Thanks to Thunder's excellent picture of the AW fan formers, I should be able to make some progress quickly in the fan installation department ...
The elevator and aileron servos are finally in and tested. The elevator servos are mounted asymmetrically to avoid the use of mixers or mixing functions in the transmitter. A single y-connector is used in the tail, as well as one for the ailerons. . |
Latest blog entry: BAe Hawk 90mm EDF
These brakes are hydraulic, and require a specific type and shape of wheel inset. Not sure I will be using these particular designs; well made and lightweight but not necessarily a good fit to the Robart rims & wheels ...
I've noticed that some hydraulic systems are starting to be offered. They will probably be easier to make work smoothly because the pressure variation will be more exact with fluid as opposed to air, but can you imagine the mess if you get a leak? Also normal brake fluid is very corossive and will remove paint. Could get ugly.
Latest blog entry: EDF, My First Six Years, mostly Pictures
Yes in principle hydraulic brakes should be much smoother because of the incompressibility of oil (some even use water, but does not seem a such a great idea to me since it evaporates).
I thought though this was more an internet flying kind of project, but then my friend Gregg F has oil brakes in a BVM Fury and he says they work fine. If Gregg says they work, then they work ! I suppose once you put the oil in, you are done for life... They work quite differently from the BVM and Robart Uni air (pneumatic) brakes, which make an o-ring expand against the rim. There when air pressure is released, the o-ring returns to it's previous state, hopefully unlocking the brake. On the other hand the above oil (hydraulic) disk brakes rely on the servo activated piston to push in, and then pull back the disk away from the wheel. I noticed a number of things: 1) The brakes are made by UMS where you can see what a full system entails , http://www.umstech.in/view_products....ssories&page=3 2) They say on RCU 3-in-1 oil, or jack oil, works fine (I suppose it's ok with the o-rings). 3) The plunger can be made very simply with an insulin syringe, or use the smc one with a strong digital servo. Each brake has an air purge valve. Filling the brake circuit sounds like fun. 4) I am not sure what wheels fit these brakes, besides the UMS 90mm ones. It's not clear to me that the Robart aluminum hubs will work. The brakes apparently need 55mm rims. 5) I am thinking of just ordering a pair of UMS alu hub 90mm wheels, so I don't have to figure out how to fit the wheels to the brakes. 6) All of the above makes the Robart Unibrakes look very attractive in spite of the price .. |
Three and one oil would be much more user friendly than automotive type brake fluid. That would be nice to have proportional brakes instead of the almost on/off function of the air brakes. You also have plenty of room inside the plane to be able to access the system if you ever needed to.
Hutch, thanks for posting the Me-262 twin seater pictures ! Outstanding
![]() Regarding the oil, there's probably a better choice but I don't know ... Gregg F was telling me that the larger Skymaster ones use such a system ... will have to check when I find the time. |
3in1 is the same as sewing machine oil. Thin light viscosity.
Motorcycle fork oil is excellent stuff, the thinnest used to be 5 weight but they have 0 weight nowadays. |
Latest blog entry: Durafly Vampire 70mm
The motors have now been installed in the fans.
There's four solid screws at the front, secured with silicone, and four supports glued in with silicone at the back. All the shaft adapter screws and nuts have been loctite'd. . |
I was also able to get a bit of work done on the motor/fan installation.
The fans fit perfectly in the nacelle opening, with no play. The front of the nacelle looks really solid, so that would be half of the motor mount. The second half is a former that supports the fan assembly at the back. Then on the sides there will be two additional supports. Finally two ply braces will go from the rear former to the wing mount. . |
Here's btw a picture of the wing mounts for folks that did not get a set with the kit,
Amazon.de also delivered today a very nice book on the Me-262, with lots of color & bw pictures
| Thread Tools | |
| Build Log Skymasters F-4E Phantom As Twin EDF Project | FlyBoyTha1 | Electric Ducted Fan Jet Talk | 321 | Mar 29, 2013 11:44 AM |
| Build Log Twin 90mm EDF F-22 50" span 72" lenth | Hover or die | Scratchbuilt EDFs | 58 | Jan 21, 2013 09:03 AM |
| Discussion Boeing 777-200LR Twin 90mm project | NickM91 | Scratchbuilt EDFs | 20 | Jul 10, 2011 08:40 AM |
| Discussion Nitroplanes Honda 420 EDF, twin 90mm | Knife Liddle | Electric Ducted Fan Jet Talk | 17 | Mar 14, 2011 07:59 PM |
| Build Log Eagle project (twin 90mm) | Kevin Cox | Electric Ducted Fan Jet Talk | 42 | May 25, 2006 10:40 PM |
