Old Apr 05, 2011, 02:10 PM
Tony97 is offline
Find More Posts by Tony97
Tony97's Avatar
Joined May 2004
So we should calibrate ESCs on your quads? Thought they came calibrated???
What graph? I didn't know about those numbers. I guess you are talking about the GUI software. I will plug back in and check that out later, update and post V8.
Originally Posted by witespy View Post
Do not forget that you might need to To calibrate your esc's
esc to rx, turn on tx and put throttle full up, then connect battery and motor beeps once and you put throttle down before it goes into programing mode and it should beep again telling it is ready.
and more info on how the graph should look..
Now when you pitch the aircraft forward the pitch numbers should go positive and the graph should show positive data for the pitch channel.
Inversely pitch back on the aircraft and the pitch numbers should go negative and reflect that in the graph as well.
Likewise if you roll the aircraft to the right (viewed from the back) the roll numbers should go positive and the graph should reflect that.
Inversely when you roll left the roll numbers should go negative and the graph should reflect that too.
When you yaw the aircraft to the right, the yaw numbers should go positive and be reflected in the graph.
When you yaw left the yaw numbers should go negative and be reflected in the graph data.
Tony97 is offline Find More Posts by Tony97
Old Apr 05, 2011, 03:07 PM
witespy is offline
Find More Posts by witespy
Clearwater, FLorida !
Joined Sep 2009
They come calibrated with my radio and the receiver shipped with the quad. This calibration is not going to be the same for all radio's . you would have to shipped me your radio. I do use a DX8, so they should be really close to every one using spectrum.
It "should" not be needed....but might "fine tune" things a little more. If it "looks" like one motor is not spinning exactly like the rest.
witespy is offline Find More Posts by witespy
Old Apr 05, 2011, 06:12 PM
seadog1967 is offline
Find More Posts by seadog1967
Waiting for my Medication
seadog1967's Avatar
USA, MA, West Springfield
Joined Nov 2010
Well did the wire trick witespy suggested. Disconnected the red power ones on three then on fourth plugged in only the single signal one to the board and ran the connector down thru the plate and out to the rx. Plugged into the batt slot. Turned on tx. plugged in batt. on quad got my little lite and click then moved throttle to low right to arm. Got the motor movement. Held on to it and moved the throttle up a little. Let it run then turn off the Tx. Took a second or so and the motors stopped. Wasn't instant but a very short delay. I think good just incase you lose signal for a second. So this I think solves that problem on runaway quads.
So if totaly newb to RC and electronics can do it the rest of you should have nooooo problem.
seadog1967 is offline Find More Posts by seadog1967
Old Apr 05, 2011, 06:23 PM
tc3wins is offline
Find More Posts by tc3wins
Multirotor Builder!!!!!
South Carolina
Joined Mar 2009
Ya never know. I can't wait to see it fly. You will have it doing back flips in no time.
tc3wins is offline Find More Posts by tc3wins
Old Apr 05, 2011, 06:25 PM
Tony97 is offline
Tony97's Avatar
Joined May 2004
Trimming STABLE Mode
Video posted on page 14 that shows this better.
Old Apr 05, 2011, 06:28 PM
Tony97 is offline
Tony97's Avatar
Joined May 2004
I never calibrated my quad from you. I didn't know we had to do this. I didn't get a CD with directions. I will add it to the directions I made. Standby for version 8. I'll work on it tomorrow. Working my other job tonight.
Old Apr 05, 2011, 06:33 PM
Tony97 is offline
Tony97's Avatar
Joined May 2004
Witespy-calibration of ESC
Witespy,
Please look at the 3-4 videos of my quad taking off. Does it look like motors need calibrating? Notice how in either ACRO or ACC I have to really be on the throttle carefully to takeoff or it will flip or roll. Always been like this. Now I would think if out of cal it would fly out of trim right? So maybe this is why I needed to do a lot of trimming in ACC mode. If you calibrate motors, you would need to retrim and adjust ACC Mode trim right?
Old Apr 05, 2011, 06:47 PM
seadog1967's Avatar
Joined Nov 2010
Umm will chill out on the flips for awhile. LOL I had enough excitement recently. LOL but will be flying soooooonnnnn.
Old Apr 05, 2011, 09:26 PM
rernewe is offline
Find More Posts by rernewe
Canada, ON, Alliston
Joined Sep 2009
What size props does this use? I've seen every other piece of info about these except prop size.
thanks.
rernewe is offline Find More Posts by rernewe
Old Apr 05, 2011, 09:27 PM
seadog1967's Avatar
Joined Nov 2010
Showed in the manual. 10 x 4.5
Old Apr 05, 2011, 09:28 PM
seadog1967's Avatar
Joined Nov 2010
Can get spares here. http://www.cnchelicopter.com/servlet...pecific/Detail
Old Apr 05, 2011, 09:56 PM
rernewe is offline
Joined Sep 2009
thanks guys !! I love the fast response i get here.
Old Apr 05, 2011, 10:34 PM
Tony97 is offline
Tony97's Avatar
Joined May 2004
We hope to get timely answers out. Seadog...I will put that link in the next revision of the manual.
Old Apr 05, 2011, 10:36 PM
Tony97 is offline
Tony97's Avatar
Joined May 2004
Just got home from flying the blimp. I'm beat! I will tweak the manual a bit tomorrow. I will also try to take some video of motor calibration, quad trimming, STABLE mode trimming, etc., later on when the wind dies down. The news said it will be above 15 until Sunday.
Old Apr 05, 2011, 11:06 PM
Tony97 is offline
Tony97's Avatar
Joined May 2004
Props
What about this place?
http://montorc.com/epp1045.aspx
Discussion Quad brushless motors and quad ESC wiring whatala Power Systems 11 Dec 28, 2015 03:51 PM
Found Want to Trade FY-90Q Quad Controller for differnt Quad controller FL62 Aircraft - Electric - Helis (FS/W) 5 Mar 11, 2011 06:43 PM
Discussion KK Quad In air from a Gaui Quad guyg Multirotor Talk 1 Jan 21, 2011 05:13 PM
Build Log STM8s Quad-copter "Quad-radic" Edftakeoff Multirotor Talk 4 May 17, 2010 03:09 AM
quad cdr quad esc how many poly cells? captinnitro Power Systems 2 Apr 04, 2005 08:37 PM
