Old Jun 19, 2011, 07:03 PM
Aircraft Addict
buddman36's Avatar
Jersey
Joined Mar 2010
Originally Posted by kuczy View Post
There have been several EDF Stryker C's over the years. If you want an EDF that looks like a Stryker look into the Phase3 Phantom.
Very True !! Think I will Buy one of them too ! Thanks for making my life easier !!!
buddman36 is offline Find More Posts by buddman36
Old Jun 19, 2011, 08:14 PM
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
Originally Posted by Razors edge 29 View Post
I am in US now so I got mine quick lol
Go go hobbypartz and order some sky lipo 2200 mah 40C.
I have some and they should work well
[/B]
Yea i may try from them. I did up a order and it was Cheaper then HK...Very surprising lol. I thought HK was the Cheapest lol.
EDIT: I just went a rechecked the pricing of 2 2200mahs. 2 Blue ones from Hobbyparts and 2 2200mahs Nano's 25-50C form HK. i was mistaken!!
The Nanos are 3-4 bucks cheaper. But that's not much of a difference!!.
Razor how were the shipping times from Hobbyparts!!
Eastcoast78 is offline Find More Posts by Eastcoast78
Old Jun 19, 2011, 08:15 PM
Joined May 2009
can anyone recommend a faster set up? how about a turnigy 1500kv and a 45amp esc running on a 4s? it made my skyfun go about 130..what is everyones thoughts?
http://www.hobbyking.com/hobbyking/s...idProduct=8503
HeliorPlane is offline Find More Posts by HeliorPlane
Old Jun 19, 2011, 08:18 PM
Can A da....Ehh!!
Joined May 2010
Originally Posted by noobiznessflying View Post
Wow that's the best advice I've read so far! Man any advice on how to learn to ride a motorcycle?? Let me guess, just get on it and hope it doesn't tip over?
Yes Exactly!! Or you can tell someone how too ride it 20 times and they'll still go out and dent the tank!! lol
Old Jun 19, 2011, 08:23 PM
Can A da....Ehh!!
Joined May 2010
Originally Posted by HeliorPlane View Post
i said i was sorry.
No worries!!
Old Jun 19, 2011, 10:39 PM
Can A da....Ehh!!
Joined May 2010
I would think you would need a Higher KV motor? The Stryker is 855g vs the SkyFuns weight of 550g. What size Prop did you use with that motor to get that speed? I guess the 4S would help. Were oyu using that 45A esc?
I was thinking of getting getting some 4S's for the Q, but i just ordered 3 of these. Not bad for $35 bucks Shipped.
http://www.hobbyking.com/hobbyking/s...idproduct=8932
I got a 50A esc on the way in another order, but im not sure if it would handle 4S on the 480 2200kv Im thinking 60A esc would be a safe bet for a 4S on the Q's new motor.
Old Jun 19, 2011, 10:46 PM
what ya mean i have to land?
DesMoines,Wa
Joined Feb 2008
that motor is not going to push your stryker very well,try this motor with a 60a esc,6x4or 6x5 sport prop,2200-2650 4s 40c batt
http://www.hobbyking.com/hobbyking/s...idProduct=7993
it's a fun setup that performs very on the stryker c
oly_rcer is offline Find More Posts by oly_rcer
Old Jun 19, 2011, 11:33 PM
Ping's Avatar
Indianapolis
Joined Aug 2004
Hand launches...well they aren't easy especially without wind. On the maiden I used an overhand toss without throttle and it worked well. Today it was a dead calm and my first two hand launches did not go well.
It seems the best method is gripping one wingtip apply full throttle and gently toss it forward. Keep your hand on the right stick so you can steer it in the first second. I agree the airframe is very tough, the detachable nose is a great addition and prevents a lot of damage to the airframe.
Ping is offline Find More Posts by Ping
Old Jun 20, 2011, 12:38 AM
Can A da....Ehh!!
Joined May 2010
100% throttle!! She must get going right from the get go!!
Old Jun 20, 2011, 01:01 AM
No mods no glory!
micromantis's Avatar
USA, CA, Redwood City
Joined Nov 2010
Originally Posted by Ping View Post
Here is the DX 8 mixing to use your rudders as air brakes with the flap system menu.
Right rudder connected to rudder port on RX
Left rudder connected to Aux1 on RX
Mix 1
RUD > FLP
Rate: 100
100
Offset: 0
Trim: Act
SW: ON
Mix 2
FLP > RUD
Rate: -100
-100
Offset: 0
Trim: Inh
SW: ON
Use the flap system menu to control your air brake. Positive flaps will move the rudders out towards the wingtips. Negative flaps will move them in towards the motor. You can also change the activation speed, switch, and elevator mixing easily from the flap system menu.
Aux1 will control the left rudder. Make sure the subtrim and reversing are correct. Then set your endpoints on the Rudder and Aux1 channels to be the same.
Awesome, set it up on my DX6i.
micromantis is offline Find More Posts by micromantis
Old Jun 20, 2011, 01:31 AM
sickwitit's Avatar
Lewisville, TX
Joined Sep 2010
In order to get 35mm of travel when testing my ailerons and elevators, I had to adjust both servo travel to 125% and move the clevis' to the bottom hole on the control horns. I am using the DX6i and I measured from the root of the control surface as described in the manual. Has anyone else noticed this issue?
sickwitit is offline Find More Posts by sickwitit
Old Jun 20, 2011, 09:00 AM
Youtube Johnbrum26
Mckinney,TX
Joined Oct 2010
I had to so the same thing on my P47. Maybe it has something to do with the servo centering not sure.
I hopefully will get mine today so ill let you know. How mine acts.
Killab is offline Find More Posts by Killab
Old Jun 20, 2011, 09:36 AM
The Earth got in the way!
kuczy's Avatar
United States, OH, Canal Winchester
Joined Feb 2007
Mine is out for delivery. Probably won't be here until 5-6ish
kuczy is offline Find More Posts by kuczy
Latest blog entry: Getting into 3D a little more
Old Jun 20, 2011, 09:42 AM
Mingus The Red's Avatar
United States, OH, Mentor
Joined Jun 2007
Ditto,long hours they'll be in the meantime. hehe
Mingus The Red is offline Find More Posts by Mingus The Red
Old Jun 20, 2011, 10:14 AM
R.C. Aviation Fanatic
Razors edge 29's Avatar
Canada
Joined Aug 2009
Faster than HK
Like 2 weeks I think
Hobbyking for me is always longer
Razors edge 29 is offline Find More Posts by Razors edge 29
New Product Parkzone F 27Q stryker friz Electric Plane Talk 181 Nov 04, 2011 02:54 PM
Found Parkzone F-27c stryker PNP NIB rcwarrior Aircraft - Electric - Jets (FS/W) 0 Nov 11, 2010 07:48 AM
Question Please Help! Can I use 14.8V 2200mAH on ParkZone F-27C Stryker? rcwarrior Electric Ducted Fan Jet Talk 3 Nov 11, 2010 12:13 AM
Discussion Looking for plans for foamy similar to Parkzone F-27c Stryker CX2Mike Foamies (Scratchbuilt) 5 Oct 24, 2010 01:00 PM
For Sale Parkzone F-27c Stryker PNP or BNF beginner4life Aircraft - Electric - Airplanes (FS/W) 1 Sep 12, 2010 11:02 AM
