Old Apr 02, 2011, 10:43 AM
FlyBoyTha1 is offline
Find More Posts by FlyBoyTha1
FlyBoyTha1's Avatar
The Greater Bay Area
Joined Sep 2008
Question
XPS Pro Fan Esc Settings For CC120HV - CC160HV Questions:
Anybody know the XPS Pro Fan Settings For Using A CC120HV CC120HV - CC160HV ?
Thanks!
FlyBoyTha1 is offline Find More Posts by FlyBoyTha1
Old Apr 02, 2011, 12:18 PM
bruff is offline
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Used medium setting and outrunner mode. Best check with Scott after this weekend.
Bob
bruff is offline Find More Posts by bruff
Old Apr 02, 2011, 03:27 PM
FlyBoyTha1's Avatar
Joined Sep 2008
Bob
Thanks Bob
Old Apr 02, 2011, 06:12 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i was told not to use outrunner mode,that is for big prop motors with low kv.
AIR SALLY is offline Find More Posts by AIR SALLY
Old Apr 02, 2011, 06:22 PM
Arngeir Blakseth is offline
Find More Posts by Arngeir Blakseth
Senior Member
Arngeir Blakseth's Avatar
Molde, Norway
Joined Jan 2001
Yep, same I was told about the old version with the Big Screamer. I ended up at 5 degrees timing, the recommendation was 0 and inrunner mode, but I had to add some timing to prevent sync loss/stuttering above 2/3 power.
Arngeir Blakseth is offline Find More Posts by Arngeir Blakseth
Old Apr 02, 2011, 09:50 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
bob vincent set mine up for the LS/xps motor ...and the XPS pro runs perfect on the same settings...i just dont remember what numbers he put in
Old Apr 03, 2011, 05:18 AM
FlyBoyTha1's Avatar
Joined Sep 2008
Sound like i have a product with no diretion on the right esc settings
You can't even google the settings
Old Apr 03, 2011, 05:40 AM
DominicM is offline
Find More Posts by DominicM
DominicM
DominicM's Avatar
Fleet, Hampshire, UK.
Joined May 2003
While we are on the subject of ESC setup for this fan would be good to know what it should be for the Hacker MasterSpin 170A ESC.
DominicM is offline Find More Posts by DominicM
Old Apr 03, 2011, 06:02 AM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
HV controllers - 0 degrees, outrunner mode
Spin controllers - 30 degrees, 8 poles
JimDrew is offline Find More Posts by JimDrew
Old Apr 03, 2011, 06:12 AM
FlyBoyTha1's Avatar
Joined Sep 2008
Thanks Jim,
How about the other settings as it would be nice for others to see if any other settings should be changed also for the CCHV Esc's.
Throttle Response: High, Med, Low?
Motor Start up: High, Med, Low?
Motor Timing: High, Med, Low?
Cutoff Type: Hard Cutoff, Soft Cutoff?
Also what kind of numbers are expected on 12's 45c packs on this XPS Pro fan.
Are the numbers posted on your site numbers with 65C packs only?
Old Apr 03, 2011, 04:05 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
That's all personal preference.
Performance varies dramatically with different batteries. Our numbers are using our 65C batteries.
Discussion 2801 Pro settings for V120D02 gmbnj Micro Helis 14 Dec 20, 2011 08:19 AM
Discussion Vertigo "Rebel" mods for XPS Dynamax fan install bruff Electric Ducted Fan Jet Talk 6 Mar 13, 2011 11:11 PM
Discussion 16S ESC for XPS DYNAMAX EXTREME PRO Brutikus Electric Ducted Fan Jet Talk 33 Feb 10, 2011 05:13 PM
Help! 100mm Sapac Fan ESC Settings??? Kevin Greene Electric Ducted Fan Jet Talk 8 Dec 02, 2010 04:27 PM
