Joined May 2011
In response to a request from someone trying to adapt my interrupt-driven packet transmitter, I've re-written the code to use only standard Arduino functions and be call-able on-demand with "sendPacket(yaw,pitch,throttle,trim)". The function returns the variable delay in milliseconds needed to send 10 packets per second (which can be ignored).
The code can be found at: http://sites.google.com/site/spirixcode/code/kodek.txt The loop contains example code to drive the throttle from 0 to 127 and back down again. PS: Although my helicopter seems happy with the pulse trains that I'm generating, I don't have an oscilloscope so I can't actually confirm that the output of my code is what it should be. If anyone has the time and inclination to sample the output and let me know the results, it would be greatly appreciated
Hey guys, could you pop by the iPhone IR controler thread, I'm not having much luck in trying to build hardware for the existing app.
Hey nemoskull, with the AVR remote idea, do you think it could take a PPM input rather than using the S107 Tx casing? reason being it could then be used with a real hobby Tx as a mdule or it could be used with the iPhly iPhone app. oh hows you micro sub? |
Joined Oct 2011
Hi guys
I have a couple of videos that may interest you. In the first one I'm flying the IR Helicopter in AutoPilot mode (the auto pilot controls the altitude):
The second one demonstrates how I decoded the IR protocol using the USB IR Toy v1:
It also has a link to the program. |
Joined Mar 2012
Edit: here's a post about it complete with working code: http://www.abarry.org/likelytobeforgotten/?p=55 I was working on a S107 with the same protocol -- this one has 3 channels (A, B, C) and has a 30 bit protocol instead of the 32 bit one. It also did not come with a USB charger but came only with the controller charger. There are a few things that are different about it: 1) It has a checksum. The bits labelled 21-24 in your table are a bitwise XOR of 4-bit words with the two zeros appended to the end of the bitstring. Thus you can compute the checksum for the first packet: 1000 0000 1000 1100 0000 1111 1111 11 with: 1000 ^ 0000 ^ 1000 ^ 1100 ^ 0000 ^ 1111 ^ 1100 = 1111 and for the second packet: 1000 0000 0011 1001 0000 0001 1111 11 with 1000 ^ 0000 ^ 0011 ^ 1001 ^ 0000 ^ 1111 ^ 1100 = 0001 2) The delays between packets are different for the different channels: Channel A: 136500 us Channel B: 105200 us Channel C: 168700 us These numbers are approximate but they are good enough for the helicopter to fly with (I've tested all 3 channels). 3) As you have said, the bits are as follows: CC00 PPPP TTTT TTTT YYYY XXXX RRRR RR C - channel P - pitch T - throttle Y - yaw X - checksum R - trim 4) The bits in the throttle, pitch, and yaw are reversed, so for throttle bit 16 is the most significant bit with bit 9 being the least significant for throttle. 5) Bit 20 is the direction bit for yaw and then bits 19-17 (aka reversed) are the speed bits. So for full yaw in one direction you do 1111 and for full yaw in the other direction you do 1110 6) Bit 8 is the direction bit for pitch with the speed bits being just like yaw. 7) The trim bits are probably reversed or something like that too but I just set them to 0 and didn't worry. Here's my relevant code for an Arduino. Note that my array starts at 0 so all my indexes are shifted down by one from your table: // channel A B or C // A is 10 with 136500us packet delay // B is 01 with 105200us packet delay // C is 11 with 168700us packet delay if (channel == 0) { packetData[0] = 1; packetData[1] = 0; channelDelayValue = 136500; } else if (channel == 1) { packetData[0] = 0; packetData[1] = 1; channelDelayValue = 105200; } else { packetData[0] = 1; packetData[1] = 1; channelDelayValue = 168700; } packetData[2] = 0; packetData[3] = 0; // pitch packetData[7] = (pitch & 0b1000) >> 3; // direction bit if (pitch < 8) { pitch = 8 - pitch; } packetData[6] = (pitch & 0b0100) >> 2; // others are speed bits packetData[5] = (pitch & 0b0010) >> 1; packetData[4] = (pitch & 0b0001); // throttle // bits are reversed in the throttle command packetData[15] = (throttle & 0b10000000) >> 7; packetData[14] = (throttle & 0b01000000) >> 6; packetData[13] = (throttle & 0b00100000) >> 5; packetData[12] = (throttle & 0b00010000) >> 4; packetData[11] = (throttle & 0b00001000) >> 3; packetData[10] = (throttle & 0b00000100) >> 2; packetData[9] = (throttle & 0b00000010) >> 1; packetData[8] = (throttle & 0b00000001); // yaw packetData[19] = (yaw & 0b1000) >> 3; // direction bit if (yaw < 8) { yaw = 8 - yaw; } packetData[18] = (yaw & 0b0100) >> 2; packetData[17] = (yaw & 0b0010) >> 1; packetData[16] = (yaw & 0b0001); // these 4 bits are the checksum, so make sure they // are 0s so they don't change the XOR later on packetData[20] = 0; packetData[21] = 0; packetData[22] = 0; packetData[23] = 0; // yaw trim / yaw adjust (the little dial on the controller) // 6 bits packetData[24] = 0; packetData[25] = 0; packetData[26] = 0; packetData[27] = 0; packetData[28] = 0; packetData[29] = 0; // these bits are never sent but we do the checksum // computation in 4-bit chunks, with the trailing two // bits set to zero, so we set them to zero here to make // the checksum a bit easier to compute packetData[30] = 0; packetData[31] = 0; int i; int checksum[10]; checksum[0] = 0; checksum[1] = 0; checksum[2] = 0; checksum[3] = 0; // compute checksum -- bitwise XOR of 4-bit chuncks // with two zeros padding the *end* of the last two bits for (i=0; i<32; i+=4) { // XOR checksum[0] = packetData[i + 0] ^ checksum[0]; checksum[1] = packetData[i + 1] ^ checksum[1]; checksum[2] = packetData[i + 2] ^ checksum[2]; checksum[3] = packetData[i + 3] ^ checksum[3]; } // now set bits 21-24 (array values 20-23) to the checksum packetData[20] = checksum[0]; packetData[21] = checksum[1]; packetData[22] = checksum[2]; packetData[23] = checksum[3]; int bitsum = 0; for (i=0; i<30; i++) { if (packetData[i] == 1) { bitsum ++; pulseNum = 32; } else { pulseNum = 16; } // flash pulseNum times while(pulseNum--) { digitalWrite(LED,LOW); delayMicroseconds(9); digitalWrite(LED,HIGH); delayMicroseconds(8); } delayMicroseconds(300); } // channel A B or C // A is 10 with 136500us packet delay // B is 01 with 105200us packet delay // C is 11 with 168700us packet delay // we compute the delay and return it to a function that will delay this amout return((channelDelayValue - bitsum * 272)/1000); // in ms. |
Joined Mar 2013
amieres, you used your software to read the USB Infrared Toy? Is there any other graphic software you indicate?
andybarry, this table is valid for this model sold in DX? http://dx.com/p/usb-rechargeable-3-c...r-remote-32694 I'll start looking for that protocol and I'm doing some lifting. I'll decode the protocol and compare it with that table. Thank you. -- MhagnumDw |
| Thread Tools | |
| Discussion Coaxial IR protocol (SH, Syma, etc...) | Darkstar2000 | Coaxial Helicopters | 246 | Jun 11, 2012 10:28 AM |
| Discussion S107 IR Protocol and Schematic | campeck | Coaxial Helicopters | 2 | Dec 28, 2010 06:32 PM |
| Discussion Syma s107 swaying | Pitnut | Micro Helis | 2 | Sep 16, 2010 08:31 AM |
| Question Syma s107 swaying | Pitnut | Coaxial Helicopters | 1 | Sep 01, 2010 05:43 PM |
| Discussion Syma s107 sway | Pitnut | Coaxial Helicopters | 1 | Sep 01, 2010 04:28 AM |
