Me-262 A-1a (Twin 90mm) by Airworld
Started to look at the various components last week
...This thread in German It's a big all fg-airex-sandwich carbon composite airframe for twin 90mm fans, made by Airworld Germany; http://www.airworld.de/Englisch/Index.htm the rest of the components, well you can guess where most of them (esc, batts) will come from ... Edit : Me-262 flyby added March 2012 :
Here's a short video I took of the original last June 2010:
Latest blog entry: BAe Hawk 90mm EDF
These new TS EDF motors look interesting, they supposedly run very cool :
http://www.tenshock-motors.de/Brushl...tenlos-Motoren . |
Hello Herb.
Gorgeous ME262! detachable nacelles and scale gear! NICE! Pricey boat motors though! Figured you'd steer clear of those types..... and not because of the price! ![]() Have you settled on 6S,9S or 12S? Maybe I'm wrong but 6S seems low to me for the size of that jet. Cheers! Bruce |
Latest blog entry: Durafly Vampire 70mm
Hi Bruce ! Fan-wise the usual suspects
although I have not decided yet ...Most likely 8S (2x4S) - 9S (3x3S) per motor. |
cool...
Estimate for AUW? I maidened my new little F9F sunday and talked w/ Hung, He read something on rcg about the 262 weighing 20-25lbs but i think its closer to 13lbs. Even the turbine version lists at 15.5 maybe it was a different brand he saw... |
It is quite light ! That's why I decided to go ahead and get one
![]() You might be referring to another similar sized model out there, I think it was us-made and it's a real lead sled at 30+ lbs. The Airworld Me-262 is in a completely different class, no comparison imo. A high performance all-composite airframe. wingspan 200 cm = 80 '' length 175 cm = 70'' Original Me-262 ws = 12.5m, length = 10.58m Thus the scale is approximately 6.2:1 The empty airframe weights are as follows: fuse 32.1 oz wing 47.6 oz nacelle (each) 9.1 oz two elevators 8.2 oz --------------------- empty airframe weight = 106.1 oz = 6.6 lbs = 3.01 kg Very light, esp. the fuselage. The wing is one piece, and very strong (turbine grade). Estimated weight rtf should be in the 14-15 lbs range ![]() . |
Bare aiframe as in the pic below, 106 oz
Gel-coated silver painted-in-the mold fiberglass (not polyester), with lots of carbon fiber reinforcements in the wing, fuselage, elevators and nacelles. Specifically: fiberglass fuseleage and nacelles, fiberglass-airex-fiberglass sandwich (wing), and fiberglass-balsa-fiberglass sandwich (elevators). . |
close up
An Me-262 nacelles fits nicely in one of my airplane stands
Nacelles & intakes
Good grief that things huge!:eek
5"10 length, 6'8" wingspan! You need a bigger SUV! ![]() even with the wing off!LOL |
She sure is big ! The 2m wing just barely fits lenghtwise in my suv
![]() Uncle Joe (Joe Balaban) should be awarded a major prize for flying this thing on nicds @ 20 lbs & 1800W total ... I am collecting some scale documentation & possible paint schemes, http://hyperscale.com/index_air_messerschmitt.htm http://www.modelingmadness.com/kitindex/kitindexmno.htm http://www.stormbirds.com/warbirds/index.html http://www.militaryaircraft.de/pictu...62/Me-262.html http://www.me-262.de/home/home.php |
| Thread Tools | |
| Build Log Skymasters F-4E Phantom As Twin EDF Project | FlyBoyTha1 | Electric Ducted Fan Jet Talk | 321 | Mar 29, 2013 11:44 AM |
| Build Log Twin 90mm EDF F-22 50" span 72" lenth | Hover or die | Scratchbuilt EDFs | 58 | Jan 21, 2013 09:03 AM |
| Discussion Boeing 777-200LR Twin 90mm project | NickM91 | Scratchbuilt EDFs | 20 | Jul 10, 2011 08:40 AM |
| Discussion Nitroplanes Honda 420 EDF, twin 90mm | Knife Liddle | Electric Ducted Fan Jet Talk | 17 | Mar 14, 2011 07:59 PM |
| Build Log Eagle project (twin 90mm) | Kevin Cox | Electric Ducted Fan Jet Talk | 42 | May 25, 2006 10:40 PM |
