Old Apr 01, 2011, 11:43 PM
norbert_jones is offline
Find More Posts by norbert_jones
Joined Sep 2007
Can't balance Nano-tech 45C/90C lipos with BC6 charger
Hey guys,
I have two 2200 mAh three cell Nano-techs rated at 45C/90C.
I can't get my Bantam BC6 charger to do a proper balance charge on either battery.
At time of writing the charger has been trying to balance one of the batteries for 4 hours now. For the last couple of cycles I've just given up and manual terminated the charge. The charger usually shows each cell voltage something like: 4.17; 4.21; 4.19
I'm fairly sure it's not a problem with the charger as the charger will balance an old 20C Rhino lipo perfectly.
So what's the deal?
Are the cells just ridiculously mismatched?
Is the low internal resistance of these higher C-rated cells confusing the charger?
NJ.
norbert_jones is offline Find More Posts by norbert_jones
Old Apr 02, 2011, 04:33 AM
lipoflyer is offline
Find More Posts by lipoflyer
lipoflyer's Avatar
Australia
Joined Nov 2010
I take it that you dont balance charge regularly? You could try and draw down the offending cell?
lipoflyer is offline Find More Posts by lipoflyer
Old Apr 02, 2011, 06:49 AM
Joined Sep 2007
On the contrary, every charge has been set as a balance charge (attempted at least).
NJ.
Old Apr 02, 2011, 07:26 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
I showed with graph and pointed out with text that my 45C Nano did not have highly matched cells in it and as usual many here once again just accused me of running down HK LiPolys as I am such a Thumder Power supporter. Look in the battery graph vault. I test ,many LiPolys and post the results obtained.
http://www.rcgroups.com/forums/showthread.php?t=1302258
Wayne Giles also recently tested some Nanos , search for his results.
Sold 5 Nano-Tech 3s2200 Lipos 45C NEW JeremySoCal Aircraft - Electric - Batteries & Chargers (FS/W) 5 Feb 15, 2011 11:46 AM
Discussion Nano Tech 90C starter FAIL! Mikarro Batteries and Chargers 5 Oct 29, 2010 01:36 PM
Sold Never used Turnigy Nano-Tech 4000 3S 45C Flyextreme Aircraft - Electric - Batteries & Chargers (FS/W) 2 Oct 05, 2010 12:40 PM
Wanted Turnigy nano-tech 2200mah 3S 45~90C Lipo Pack NIB unlvace Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 03, 2010 07:42 PM
