Old Jun 29, 2011, 11:13 AM
poiyt is offline
Find More Posts by poiyt
United States, GA, Newnan
Joined Aug 2010
Originally Posted by killowatt View Post
Ok i got to put the data logger on the Q between t-storm's tonight ...
APC 7x5 sport cut down an inch pulled 40amps
43amps
Both measurements were taken with a fresh hyperion 3s 35c 2200
So...what's the takeway? APC 7x5 sport un-cut is good to go w/ a 3S & stock esc? Upps the performance?
poiyt is offline Find More Posts by poiyt
Old Jun 29, 2011, 11:16 AM
poiyt is offline
Joined Aug 2010
Originally Posted by Killab View Post
I can take a pic of it when i get home. I just use 3M dual lock. It's pretty stong. So far the camera has stayed in place on the stryker.
You can find it at walmart, home depot, Ect they sell it in strips for a few bucks.
http://www.uline.com/BL_6418/3M-Dual-Lock
Btw...what POV cam you guys using for the in-flt vids?
Would this be a good choice?
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
Old Jun 29, 2011, 11:38 AM
Jeff_edge540 is offline
Find More Posts by Jeff_edge540
Mis-guided heli guy
Jeff_edge540's Avatar
Austin, TX USA
Joined Mar 2007
That is an excellent choice. Here is a YT vid comparing that cam to a new HK HD cam..
Video from the HobbyKing HD 720p "Wing Camera" (1 min 22 sec)
Jeff_edge540 is offline Find More Posts by Jeff_edge540
Old Jun 29, 2011, 11:51 AM
modbuilder is offline
Find More Posts by modbuilder
KJ4WFG
modbuilder's Avatar
United States, SC, York
Joined Dec 2007
Originally Posted by Wrathchild View Post
My opinion.. the front mount needs to angle down a bit. It seems that in level flight you're seeing mostly sky.
Also, if it's possible without messing up your focus I would try to get some of the wing's leading edge into the frame. I think the video gives a better "feeling" of what's going on when you have some reference.. and stops some of the motion sickness effect of watching a video like that.
check your pm's
modbuilder is offline Find More Posts by modbuilder
Old Jun 29, 2011, 12:00 PM
brati4 is offline
Find More Posts by brati4
brati4's Avatar
Wichita,Ks
Joined Feb 2007
Originally Posted by ty_horn View Post
that is exactly what I use. Perfect fit. No surgery.
Sorry to ask, but are you stock(ESC/Prop). Any CG issues?
brati4 is offline Find More Posts by brati4
Old Jun 29, 2011, 01:54 PM
Benihama is offline
Find More Posts by Benihama
Joined Jun 2011
Just made my first 27q flight with 4s lipo today. the 40amp esc can handle it easy just the engine is going to be a bit hotter then on 3s with the 6x6 prop.
the next days i try to fly this setup with an 6x5 prop on 4s.
all i can say for now... the Stryker can be RELAY fast
Benihama is offline Find More Posts by Benihama
Old Jun 29, 2011, 02:09 PM
gatorb8 is offline
Find More Posts by gatorb8
Registered Offender
gatorb8's Avatar
United States, FL, Gulf Breeze
Joined Apr 2008
Was able to maiden my Q today
I went with 4 cell and Ice lite 75 esc for the first flight. The rest was stock. I'm at 8750' altitude so I was wanting a bit more power in this thin air. I did not even attempt the no-power launch, went with the power-on launch. First launch---not so good, not enough power. Second launch went fine, third too. I switched in a bit of up elevator for launch, and switched it out when underway. On low rates and high speed I did get a bit squirrley so may need to dial down the throws a bit for high speed. I used a "chicken-glove" for powered launch just in case.....after I get the hang of it, may not need it.
The thing is pretty fast, seemed like a spec in the sky that I was always turning.
Time to log some flights and get more comfortable!
if you click on the 4 arrows in the lower right, you can watch full screen
Stryker Q maiden (6 min 23 sec)
gatorb8 is offline Find More Posts by gatorb8
Old Jun 29, 2011, 02:18 PM
Benihama is offline
Joined Jun 2011
was that fly with 4s on the original motor? did you check the temp of the engine after?
Old Jun 29, 2011, 02:22 PM
gatorb8 is offline
Registered Offender
gatorb8's Avatar
Joined Apr 2008
stock motor, didn't check temp
Old Jun 29, 2011, 02:32 PM
thinman is offline
Find More Posts by thinman
Joined Dec 2008
On a DX7 how do you program/switch in up elevator? This will be my first wing plane and I've never done it. I have programmed in flaps in the flaperon mode on one of my other planes. Is it similar?
Bob
thinman is offline Find More Posts by thinman
Old Jun 29, 2011, 02:36 PM
jhroof is offline
Find More Posts by jhroof
Orlando, Fl
http://vimeo.com/25777994
Is that a glove you are wearing? I know it can't be because it is too cold.
Edit: Guess it didn't read the whole thing. Anyway, what kind of glove did you use?
jhroof is offline Find More Posts by jhroof
Old Jun 29, 2011, 02:45 PM
Killab is offline
Find More Posts by Killab
Youtube Johnbrum26
United States, TX, Celina
Joined Oct 2010
Just ordered that one last week. Of course after I see the hk one.
Killab is offline Find More Posts by Killab
Old Jun 29, 2011, 03:27 PM
poiyt is offline
Joined Aug 2010
Bob
Bob to answer your question, delta's dont have flaps per se.
I'd suggest using your manual but in the "setup" menu, under 'wing type', select "delta". The tx will then mix in the elevons (mixing aileron & elevator). After selecting delta you can power off, then turn it back on & go to the programming menu. There you'll find everything else you need for the electronic setup.
But before electronic setup, do the mechanical set to center. Set all your tx trims & subtrims to zero. Then check to ensure the 4 servo horns are all perpendicular (ie, 90*) to their cases...move the clevises as needed to center the elevons & rudders.
Not sure how much more you may need but this is a start.
Jeff
Old Jun 29, 2011, 03:40 PM
vygec is offline
Find More Posts by vygec
London, UK
Joined Mar 2010
ok, just had my 'attempted' maiden, not good news im afraid.
Did control check, checked all surfaces, everything working perfectly.
1st launch, no power, good throw, hit upto half power, landed straight on the ground, fortunately on its back, no damage.
2nd launch, i thought i'd try some power, gave it 1/4 power, threw into the wind, same effect, except this time the propellor broke!
so end of.
wasnt keen on full power, but i reckon it might be required.
now, i need a prop, can it be any 6*6 prop, or does it need to be the one from parkzone. im not sure if spares are currently available?
was so upset, came back home quickly, and took out my trusty T28 for a quick 1 battery, that cheered me up
vygec is offline Find More Posts by vygec
Old Jun 29, 2011, 03:46 PM
thinman is offline
Joined Dec 2008
Thanks Jeff. I think I'll be able to get set it up from the info you gave me.
Bob
New Product Parkzone F 27Q stryker friz Electric Plane Talk 181 Nov 04, 2011 02:54 PM
Found Parkzone F-27c stryker PNP NIB rcwarrior Aircraft - Electric - Jets (FS/W) 0 Nov 11, 2010 07:48 AM
Question Please Help! Can I use 14.8V 2200mAH on ParkZone F-27C Stryker? rcwarrior Electric Ducted Fan Jet Talk 3 Nov 11, 2010 12:13 AM
Discussion Looking for plans for foamy similar to Parkzone F-27c Stryker CX2Mike Foamies (Scratchbuilt) 5 Oct 24, 2010 01:00 PM
For Sale Parkzone F-27c Stryker PNP or BNF beginner4life Aircraft - Electric - Airplanes (FS/W) 1 Sep 12, 2010 11:02 AM
