Wiring repair question?
I noticed when I had to replace a motor plate, that the motors on my Witespy 450 are soldered to the ESCs. Is this done for expedience sake during the building process, or is it necessary to carry the amperage from the ESC to the motor?
In other words, can I install bullet plugs and still be safe as far as carrying the current from the ESC to the motors? It sure would make making repairs easier. Jim |
Second: You should not use the same wiring, you should re-wire with the included wiring harness. I believe there is a diagram included. What you should do is send the board back and have Paul install header pins like your 1d board has, then you can just drop it in. Also: http://flyingeinstein.com/index.php/tutorials/ezconnect e |
I did a bit more testing, and it would appear to not be a hardware issue at all. I switched the ESC connectors from the rear motors to the front and visa-versa, and then the front motors ran slower than the rear motors, rather than the other way around. This tells me that it's actually the signal from the board to the motors that is incorrect. I also tried changing the pitch and roll channels in the Tx, to see if it's a signal issue. If it had been a signal issue, this would have caused the motors on one side to run faster, but it did not. The speed difference was still a front/back issue. So, that leaves me with the board itself. Fir some reason, the board is making the rear motors spin slower than the front motors regardless of mode. I already re-uploaded the firmware with no effect. Do you think there's anything else I can try? It's the Quadrino Zoom board, and physically is pristine. |
Great news for Witespy Naza owners, Naza GPS will be out with RTH and PH for $169 in June! Very cool!
Latest blog entry: Wirewolf903 Blog
Australia, WA, Perth
Joined Mar 2012
Changed to Naza
Just finished changing over from quadrino to Naza. Very impressed with the stability. Ive also installed LED lighting. I thought the LEDs were just a fancy addition when I first saw these, but its enabled me to get more flights in when I get home from work and its dark. My nearest neighbours are about 300 metres away and I could here them screaming out when they saw the quad lit up in the sky. They had no idea what it was lol.
Now I just have to wait for my go pro to arrive ![]() Michael VC-450 Witespy Build, Naza, er9x, 5.8Ghz FPV, Fatshark Predator Gemfan Props http://www.hellfast.com.au |
"To cover the most possible scenarios without prior testing, medium timing should be used. Those who wish to use low timing to conserve power should bench test the esc/motor/prop combo prior to flight by running it completely through the throttle range to make sure there are nosync issues that would cause the motor to hesitate or stall. If the motor manufacturer recommends a specific timing (such as high), then that motor response throughout entire throttle range should provide the most efficient setup".recommendation should always be followed. Bench testing all timing selections prior to flight and choosing the lowest one that gives smooth |
Joined Sep 2011
Thanks csnes1! I'm currently using the medium setting but two of my motors are getting extremely hot even after a couple minutes of hovering. They're brand new so i'm trying to determine what may be the cause. Still gotta try adding some oil and swapping two of the motors.
Clearwater, FLorida !
Joined Sep 2009
tons of UPDATES: I have the HoryzonHD 1080p Camera in stock .... This is a Killer camera for the readytofly quad. I am installing them now, or I have them for sale too.. Fits perfect in the frame, and FPV ready with live video out. I will have some 5.8G 400mw 8CH Video Transmitters and good DVR's coming very soon Also the Quadrino GPS is done.. Boards are ready. Working on the code now.. Should not be long.. Also have flashed ESC as an option too if you want to try out the rapidESC's sorry for the messy pictures.. I will get some better ones soon. ![]() ![]() ![]() ![]() ![]() ![]() video from camera SD card.
and video form downlink (my editing/recorder messed this up big time. I will find something better.)
Thanks for the Updates......great additions!!
| Thread Tools | |
| Found Want to Trade FY-90Q Quad Controller for differnt Quad controller | FL62 | Aircraft - Electric - Helis (FS/W) | 5 | Mar 11, 2011 06:43 PM |
| Discussion KK Quad In air from a Gaui Quad | guyg | Multirotor Talk | 1 | Jan 21, 2011 05:13 PM |
| Build Log STM8s Quad-copter "Quad-radic" | Edftakeoff | Multirotor Talk | 4 | May 17, 2010 03:09 AM |
| Discussion Quad brushless motors and quad ESC wiring | whatala | Power Systems | 8 | Feb 28, 2010 07:27 AM |
| quad cdr quad esc how many poly cells? | captinnitro | Power Systems | 2 | Apr 04, 2005 08:37 PM |
