Old Apr 05, 2011, 01:27 AM
sikky is offline
Find More Posts by sikky
speedin n da weeds :)
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
its 85 for just the frame no hatches hardware ect......
sikky is offline Find More Posts by sikky
Old Apr 05, 2011, 04:34 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Originally Posted by Prof100 View Post
Frisbee style launch would be much safer. That's how I launch my Superfly and scratch built F22 too.
To each his own, I've never been happy with the frisbee toss.
An aside: grew up in Bridgeport CT, home of Frisbe Pie Co. Ate the pies, threw the tin plates, got in trouble more often than not because they had a deposit on the tins and wouldn't take them back if dented.
I use a transmitter strap and the transmitter is in the way for a frisbee toss. I get much more power from the sidearm toss, that's why the hand launch glider guys use it.
Azarr
Azarr is offline Find More Posts by Azarr
Old Apr 05, 2011, 08:15 AM
rpstar is offline
Find More Posts by rpstar
rpstar's Avatar
Dacula, GA
Joined Feb 2008
Originally Posted by GryphonRCU View Post
Point is that both are Stryker....and they have so much in common.
Would you prefer if the title of the original thread changed?
Read the other thread...same comments are made.
Gryphon
No, separate the threads.
rpstar is offline Find More Posts by rpstar
Old Apr 05, 2011, 11:45 AM
Infernal Bill is online now
Find More Posts by Infernal Bill
United States, CA, Rancho Palos Verdes
Joined Sep 2010
Thanks, guys, for the input on the hand launch. I like the idea of mixing in elevator to the throttle, but it sounds like the recommended approach is to launch throttle off.
There are a few guys I fly with that have multiple Funjets with different setups and I've given them a few tosses so they could have full hands on during launch. They always launch at half to 3/4 throttle. Now you guys have me freaked out with all the fingering slicing stuff. I know that chicks dig scars, but I'd like to avoid severing a tendon.
You really have enough time to throw and get your hand on the throttle before these heavy planes hit the ground?
Infernal Bill is online now Find More Posts by Infernal Bill
Old Apr 05, 2011, 11:59 AM
kuczy is offline
Find More Posts by kuczy
The Earth got in the way!
kuczy's Avatar
United States, OH, Canal Winchester
Joined Feb 2007
You just have to throw it hard at about 45degrees and punch the throttle. I tell everyone to throw it like a 70yrd touchdown pass. If you throw it like that into the wind you'll never have a problem. Just use low rates to launch and it works every time. I've been doing it like that for about 6yrs and haven't lost a Stryker on the launch yet. I'm not a fan of the Frisbee throw but, to each his own. What ever gets it into the air and your comfortable doing is the right way for you.
kuczy is offline Find More Posts by kuczy
Old Apr 05, 2011, 12:10 PM
snivilous is offline
Find More Posts by snivilous
High Altitude Specialist
snivilous's Avatar
Joined Jan 2010
What if you don't know how to play football
snivilous is offline Find More Posts by snivilous
Old Apr 05, 2011, 12:58 PM
ElIntocable is offline
Find More Posts by ElIntocable
7.62x51
ElIntocable's Avatar
United States, LA, Shreveport
Joined Jul 2010
Originally Posted by snivilous View Post
what if you don't know how to play football :d
lol!
ElIntocable is offline Find More Posts by ElIntocable
Old Apr 05, 2011, 01:41 PM
Figure.N9ne is offline
Find More Posts by Figure.N9ne
Miami, FL
Joined Mar 2007
the point of the mix is so you can launch throttle off and as soon as the plane is out of your hand you can get on the throttle with your left hand. Without the mix, you have to get the right hand to the elevator THEN give it throttle. with this method, all that you need is a soft toss at about 20 degrees into the wind and the plane does the rest.
so you're supposed to kick it?!?
Figure.N9ne is offline Find More Posts by Figure.N9ne
Old Apr 05, 2011, 02:02 PM
jhroof is offline
Find More Posts by jhroof
Orlando, Fl
Originally Posted by Yaniel View Post
the point of the mix is so you can launch throttle off and as soon as the plane is out of your hand you can get on the throttle with your left hand. Without the mix, you have to get the right hand to the elevator THEN give it throttle. with this method, all that you need is a soft toss at about 20 degrees into the wind and the plane does the rest....
What mix do you use? Like a -20%, so you have about 20% elevator at 0 rpm and no elevator at full rpm. That way it wouldn't loop on you as you increase the throttle.
jhroof is offline Find More Posts by jhroof
Old Apr 05, 2011, 03:09 PM
kuczy is offline
kuczy's Avatar
Joined Feb 2007
I guess change your name to Nancy........
Really just chuck up into the wind, it'll glide, and just throttle up. Pretty easy.
Old Apr 05, 2011, 03:33 PM
Miami, FL
Joined Mar 2007
it's a 20% mix but the elevator goes up more as the throttle increases, no throttle = no elevator (seems like a good way to stall if you have up elevator with no throttle). You also shouldn't give it full throttle on launch as it'll want to torque roll. With probably 70% throttle the plane climbs out nicely and has never even come close to looping. IF it even will loop like that, you'll have your other hand on the radio, the mix turned off, and be flying the plane long before that time.
Old Apr 05, 2011, 04:28 PM
rimripper is offline
Find More Posts by rimripper
rimripper's Avatar
Alberta,Canada
Joined Nov 2009
IMHO you can set a degree of mix in a position switch,no need to mix it with throttle.
Set it up for 30% for launch,throw,let the stryker climb under the 3/4throttle,and then return switch to 0 for level flight.
I think this was posted a few pages back in the stryker c thread.
rimripper is offline Find More Posts by rimripper
Old Apr 05, 2011, 04:31 PM
Miami, FL
Joined Mar 2007
i had it like that originally, but it tends to go smoother when mixed to throttle because it wont try to climb before adding throttle. in the end either way will work.
Old Apr 05, 2011, 05:31 PM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
So the Stryker-Q is marketed as having an airfoil that's better suited to high speed, eh?
Do we have an idea as of now what that means? Thinner? More symmetrical?
The main things that appear to keep the Q from being as suited to high power and high speed are the canopy that restricts cooling air to the motor, and the possible inability to run the Custom RC Parts Stryker motor mount.
I think these things can be worked around by making custom hatches or using a Stryker C hatch, and modding the trailing edge to mount the Custom RC Parts mount.
If the Q has an airfoil that truly is more suited to high speed, I'm super interested in it, as long as it can still run the high power it takes to get high speed. (I'm the fool who has packed 11S 4000mah into his Stryker to get 195mph)
murdnunoc is offline Find More Posts by murdnunoc
Old Apr 05, 2011, 06:28 PM
MARCOELDRAGON is offline
Find More Posts by MARCOELDRAGON
Fly Naked !
MARCOELDRAGON's Avatar
Waynesboro VA USA
Joined Dec 2010
I'm thinking I'll use my current 2 F-27C's for speed and the F-27Q for aerobatics. I was about to order an Extra 300 for aerobatics when my old car showed signs of expiring and had to buy a new one. I was a bit bummed until a buddy told me about this new Stryker, it cheered me right up.
MARCOELDRAGON is offline Find More Posts by MARCOELDRAGON
New Product Parkzone F 27Q stryker friz Electric Plane Talk 181 Nov 04, 2011 02:54 PM
Found Parkzone F-27c stryker PNP NIB rcwarrior Aircraft - Electric - Jets (FS/W) 0 Nov 11, 2010 07:48 AM
Question Please Help! Can I use 14.8V 2200mAH on ParkZone F-27C Stryker? rcwarrior Electric Ducted Fan Jet Talk 3 Nov 11, 2010 12:13 AM
Discussion Looking for plans for foamy similar to Parkzone F-27c Stryker CX2Mike Foamies (Scratchbuilt) 5 Oct 24, 2010 01:00 PM
For Sale Parkzone F-27c Stryker PNP or BNF beginner4life Aircraft - Electric - Airplanes (FS/W) 1 Sep 12, 2010 11:02 AM
