Your mileage may vary but I cycled a TP Pro Power 45 2250 mnAh 300 times. Charged at 10A discharged at 40 amps. (17.7C) .
http://www.rcgroups.com/forums/showthread.php?t=1142882 |
United States, NJ, Frenchtown
Joined Mar 2003
Heliguys
You people are really tough on your cells. Most of you that I have talked to NORMALLY run at the burst rating for a lot of the flight. Just a fact of getting the vertical performance they want.
The fact that all are aging equally is good. Maybe yours were not the best ones in a production run ?? Maybe you fly with longer high amp drain than on the ground tests say ?? |
Joined Mar 2003
Normally as the C rating goes up..... The # of continous & burst cycles goes down.
So you going to a smaller & lighter should equal less cycles. There is just less material to deliver power. I would think the Helicopter Forums would really help you a lot more. They do try all combinations to get maximum number of lifts per dollar. |
El Cajon, CA, USA
Joined Feb 2001
I know there is endless discussion (much of it very very good) about what C ratings really mean and ways of standardizing the discussion. It just strikes me as so odd when I'm "pushing the envelope" by using smaller cells than anybody else and yet I'll be bursting at half of what the continuous rate is. I know I'll have reduced flight times and probablly reduced life cycles but it shouldn't be like 60% reduction in cycles right? I'd expect it to be a reduction of like 8-15% or something. I want those TP 3300 packs so bad to test my theories but I'm still gunshy from my TP Extreme V2's. They sucked really bad for lifecycles and even though the world is saying these new 45 and 65C batteries are different I'm still scared. I wouldn't be worried about it on a 45-60 dollar battery. It's the fact that I'll be buying 2-3 of these $180 dollar suckers. Sure do wish I'd have had the forsite to get in on that 25% off sale from a month ago..... |
Joined Mar 2003
Munch
Something else to consider about anything being produced in this LOOONG Depression. Companies are going to make stuff cheaper for the same price. REALLY TOUGH to know if you are buying the good old cells or newer stuff that is rated by the sales dept. Good luck. |
| Thread Tools | |
| Discussion High quality cheap building material. | Kimber | Dock Talk | 3 | Feb 12, 2011 09:27 PM |
| Sold For Sale -High Quality Motor Combo / Motor + ESC + Folding Propeller CHEAP | ALL American | Aircraft - Electric - Power Systems (FS/W) | 6 | Nov 23, 2010 08:31 AM |
| Sold Scorpio F6F Hellcat Large size High quality Foam/wood ARF | shschon | Aircraft - Electric - Airplanes (FS/W) | 0 | Mar 17, 2007 05:05 PM |
| Flat airfoils: slow vs. high speed, small vs. large | stjobs | Modeling Science | 15 | Oct 29, 2004 03:55 PM |
| High Kv small pinion vs low Kv large pinion? | Nicke | Power Systems | 13 | Oct 16, 2003 02:38 AM |
