Old Jun 12, 2011, 05:47 AM
mozzyrocks is offline
Find More Posts by mozzyrocks
Australia, VIC, Blackburn North
Joined Feb 2011
Here you go Taki.
This is what mine looks like.
mozzyrocks is offline Find More Posts by mozzyrocks
Old Jun 12, 2011, 11:44 AM
deadspeedv is offline
Find More Posts by deadspeedv
Joined Apr 2011
No Teflon washer? :P
I had a bitch of a time trying to put my strut on. The holes were a little to far apart, but still close enough to make it look like everything would be alright. I drilled the holes and put the bolts through only to find out there was no room to put a nut on. So had to rip it off glue the bottom holes up and then drill 2 new holes higher up on the strut. Fits perfect now.
How do you go about cutting your flex shaft to size? I was going to wrap it in tape then cut it with a dremel.
deadspeedv is offline Find More Posts by deadspeedv
Old Jun 13, 2011, 02:38 AM
Rusty Old Fart is offline
Find More Posts by Rusty Old Fart
Zombie Apocalypse
Rusty Old Fart's Avatar
Newcastle, Australia
Joined Nov 2010
Yep cut with a dremel and then solder. Or as some do forget the tape, solder it first then cut with the dremel.
Rusty Old Fart is offline Find More Posts by Rusty Old Fart
Old Jun 13, 2011, 04:08 AM
Taki_bg is offline
Find More Posts by Taki_bg
Bulgaria, Burgas, Pomorie
Joined Mar 2011
Originally Posted by mozzyrocks View Post
Here you go Taki.
Hi Mozzy,
must I glue the bushing to the strut or live it free and just to fix it on the back with heat shrink to the brass tube?
May I use i file to make a flat spot to the prop shaft for the drive dog?
Cheers.
Taki_bg is offline Find More Posts by Taki_bg
Old Jun 13, 2011, 06:29 AM
Joined Feb 2011
Do not glue it!
The heatshrink is to stop the water pushing up the brass tube through the strut.
It doesn't hold anything.
The brass tube should go almost through the strut & the bushing slides inside the tube & then your teflon liner should slide in from the top, till it touches the speedmaster bushing.
Do I need a teflon washer? Maybe I should get one.
Old Jun 13, 2011, 07:32 AM
Taki_bg is offline
Joined Mar 2011
Do not glue it!
Thank you for supporting me Mozzy!
I think you really need a teflon washer. What about making the flat spot on the prop shaft?
Cheers.
Old Jun 13, 2011, 07:37 AM
Joined Feb 2011
I think I made the flat spot on mine.....although, I really can't remember it was so long ago!
Flat spot it as you will want it to grip.
Yeah, I think I'll get a teflon washer.
I wonder if I have one here? Hmmmmm.
Old Jun 13, 2011, 08:14 AM
goldcoastflyer is offline
Find More Posts by goldcoastflyer
Joined Feb 2010
just ordered the genisis from Hk AUS, they told me 3 weeks to new stock. Was gonna run stock with some 2cell 4000 batteries so do I need to glass motor mounts to start?
Thanks for info so far great forum for this boat
goldcoastflyer is offline Find More Posts by goldcoastflyer
Old Jun 13, 2011, 08:20 AM
Zombie Apocalypse
Joined Nov 2010
The boat will run stock out of the box just fine. Prolonged use will force the upgrade to 3/16. Do the usual.
1 Pull down and regrease everting
2 Locktight everything when you put it back together
and enjoy
Old Jun 13, 2011, 08:31 AM
Joined Apr 2011
Dont hit fish when running it. It can bend the strut
Do you solder your shaft farty? I found that it no longer fits into the collet gripping thingy :P. I think I need to buy a soldering iron that it is bit hotter so it flows better. If it is even a wire bigger it will not fit.
Old Jun 13, 2011, 08:37 AM
Joined Feb 2011
YES, glass the mounts in properly!!!
Just over lay them as they are.
I cut slots in the carbon & kevlar I used & went over the top & just resined it in. Worked out pretty well.
The battery mounts don't like to hold heavy (6S) packs as I found out.
Realistically, 2S x 2P = 4S in parallel will be much better. More weight & longer run times.
Use the T180 ESC & the 5.5mm bullets. Make a bigger mount for the ESC too.
Can't go wrong.
Deadspeed, have you tried one of those flame burner things to do your soldering?
That's what I used & it doesn't require anything to touch the components, just the flame.
Old Jun 13, 2011, 09:10 AM
Taki_bg is offline
Joined Mar 2011
Guys is it a problem to run 2 x 3S 5000mAh battery in series, one of them is 20C the other one is 40C? Or the 2 batt must be with the same C rating?
Old Jun 13, 2011, 11:33 AM
F1 madness is offline
Find More Posts by F1 madness
F1 madness's Avatar
Staffs UK
Joined Feb 2010
batts have to have same MAH,C Rating
dont run like you said disaster waiting to happen
F1 madness is offline Find More Posts by F1 madness
Old Jun 18, 2011, 04:30 AM
Taki_bg is offline
Joined Mar 2011
Hello guys,
2 days ago I have reinforced my Genesis with fiberglass clothe and glued back the ESC and servo stands. Here are some pictures.
Old Jun 18, 2011, 10:14 AM
Joined Feb 2011
Nice work Taki.
That's what's got to be done if you want to increase the power plant later on.
I finally drilled & tapped my motors endbell too.
Next is laying more carbon & kevlar into the sponsons.
Discussion Genesis setup recommendations stuglas69 Racing Boats - Electric 32 Jul 03, 2015 09:55 PM
Question TFL Hobby GENESIS twin setup Alfa Twin Spar Racing Boats - Electric 54 Feb 21, 2014 08:43 AM
Yippee! Carbon Fiber Genesis Hulls!! FighterCat57 Racing Boats - Electric 7 Dec 03, 2010 01:34 PM
Discussion bought the "Genesis Offshore Twin Hull",need opinions! ginnz Racing Boats - Electric 77 Oct 20, 2010 04:52 PM
Sold Genesis Cat Dangerous_toys Boats (FS/W) 5 Sep 09, 2010 11:29 PM
