM
sawman is offline
Find More Posts by sawman
Air Crash Expert
sawman's Avatar
Louisiana
Joined Oct 2005
Alex,
I have copper foil with adhesive backing. It is 3/4 inch in width. Guess you know where I'm going with this.
What effect does the width have on the element lengths ? Also curious about what kind of gain to expect.
sawman is offline Find More Posts by sawman
Old May 22, 2011, 07:27 AM
Blue Chip is offline
Find More Posts by Blue Chip
Honey Badger
Blue Chip's Avatar
United States, FL
Joined Oct 2005
Will putting a piece of ny-rod over the elements change anything?
Blue Chip is offline Find More Posts by Blue Chip
Old May 22, 2011, 08:07 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by sawman View Post
Alex,
Bad idea. The element thickness is critical. The lengths are actually quite loose but you must use 20-24AWG wire.
-Alex
Old May 23, 2011, 05:44 AM
powermec is offline
Find More Posts by powermec
FRANCE
Joined Oct 2005
Hello !
I can install the antenna along the aluminum arms of a MK?
I think about wiring the metallics arms with battery ground.Good idea or it's useless?
powermec is offline Find More Posts by powermec
Old May 23, 2011, 07:30 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I would not do that. The aluminum will mutually couple with the antenna similar to how a Yagi antenna works. However, in the case of the booms, it will most certainly be a bad thing...
-Alex
Old May 23, 2011, 09:21 AM
sawman is offline
Air Crash Expert
sawman's Avatar
Louisiana
Joined Oct 2005
-Alex
Thanks .
Old May 23, 2011, 11:32 AM
powermec is offline
FRANCE
Joined Oct 2005
-Alex
Thanks Alex !
Ok ,it's not recommended to use turnstile antenna on quadrocopter with metallic frame ,stock antenna is preferable?
Old May 23, 2011, 12:28 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
The stock antenna won't do any better on a metal frame. The aluminum will react just the same. This is a case where 2.4GHz would be the best choice for control.
-Alex
Old May 23, 2011, 12:59 PM
i3dm is offline
Find More Posts by i3dm
RC pilot by soul
Israel
Joined Apr 2005
Alex,
Will 18 AWG wire off a burnt computer PSU work well ?
i3dm is offline Find More Posts by i3dm
Old May 23, 2011, 02:36 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
It would do ok. It would be a little out of circularity, but you'll be ok for most purposes.
-Alex
Old May 23, 2011, 02:39 PM
i3dm is offline
RC pilot by soul
Israel
Joined Apr 2005
What does that mean in simple terms ?
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV Equipment (FS/W) 8 Jul 22, 2011 03:55 PM
Mini-HowTo Build a performance antenna for your LRS radio IBCrazy FPV Talk 18 Apr 11, 2011 09:57 PM
Question UHF LRS Pro Antenna Question CageHound FPV Talk 4 Apr 04, 2010 09:47 AM
Discussion For Sale: Spektrum DX7 for use with UHF/LRS jeff1068 FPV Talk 0 Mar 31, 2010 07:24 PM
Discussion Scherrer UHF LRS x Futaba 12FG/R6014FS Cr_Conrado FPV Talk 2 Dec 20, 2009 07:35 AM
