Old Apr 01, 2011, 12:41 PM
sfluck is online now
Find More Posts by sfluck
Winterthur ZH, Switzerland
Joined Mar 2009
Phoenix Ice Lite 100 with Hacker A40-14s
Hi everyone
I have a question about how to setup the Hacker A40-14s with the Phoenix Ice Lite 100A ESC.
In the instructions of the motor it says
-recommended Timing: 20-25
-Switching frequency: 8-16 kHz
Due to Castle Link I can set up the ESC with the computer. In the menu there are the following modes possible:
-Motor Timing: Low(0), Normal(5), High (10) and Custom (0-20).
-PWM Rate: Outrunner Mode, 8kHz, 12kHz, 16kHz, 24kHz.
Now what should I choose? About the timing, are the numers meant in ? and about the Switching frequency, what exactly is the Outrunner Mode?
Thank you for your help! Originally I planned to do a maiden tomorrow...
Regards Stefan
sfluck is online now Find More Posts by sfluck
Old Apr 01, 2011, 01:07 PM
crypto666 is offline
Find More Posts by crypto666
USA, NV, Caliente
Joined Mar 2009
Timing--low is always a safe bet and is usually the most efficient. However, more power can be had from higher timings, but often at the expense of efficiency. My experience is that is makes very little difference. Trial and error is often the best practice. I usually start at 0 degrees (the numbers in caste link are degrees) run it, check data, bump it up 5 degrees, check, repeat and choose what ever looks best to you. It would be helpful to monitor motor temp while doing so so you can analyze efficiency.
PWM--is the frequency of the energizing pulse. Higher frequencies are easier on the motor, while lower frequencies are easier on the ESC. This can be used if the motor or esc is generating excessive heat or running close to its limits. Increasing the freq will move heat from the motor to the esc and vis a vis.
Outrunner mode is and automatic PWM that I believe changes with RPM. I would assume it starts out fast and slows down with RPM, but it may be the inverse.
crypto666 is offline Find More Posts by crypto666
Discussion Phoenix Ice Lite 100/ Ice 100 sebbe Power Systems 5 Nov 10, 2011 05:15 PM
Sold Hacker A40 14S...$60 shipped dumbdidgits Aircraft - Electric - Power Systems (FS/W) 11 Feb 27, 2011 05:48 PM
Discussion Phoenix ICE LITE 50 BEC with 4S LiPo bastian74 Power Systems 7 Sep 06, 2010 12:16 PM
Sold Phoenix ICE 100/ICE LITE 100 NIP hole digger Aircraft - Electric - Power Systems (FS/W) 9 Oct 14, 2009 02:47 PM
Wanted Want a Hacker A40-14S (530KV) or A40-12S (610KV) DavidMC Aircraft - Electric - Power Systems (FS/W) 0 Sep 08, 2008 11:19 PM
