Espritmodel.com Heli Air
Old Aug 10, 2011, 09:36 AM
Australia, VIC, Blackburn North
Joined Feb 2011
Yeah, you're right, mine is the same as yours.
I think it may fit though, I guess I need to get the gear & wack it in.
mozzyrocks is offline Find More Posts by mozzyrocks
Old Aug 10, 2011, 09:40 AM
F1 madness's Avatar
Staffs UK
Joined Feb 2010
Thats the only thing i can think off,just try it and see
F1 madness is offline Find More Posts by F1 madness
Old Aug 10, 2011, 09:48 AM
Joined Feb 2011
Yeah, looks like I'll have to.
How difficult is it to get one of those crazy arsed 16S ESCs?
Actually I better ask the owner of that Red Rocket the dimensions unless they are list on the Fightercat site.
Old Aug 13, 2011, 06:35 AM
Bulgaria, Burgas, Pomorie
Joined Mar 2011
OK Guys,
here are some pictures!
As you can see the rear bracket is on its place, but I can't line up the flex cable with the motor shaft. The motor cooler is touching the floor and I cant move the front of the motor i little more down to line up everything.
Any suggestions?
Taki_bg is offline Find More Posts by Taki_bg
Old Aug 13, 2011, 07:43 AM
Wave Riding Vehicles
HYDROJERRY's Avatar
Louisburg,North Carolina
Joined Jun 2009
almost looks like if you could cut out the mount from the floor and turn it around, maybe cut the hole slotted and then reglue it to the floor it may work,
HYDROJERRY is offline Find More Posts by HYDROJERRY
Old Aug 13, 2011, 01:29 PM
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
For that small amount, I'd file off the bottom front edge of the water jacket at the same angle as the bottom of the hull & slot the front screw holes down in the motor mount.
You should get the right depth before you hit the O ring slot.
Another option is to make a new bracket for the rear ring mount & move the ring as far back as you can so you can slide the cooling jacket further back. That should allow the front to drop down. You will still have to slot the front mounting holes down too.
Paul.
785boats is offline Find More Posts by 785boats
Old Aug 13, 2011, 05:16 PM
Stoke-on-Trent, UK
Joined Nov 2010
I think the problem your having with the motor fouling the floor is possibly because the reinforcement you did to the mounts looks to of raised the floor level around the mounting plates, maybe you could sand a channel in the reinforcing fibreglass.
To me that mount is backwards, the elongated hole should be at the back on the ring and not nearest the shaft, reason being any vibration in the shaft could loose the bolts causing the mount to slideand put the flexi out of line, if the circular holes were at the front this couldn't happen as the front mount would buffer the vibration.
rotorkilla is offline Find More Posts by rotorkilla
Old Aug 15, 2011, 08:54 AM
Joined Feb 2011
I just bought my Leopard & cooling jacket from eBay.
Once I receive it I'll see how I go with my install, Taki, & if I experience the same problem I'll try some other things before I go grinding my cooling jacket.
Old Aug 15, 2011, 10:46 AM
F1 madness's Avatar
Staffs UK
Joined Feb 2010
Old Aug 15, 2011, 11:38 AM
HYDROJERRY's Avatar
Joined Jun 2009
i was thinking of the same but i thought i heard the ones on ebay arnt the same i could be wrong!!!!
Old Aug 15, 2011, 08:38 PM
Joined Feb 2011
How can a branded Leopard motor not be the same?
They ALL come from China, I'm just cutting my costs by getting it from Hong Kong.
The part numbers are all the same too.
Plus, free postage too!
Old Aug 16, 2011, 04:16 AM
F1 madness's Avatar
Staffs UK
Joined Feb 2010
thats where iv started getting from hong kong as it works nearly £20 GBP cheapper,they are the same
Old Aug 16, 2011, 07:44 AM
HYDROJERRY's Avatar
Joined Jun 2009
No your right i was thinking of when i was reading about the new turnigy motors that look like Leopards,,, my bad...and i agree with you on the cheaper and free shipping from ebay thats where i was looking for them too..
Old Aug 17, 2011, 12:41 AM
Joined Feb 2011
I'm about to drop a Leopard 4082 1600kv & SF 200 ESC in to my Genesis & I'm wondering whether an Octura X447/3 or a X450/3 would be too much prop for the setup running 6S?
Currently have a X440/3 installed.
Also, what's the most accurate balancer that OSE sell?
Old Aug 17, 2011, 08:20 AM
F1 madness's Avatar
Staffs UK
Joined Feb 2010
Mozzy just had a thought
are you going to offset the rudder if not running a 47mm prop is very close to the rudder bracket and will cause cavitation and you wont be able to get your prop up high enough,which means youll be lifting the transom and the front will be ploughing the water
I tried running a 47mm on my saga and experienced as above
Question TFL Hobby GENESIS twin setup Alfa Twin Spar Racing Boats - Electric 52 Aug 11, 2011 04:43 AM
Yippee! Carbon Fiber Genesis Hulls!! FighterCat57 Racing Boats - Electric 7 Dec 03, 2010 01:34 PM
Discussion Genesis setup recommendations stuglas69 Racing Boats - Electric 4 Nov 16, 2010 06:56 PM
Discussion bought the "Genesis Offshore Twin Hull",need opinions! ginnz Racing Boats - Electric 77 Oct 20, 2010 04:52 PM
Sold Genesis Cat Dangerous_toys Boats (FS/W) 5 Sep 09, 2010 11:29 PM
