Well LOS is your limitation with that quad. The transmitter range is around 1 to 1.5 miles depending on your surroundings and area interference. If you try to fly your quad that far without an FPV set up, orientation will be your biggest challenge. Hope that helps?
Latest blog entry: Wirewolf903 Blog
Flew my first 4 battery packs! Broke a prop on the first 2, decoupled Mag & Baro from the Level switch, than achieved stable Acro hover with the second 2 (ACC still needs trimming =)
Love it! For the newbies out there: make sure you remove the prop adapter that sticks to the shaft when replacing props with adapters! I almost completely stripped a prop thread this way (witespy: see PM =) P.S. also found out the Failsafe works on the Turnigy 9x: turned off my radio by mistake (right after landing, before I disarmed) and the quad went through the programmed motions =) |
Macon, GA
Joined Sep 2010
im new to quads, i assume you meant to hook it up through the usb port to the wiiconfig software? i did that and didnt see anyhting different from the first time i set it up. i turn on my tx and then i plug in the rx, and before flight i move both sticks to the bottom left to arm the board. is that correct?
That's a nice video DSLACK. I assume in order to get vids at that elevation you are flying FPV?
Made some PID changes on my quad, got it much more stable than how it came. Out of the box it was kinda 'mushy' feeling. Still have a little more work to do. I think I prefer no expo in TX, and .45 in config. e |
Arming - Hold right Yaw (or right cyclic) for 1 sec. Disarming - Learn to DISARM the ESC's before touching or approaching the Copter ESC's/Motors can start suddenly and the props can cut - fingers and eyes - permanent injuries With THRO OFF ; Hold the YAW stick LEFt for 1 sec |
Need some advice on the stock Turnigy 9x:
I'd like to keep the Heli Mode Witespy programmed for my Quad but also add another Mode where I can play with the settings (be able to revert to the functioning but limited Mode Witespy programmed with only the 2-pos Gear swich for AUX1). What is the best way to do this? Can I Copy his Mode and change the copy to "heli 90deg mode"? I'm reading this "will work the same as acro but will give you access to throttle curve which acro doesnt"? On this new "heli 90deg mode" I would like to implement the Gear-FreeFlight combo to achieve this: "MIX function of GEAR and FLAP". I've read "Flight Mode Switch on Turnigy 9x Transmitte with standard Firmware" but it's a little too short for my knowledge ... Thanks - |
| Thread Tools | |
| Found Want to Trade FY-90Q Quad Controller for differnt Quad controller | FL62 | Aircraft - Electric - Helis (FS/W) | 5 | Mar 11, 2011 06:43 PM |
| Discussion KK Quad In air from a Gaui Quad | guyg | Multirotor Talk | 1 | Jan 21, 2011 05:13 PM |
| Build Log STM8s Quad-copter "Quad-radic" | Edftakeoff | Multirotor Talk | 4 | May 17, 2010 03:09 AM |
| Discussion Quad brushless motors and quad ESC wiring | whatala | Power Systems | 8 | Feb 28, 2010 07:27 AM |
| quad cdr quad esc how many poly cells? | captinnitro | Power Systems | 2 | Apr 04, 2005 08:37 PM |
