Old Feb 04, 2013, 07:31 AM
bladeguy5 is offline
Find More Posts by bladeguy5
bladeguy5's Avatar
United States, MD, Waldorf
Joined Jun 2012
so theres no way to get a 7x5 on the stock hub?
bladeguy5 is offline Find More Posts by bladeguy5
Old Feb 04, 2013, 01:02 PM
rcoconut is online now
Find More Posts by rcoconut
Do you see what I see?
rcoconut's Avatar
Rancho Cucamonga, CA
Joined Sep 2006
There have been guys that use washers instead of going with a new prop/spinner, but I didn't want to do that.
There was one guy that said he didn't have to do any type of modification to get a 7x5 or 7x6 prop on the stock hub?? I know it didn't work for me which is why I went with that spinner/prob hub from innov8tive design.
rcoconut is online now Find More Posts by rcoconut
Old Feb 04, 2013, 06:12 PM
MJF is offline
MJF
Find More Posts by MJF
MJF
Waiting Fer Da SEFF
MJF's Avatar
United States, GA, Perry
Joined Jul 2010
I used 2 nylon washers on mine with no problems at all
MJF is offline Find More Posts by MJF
Latest blog entry: eflite ultimate 20-300
Old Feb 04, 2013, 09:26 PM
rrg is offline
rrg
Find More Posts by rrg
rrg
rrg's Avatar
United States, KY, Edgewood
Joined Dec 2007
Same here, i drill it and use washers.
rrg is offline Find More Posts by rrg
Old Feb 04, 2013, 10:41 PM
soundcheque is offline
Find More Posts by soundcheque
Bring It On !!!!!
soundcheque's Avatar
Newmarket, England.
Joined Aug 2006
I think that the guy who didn't have to mod the prop used a "Sport" or nitro prop ??
They are usually a tad thicker.
No issue with using washers although I can understand why some guys prefer not to.
Almost seems a little "Agricultural"
The shoulder where the prop sits on the shaft is 8mm
The thread which holds everything tight is 6mm
It may be a good idea to use a washer with an 8mm bore on the adaptor shaft first, then fit the prop. Then use a washer with a 6mm bore.
This will bring the prop closer to the threaded section and therefore allow the assembly to be tightened.
Fitting the prop without an 8mm washer first will in most cases leave some of the shoulder exposed and it will not allow the assembly to tighten up securely.
Obviously it all depends on the thickness of the washer used.
The reason I've explained this is because some guys may just fit the washers after the prop is fitted to take up the play in the assembly and allow the spinner nut to tighten up.
The problem here is that if 6mm washers are used, they will not fit over the small amount of 8mm shoulder which is exposed when the prop on its own is installed on the shaft and give a false impression that everything is tight.
soundcheque is offline Find More Posts by soundcheque
Old Feb 05, 2013, 07:13 AM
splais is offline
Find More Posts by splais
Yuma, AZ
Joined Oct 2003
There is a very easy fix for the apc 7x5e prop. Hand ream the hole to 8mm. Then I went to the hardware store and found they sell small, thin nylon washers that have an 8mm hole. I put on two washers, then the prop, then the stock nut. Never had a problem. If you really want to go to the trouble, you can buy a new collet that fits the motor and apc prop without reaming, but why bother.
splais is offline Find More Posts by splais
Old Feb 05, 2013, 11:00 AM
Bring It On !!!!!
Newmarket, England.
Joined Aug 2006
+1 on that.. It really isn't an issue..
Old Feb 05, 2013, 11:49 AM
neilbooth is offline
Find More Posts by neilbooth
neilbooth's Avatar
United Kingdom, England, Kirkby in Ashfield
Joined Aug 2008
Hi all. Does anyone know of a decent motor to go on th f27q. Im running 4s 80 amp turnigy plus and a TGS 7x5e prop. Thanks guys
neilbooth is offline Find More Posts by neilbooth
Old Feb 05, 2013, 12:40 PM
Bring It On !!!!!
Newmarket, England.
Joined Aug 2006
On post 6514 there's a guy who has been using the stock motor with 4s and a 7 x 6 apc.
If you have the stock motor it appears that it will handle 4s.
Aside from that, I have used 4Max in the UK a lot for equivalent motor upgrades.
http://www.4-max.co.uk/
Old Feb 05, 2013, 05:51 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
MJF, neilbooth ,
Attached you can see pic of a Q option MEGA inrunner on a F27Q by way of $12 mount from Custom RC Parts.
MEGA 16/25/2CEQ for 3S and 4S operation
F27Q mount for MEGA inrunner:
http://www.customrcparts.com/index.p...&products_id=4
Don't forget MPI heat sink for high power operation.
Motor can come in several bigger sizes as well....and different KVs.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Feb 05, 2013, 07:17 PM
MJF is offline
MJF
MJF
Waiting Fer Da SEFF
MJF's Avatar
Joined Jul 2010
Thats what IM TALKING 'BOUT JACK>>>>
Old Feb 05, 2013, 07:18 PM
MJF is offline
MJF
MJF
Waiting Fer Da SEFF
MJF's Avatar
Joined Jul 2010
ding ding ding........give that man a prize.....hit it on the head.......thats all ya gotta do...........same thing I did as well
Old Feb 07, 2013, 09:51 AM
neilbooth's Avatar
Joined Aug 2008
Thanks for the advice guys. Think I may go for the mega if I can find 1, I can find a few others but not 2ecq. May have to wait a few weeks as they are pretty pricey lol
Old Feb 07, 2013, 01:54 PM
bladeguy5's Avatar
Joined Jun 2012
GryphonRCU, what kind of speeds are you getting out of that motor?
Old Feb 07, 2013, 09:24 PM
rrg is offline
rrg
rrg
rrg's Avatar
Joined Dec 2007
Enough to bury the WHOLE nose cone ^^^^^
New Product Parkzone F 27Q stryker friz Electric Plane Talk 181 Nov 04, 2011 02:54 PM
Found Parkzone F-27c stryker PNP NIB rcwarrior Aircraft - Electric - Jets (FS/W) 0 Nov 11, 2010 07:48 AM
Question Please Help! Can I use 14.8V 2200mAH on ParkZone F-27C Stryker? rcwarrior Electric Ducted Fan Jet Talk 3 Nov 11, 2010 12:13 AM
Discussion Looking for plans for foamy similar to Parkzone F-27c Stryker CX2Mike Foamies (Scratchbuilt) 5 Oct 24, 2010 01:00 PM
For Sale Parkzone F-27c Stryker PNP or BNF beginner4life Aircraft - Electric - Airplanes (FS/W) 1 Sep 12, 2010 11:02 AM
