This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Old Jun 02, 2011, 06:58 AM
bidule is offline
Find More Posts by bidule
jean-claude Terrettaz
bidule's Avatar
Carp, Ontario, Canada
Joined Mar 2000
Great project Herb. As usual. If you need a doors sequencer let me know.
J-C
bidule is offline Find More Posts by bidule
Old Jun 03, 2011, 12:00 AM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Herb, I'm enjoying your build. The 262 is one of my favorite jets of all time. Looks like a great flier.
Knife Liddle is online now Find More Posts by Knife Liddle
Old Jun 03, 2011, 11:24 AM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Thanks J-C and K-N
Although there's quite a bit of work involved in getting this thing ready, it is a very well engineered, strong (and very light!!) airframe.
I was able to get some work done on the nacelle mounts. They will carry quite a bit of weight and thrust, in spite of the fact that I am going for the lightest possible fan/motor setup (440g per nacelle).
The nacelles have to be mounted very rigidly for at least five reasons : a) overall motor & fan weight, b) applied thrust @ 2500W, c) motor and fan vibration , d) nacelle rigidity & issues related to fan noise, and e) twin fan resonance.
For these reasons I used two large stainless steel bolts with ply & g10 fiberglass mounts at the front, and just ply at the back.
Herb is offline Find More Posts by Herb
Old Jun 03, 2011, 11:25 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The wing mounts require two lightweight ply plates front and back, that will be next.
Old Jun 03, 2011, 11:36 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The Robart airvalve has been tested as a unit - and seems to work fine, hopefully there shouldn't be any problem there ... more pressure test later.
I will think about the pneumatic brake lines later.
Old Jun 03, 2011, 11:40 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The canopy frame was slowly and patiently cut out with a dremel ... Fritz can now see what's outside
Old Jun 03, 2011, 11:42 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
I measured all the required linkage lengths, and started to install the various servos mounts, which had to be manufactured out of ply.
Old Jun 03, 2011, 11:47 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The Me-262 is ready to be put on it's feet to check the length of the nosgear strut one more time.
After the nose strut length has been found to be ok (as it seems), it will be tapped for some (4) set screws.
Old Jun 03, 2011, 11:49 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
With the nacelles & wheels on, and the canopy cut out, it is starting to look more like an Me-262 !
Old Jun 03, 2011, 12:30 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
... ordered fans and motors - should be here in less than a week
Old Jun 03, 2011, 11:38 PM
thunder1 is online now
Find More Posts by thunder1
College Park, MD
Joined Sep 2002
That's one sweet bird! My fans are still a ways off...
What are you planning for the cockpit? I sure wish inZpan made a 1/6th Me-262 insturment panel.
thunder1 is online now Find More Posts by thunder1
Old Jun 04, 2011, 08:18 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
I will do the cockpit the old fashioned way ... scratch-built, after the Me-262 has flown
It would be cool to have a canopy that can be opened, but it seems more an internet flying project, the whole canopy would become just too delicate for everyday flying.
In any case as I said I will start worrying about canopies and cockpits after the maiden.
Old Jun 06, 2011, 04:58 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Spent a few evenings making various ply servo mounts,
Old Jun 06, 2011, 05:01 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Hopefully a small airtank will be enough just for the brakes (on a separate air circuit),
Old Jun 06, 2011, 05:03 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Fans are twin HET-700 90mm fan shrouds (40mm i.d.) with WeMoTec Pro rotors,
Build Log Skymasters F-4E Phantom As Twin EDF Project FlyBoyTha1 Electric Ducted Fan Jet Talk 321 Mar 29, 2013 11:44 AM
Build Log Twin 90mm EDF F-22 50" span 72" lenth Hover or die Scratchbuilt EDFs 58 Jan 21, 2013 09:03 AM
Discussion Boeing 777-200LR Twin 90mm project NickM91 Scratchbuilt EDFs 20 Jul 10, 2011 08:40 AM
Discussion Nitroplanes Honda 420 EDF, twin 90mm Knife Liddle Electric Ducted Fan Jet Talk 17 Mar 14, 2011 07:59 PM
Build Log Eagle project (twin 90mm) Kevin Cox Electric Ducted Fan Jet Talk 42 May 25, 2006 10:40 PM
