For me the entry of the inverted spin works best with full down, full aileron and full opposite rudder. If the plane is in the spin, take out the aileron and the spin will become ultra slow. If you keep aileron it will spin faster, but still very nice. For an upright spin pull full elevator, full aileron and full rudder same direction.
New to the forum as well as the plane. This is my first wing and after 3 flights I'm having a BLAST!! I did have to change my shorts after the maiden flight, the recommended settings from HH did not work for me at all. After whinning and crying for help EastCoast78 explained Exponential to me as well as suggested settings. Flights 2 and 3 looked smoother and felt a lot better!
Didn't try the vertical landing yet. I'm guessing just point her into the wind and full UP Elevator?? Any suggestions? Thanks in advance! Now if only my mouth would STOP getting so dry and my hands would quite shaking before I fly the Stryker I'll be feeling much better!!! |
I put 6 flights on the Q yesterday. It was great!
But on my last flight all of the sudden it started to turn left and it wouldn't straighten up. So I decided to land it. As I inspected it my left aileron control horn was off! It did land ok so don't worry to much about it.So i scraped off the paint and reglued on the control horn with CA. I hope this holds it. |
Latest blog entry: 3D Hobby Shop 58" Edge
I have looked at the new stryker. I agree it needs it own thread.
I like some of the changes. I am just concerned about the fuselage replacements costing 85 bucks. Have anyone seen them cheaper than what Parkzone has them for? I would love to get my hands on just the fuselage to see what I can do to it! It sure is faster than the original one i bought some 7-8 years ago. But for us speed junkies, it is going to need some mods so it can handle the high speeds. I think they made it so it would be harder to modify. Truly the motor mount looks like the old zagi setup! |
Latest blog entry: Composite 200 mm micro quad!
6 minutes then time to land. already put her up 20 times or so,and this is the safe bet. Some flights will have juice for after 7,some ,not after 6:30. runnin,stock pz batt. and Tenergy as well as Progressive RC spyders , all 3s 2200 25C All seem to give very similiar flight times so far,without goin overboard on the wot runs.
! This is what we were all afraid of. Sure would be nice if someone from Parkzone or Horizon could explain their thought process of using the screws/backplate setup on the rudders but not the ailerons! This makes absolutely no sense on such a high speed/aerobatic plane. And they also need to ship all of us a free set of control horns w/ backplates.
Not only were the horns just glued over paint(pretty much happens on some parts, usually the gear plate for most of HH's EPO stuff), they weren't glued well even if it was bare foam, you can see in the pic, glue was only where the paint pulled up, just 2 small drops of what looks like CA on either side of the flange, nothing in the channel for the "foot" of the horn, or in front where there is more stress. I would urge everyone to pull the horns and reglue them with epoxy, CA, or add backing plates. It's easy to catch, and easy to fix, hopefully this is the only F-up on horizon's part with this plane, if so, that would actually be an improvement considering most of their recent models. |
I have both. I've been flying the C for many years now. The Q is a better out of the box plane hands down. It's faster and more maneuverable. It also flies slow better and it hold high alpha a lot better. It does everything the C does, but it does them better and it does things that are impossible the C to do without serious mods.
Latest blog entry: Getting into 3D a little more
| Thread Tools | |
| New Product Parkzone F 27Q stryker | friz | Electric Plane Talk | 181 | Nov 04, 2011 02:54 PM |
| Found Parkzone F-27c stryker PNP NIB | rcwarrior | Aircraft - Electric - Jets (FS/W) | 0 | Nov 11, 2010 07:48 AM |
| Question Please Help! Can I use 14.8V 2200mAH on ParkZone F-27C Stryker? | rcwarrior | Electric Ducted Fan Jet Talk | 3 | Nov 11, 2010 12:13 AM |
| Discussion Looking for plans for foamy similar to Parkzone F-27c Stryker | CX2Mike | Foamies (Scratchbuilt) | 5 | Oct 24, 2010 01:00 PM |
| For Sale Parkzone F-27c Stryker PNP or BNF | beginner4life | Aircraft - Electric - Airplanes (FS/W) | 1 | Sep 12, 2010 11:02 AM |
