Old Jun 22, 2011, 01:53 PM
9sec240 is offline
Find More Posts by 9sec240
Advanced Heli Collector
9sec240's Avatar
USA, IL, Carol Stream
Joined Jan 2009
There is the possibility that it is your motor and not your ESC that is the issue. Do you have a multimeter? You could measure resistance between the leads and see if there is any anomalies.
9sec240 is offline Find More Posts by 9sec240
Old Jun 22, 2011, 02:05 PM
dribbe is offline
Find More Posts by dribbe
dribbe's Avatar
United States, FL, Venice
Joined Jan 2005
Originally Posted by Killab View Post
sorry using a turnigy 9x tx with a flysky 6 ch rx. I did have to reverse throttle. But the esc was working fine, until one bauched attempt to hand launch. It landed flat on the ground but it after that would not ARM. I will my first throw I the it like a football and twisted as I the and it went nose first. Everything worked fine after that. Then on the last failed throw it stopped working. Would ARM but was very hard to hear, then it just stopped.
Lesson just make sure its nice and tight in the holder, I think it must have shifted and hit one of the caps on the battery and shorted somehow.
OK, probably smoked it by stalling the motor (likely reasonable case)?!
Hope you are back in the air soon...
David
dribbe is offline Find More Posts by dribbe
Site Sponsor
Old Jun 22, 2011, 02:12 PM
Killab is offline
Find More Posts by Killab
Youtube Johnbrum26
United States, TX, Celina
Joined Oct 2010
Checked the motor with a different esc, all good. Tried a different motor with stryker esc, no arming. So I've concluded its the esc.
Killab is offline Find More Posts by Killab
Old Jun 22, 2011, 02:14 PM
Killab is offline
Youtube Johnbrum26
Joined Oct 2010
David
Do you mean, by a prop strike, when you day stalling the motor. Really want to make sure this doesn't happen again.
Old Jun 22, 2011, 02:22 PM
dribbe is offline
dribbe's Avatar
Joined Jan 2005
Yes, a prop strike will stall the motor (through it out of time). A relatively low resistance/high power system has a good chance of being damaged by this.
Best Regards,
David
Site Sponsor
Old Jun 22, 2011, 02:58 PM
kuczy is offline
Find More Posts by kuczy
The Earth got in the way!
kuczy's Avatar
United States, OH, Canal Winchester
Joined Feb 2007
I have a video that is uploading that all the Q owners need to watch. It's got about 10min left.
kuczy is offline Find More Posts by kuczy
Old Jun 22, 2011, 02:59 PM
jhroof is offline
Find More Posts by jhroof
Orlando, Fl
Originally Posted by GReedTFD View Post
...that's my biggest complaint and maybe it's just me, but it just doesnt feel like there's enough meat for me to grab.
It's not just you. I deepened the hand grip by pressing in with my thumb. Makes it a little more comfortable to grab. It would be better if they made the grip holes a little wider apart. That would help keep the plane level when throwing it.
jhroof is offline Find More Posts by jhroof
Old Jun 22, 2011, 03:16 PM
kuczy is offline
kuczy's Avatar
Joined Feb 2007
Servo problems already after 6 packs.
Parkzone Stryker Q Servo Issue (2 min 30 sec)
Old Jun 22, 2011, 03:17 PM
rstein9 is offline
Find More Posts by rstein9
The Flying Herb
rstein9's Avatar
Santa Barbara, California
Joined Jul 2007
I have a stryker c that i put wheels on......with a steerable nose wheel.....
works really well....anyone else do that? wish parkzone would put wheels on the new Q!
rstein9 is offline Find More Posts by rstein9
Old Jun 22, 2011, 03:19 PM
rstein9 is offline
The Flying Herb
rstein9's Avatar
Joined Jul 2007
not the famous parkzone singing servos!!!
definitely sounds nasty....i bet parkzone would replace it.
Old Jun 22, 2011, 03:48 PM
GReedTFD is offline
Find More Posts by GReedTFD
United States, OK, Tulsa
Joined Sep 2008
http://www.youtube.com/watch?v=EGZQOQHw_fA
Thanks for the video...today one of the guys at the field swore he heard the servo grind when I yanked it vertical on high rates...will definitely be keeping a close eye on them.
GReedTFD is offline Find More Posts by GReedTFD
Old Jun 22, 2011, 04:03 PM
Floater73 is offline
Find More Posts by Floater73
But often down to earth
Floater73's Avatar
Oklahoma, USA
Joined Sep 2010
Originally Posted by the Swamp Fox View Post
yeah,,, same here.. I'm not having launch issues ,but I defintely feel like I need a better grip...
The wife just called. The Q and my DX8 from the recall were just delivered. I'm ready to leave work!!!
A friend bought his last evening from the LHS. The grip on the Q is smaller than the C. I'm going to remove some foam below where the thumb goes and where each finger goes. I'll wear a disposable surgical glove and then paint the surface with thin CA where the foam is removed. Just a drop or two of CA in the hole and smoothed out with a finger. It works really well.
Also I might remove the uneven areas where the fingers go. They don't feel right to me. I like to be able to really hold on to it so I can launch it pretty hard. When it's calm launches can come pretty close to the ground.
On a separate issue, has anyone had a problem with grass or weeds getting caught by the Vs in the wing near the fuselage? It looks like they would funnel the grass and weeds into the V and then catch. We have some pretty tough weeds that grow fast. I'm thinking of either filling the area or just cutting off the point.
Floater73 is offline Find More Posts by Floater73
Old Jun 22, 2011, 04:06 PM
Mingus The Red is offline
Find More Posts by Mingus The Red
Mingus The Red's Avatar
United States, OH, Mentor
Joined Jun 2007
Ive had over a dozen flights on her now,and about 40% were in taller grass and weeds. It picked up a little on one side once. Nothin since. Sure am markin up the white fuse with bug guts too,this time of year. hehe
Mingus The Red is offline Find More Posts by Mingus The Red
Old Jun 22, 2011, 04:40 PM
kuczy is offline
kuczy's Avatar
Joined Feb 2007
I forgot. Other than the bad servo I found today I found out some good news.
Stock Motor/Prop
4s Nano Tech 1800 35c
52Amps
770Watts
After 6min of normal flying the motor was just barely warm. Speed improved by at least 10mph and vertical was completely out of sight unlimited.
The Q is too much fun to wait for HH to send me another servo. So I'll rod my R3 of 2 HS-65HB's and put them in the Q tonight. I had them in a Habu for a while so I think they'll take the abuse pretty good until I get so MG's.
HH still owes me a servo though.
Old Jun 22, 2011, 04:52 PM
Unrealpie is offline
Find More Posts by Unrealpie
Unrealpie's Avatar
United States, MI, Taylor
Joined Aug 2010
Guys, do you need to launch this thing with no power then give it power after it clears your hand? I've seen lots of posts of people hitting there fingers in the longer prop.
Unrealpie is offline Find More Posts by Unrealpie
New Product Parkzone F 27Q stryker friz Electric Plane Talk 181 Nov 04, 2011 02:54 PM
Found Parkzone F-27c stryker PNP NIB rcwarrior Aircraft - Electric - Jets (FS/W) 0 Nov 11, 2010 07:48 AM
Question Please Help! Can I use 14.8V 2200mAH on ParkZone F-27C Stryker? rcwarrior Electric Ducted Fan Jet Talk 3 Nov 11, 2010 12:13 AM
Discussion Looking for plans for foamy similar to Parkzone F-27c Stryker CX2Mike Foamies (Scratchbuilt) 5 Oct 24, 2010 01:00 PM
For Sale Parkzone F-27c Stryker PNP or BNF beginner4life Aircraft - Electric - Airplanes (FS/W) 1 Sep 12, 2010 11:02 AM
