Apr 01, 2011, 11:48 PM
United States, CA, Costa Mesa
Joined Jun 2004
Hacker X-7 Pro ESC Question
Do any of you speak Hacker X Pro?
The power system is a brand new Hacker X-7 Pro ESC, new Hacker A10-9L, and 2S LiPo packs.
When I first powered up the system I forgot to reverse the throttle channel so I unintentionally powered up at full throttle. The motor didn't start but the ESC apparently went into programming mode before I figured out what was going on. Unfortunately I didn't pay any attention to the beeps so I have no idea what (if anything) I changed when I finally pushed the stick to the top and the ESC armed. Of course I fixed the throttle problem and the power system seems to work normally, but I can't help but think that I did some "throttle-stick programming" during that initial power-up.
When I plug in a battery now (throttle off) the plane makes one low-pitched beep followed by one high-pitched beep and that's it. Can anyone tell me what this means? What kind of beeps do they make when you power 'em up in the default "LiPo-Autodetect" mode with two cells?
Thanks!
Pete
