Old Jun 20, 2011, 08:43 PM
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
Just got mine today. This is pretty cool.
And I didn't even get to fly yet. I can't wait for the maiden!
I didn't get to set the speed brakes up yet because I don't have any 3" extensions.
zmonster97 is offline Find More Posts by zmonster97
Old Jun 20, 2011, 08:58 PM
Ping is offline
Find More Posts by Ping
Ping's Avatar
Indianapolis
Joined Aug 2004
Originally Posted by kpw555 View Post
The battery compartment is pretty tight. I would say that it would probably need to be deepened to accept 4s. It might go though.
I checked and 4s 2200 will fit stock with no mods. I also messed around with balance a bit, you can shift everything back almost 1 inch which on such a short airfame should help heavier packs balance.
I personally would not run the stock motor on 4S, I can't see it lasting very long.
Ping is offline Find More Posts by Ping
Old Jun 20, 2011, 09:02 PM
kuczy is offline
Find More Posts by kuczy
The Earth got in the way!
kuczy's Avatar
United States, OH, Canal Winchester
Joined Feb 2007
My motor was warm with the 3s 40c 2200. I would think on 4s it wouldn't last long.
kuczy is offline Find More Posts by kuczy
Old Jun 20, 2011, 09:04 PM
nickelbn1 is offline
Find More Posts by nickelbn1
fly and then fly some more!
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
not getting many videos on here yet!
nickelbn1 is offline Find More Posts by nickelbn1
Old Jun 20, 2011, 09:05 PM
ATIS is offline
Find More Posts by ATIS
Member 120mph Club
ATIS's Avatar
New Bern, North Carolina, United States
Just got mine tonight... working on a review for another forum so video to follow.
ATIS is offline Find More Posts by ATIS
Old Jun 20, 2011, 09:32 PM
alucard0822 is offline
Find More Posts by alucard0822
alucard0822's Avatar
Pennsylvania
Joined Jun 2010
Did another video. This time with a lot of hand launch footage, speed test(using rcspeedo doppler app), some slow flight with vertical pulls, parachutes(simple, but my favorite move with this plane), and a few spins, stalls, and aerobatics.
F-27Q stryker testing (5 min 27 sec)
After today's flying, I did a simple ground test, and found the right side elevon servo grinding at full travel, sounded stripped, so I took it apart, no missing teeth, just looked like there was enough flex in the case for the teeth to skip, only thumped that side once on a botched handlaunch(forgot to flip off throttle hold). So now it is wearing a pair of HS-5085s I had for another project. Swapping servos is easy with a couple simple changes. First is that the servos are installed from under the wing(somewhat obvious, but perhaps not to those new to RC). Simply peel back the tape over the servos, taking care not to tear it, the servos use that soft silicone glue, so they pull out easily. You need to cut a small square hole around the servo lead where it goes under the rear skids/bottom of rudders, this allows you to to get the plug through. Then peel back the tape over the leads, pull out the old servos, and fish the new ones through the holes you cut in the fins, and through the fuse to the RX. I use hot glue on the servo, it's strong, easy to work with, and easy to remove if needed. Haven't got to fly it yet with the new servos, but they feel quicker and stronger without making a peep, so should be good.
alucard0822 is offline Find More Posts by alucard0822
Old Jun 20, 2011, 11:15 PM
Eastcoast78 is offline
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
Originally Posted by Razors edge 29 View Post
Those are good lipos BUT don't run them full throttle all the time as they'll wear out
The same lipo with higher discharge wouid be better for the Q
Like 40C and over
Cool ive sense ordered 3 trgy 2200's ,i got a email notafatcation they were in stock. got 3 for 35Bucks. Now jsut wiat for them, But postal stike is not going too help with shipping times. Hopeyfulyl they get that worked out!! Im already waiting for 2 orders for that TitanJet and stuff.
Originally Posted by flydown View Post
Am I missing something? I thought the Stryker is suppose to be launched with no throttle due to the pusher prop poising a danger to your hand or fingers. I have seen youtube post
of someones fingers being cut almost to the bone from hand launching the Stryker with the throttle on.
Yea, i Don't think ill be overhand tossing it with Power on!! Ill Like power on 50%ish, with the left handed wing toss while right stick has control.
Originally Posted by nickelbn1 View Post
You can get batteries just as cheap at valuehobby.com, and they have deans on them already. Fast shipping and great customer service.
Cool thanks for the link. I don't use Deans all my Batterys are from HK, so the first thing ill be doing is snipping the EC3 connectors off that 40ESC and replacing with a XT60.
What size of CF rod to back of control surfaces would be sufficient? .5 mm?
I think he used a flat spar.
Im going too use 6K CF tow.
ic some of the guys are replacing the horns altogether!! Its strange that PZ would have the horns that screw to the back-plate on the rudders, but not on the Ailerons!!
Did i see that right? i was watching a Vid last night and im sure i seen it on the Rudders?
Well i should get mine last next week!! SICCKK
Eastcoast78 is offline Find More Posts by Eastcoast78
Old Jun 21, 2011, 01:08 AM
the Swamp Fox is offline
Find More Posts by the Swamp Fox
the Swamp Fox's Avatar
Wadmalaw Island ,SC
Joined Dec 2003
Picked up the Q today and heaved it this evening.stock . Good fun !
the Swamp Fox is offline Find More Posts by the Swamp Fox
Old Jun 21, 2011, 06:05 AM
Sam K is offline
Find More Posts by Sam K
Sam K's Avatar
United Kingdom, England
Joined Jun 2011
Hi guys, I'm new to RC groups and this thread so I just thought I'd introduce myself. Don't worry I'm not new to The hobby though, I've been into RC planes for the past few years now and I'm itching to get my hands on the f-27q. Thanks to everyone who has posted about the setup, modifications and minor problems with then new airframe. It will certainly be useful for when I prepare mine for its maiden
Good news to those living in the UK, I just called HH UK and they told me that the Q's should hit the shelves at all UK hobby shops by the end of the week. Not long to wait now
Sam K is offline Find More Posts by Sam K
Old Jun 21, 2011, 09:38 AM
9sec240 is offline
Find More Posts by 9sec240
Advanced Heli Collector
9sec240's Avatar
USA, IL, Carol Stream
Joined Jan 2009
Got mine yesterday. Weather looks bad till Thursday. Subscribed!
9sec240 is offline Find More Posts by 9sec240
Old Jun 21, 2011, 09:50 AM
horsham rc is offline
Find More Posts by horsham rc
horsham rc's Avatar
United Kingdom, Horsham
Joined Jun 2011
f 27q
i to want one just waiting for uk delivery i hav bin told 2 weeks ??
horsham rc is offline Find More Posts by horsham rc
Old Jun 21, 2011, 10:07 AM
kissfan is offline
Find More Posts by kissfan
kissfan's Avatar
Muscle Shoals, Al.
just got mine late yesterday. Gonna try for a maiden flight today if the weather holds out. What kind of speeds are you guy's getting on 4s?
kissfan is offline Find More Posts by kissfan
Old Jun 21, 2011, 10:36 AM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
A few posts back guys were saying not to use 4 cells, the motors were getting too hot and will likely burn up
Old Jun 21, 2011, 10:37 AM
Killab is offline
Find More Posts by Killab
Youtube Johnbrum26
United States, TX, Celina
Joined Oct 2010
Do you think this will be and issue? It seems when they cut the surface it was not cut straight. If so what is the best way to fix it?
Killab is offline Find More Posts by Killab
Old Jun 21, 2011, 10:55 AM
Sam K is offline
Sam K's Avatar
Joined Jun 2011
As I said, the word from Horizon Hobby UK today was that the Q's would arrive in hobby shops by the end of the week
I live in Horsham too are you a member of Horsham district RC model club?
New Product Parkzone F 27Q stryker friz Electric Plane Talk 181 Nov 04, 2011 02:54 PM
Found Parkzone F-27c stryker PNP NIB rcwarrior Aircraft - Electric - Jets (FS/W) 0 Nov 11, 2010 07:48 AM
Question Please Help! Can I use 14.8V 2200mAH on ParkZone F-27C Stryker? rcwarrior Electric Ducted Fan Jet Talk 3 Nov 11, 2010 12:13 AM
Discussion Looking for plans for foamy similar to Parkzone F-27c Stryker CX2Mike Foamies (Scratchbuilt) 5 Oct 24, 2010 01:00 PM
For Sale Parkzone F-27c Stryker PNP or BNF beginner4life Aircraft - Electric - Airplanes (FS/W) 1 Sep 12, 2010 11:02 AM
