I wound up swapping the stock PZ 6-6 for the APC sport 7-5 and the difference was noted. Had it fly right out of my hand using the leading edge launch method.
Got it to spin and did my first parachute drop landing tonight. Amazed at the rate of spin. Lucky I started with ample altitude as I just wanted to watch it's dizzying descent as long as I could. I really wasn't planning a parachute drop but came in a bit high and just kept applying up elevator. Once it stalled it just settled right in. I do need to get an offset neckstrap mount thing as my JR 9303 is a bit "tail heavy. This Stryker (my first) is so much fun I've ordered a 2nd, plug 'n play version for backup. P.S. Found a quick way to add a thick washer for the thinner APC hub. My Stryker is a bit nose heavy so I had a steel Fox prop washer made for a prop extension. It's about 1/8" thick (tapered) and has a ID which fits the PZ prop hub perfectly. The heavier steel washer helps a bit getting the CG back to where it belongs. |
Personally, I think the guys who are stripping the servos aren't bothering to adjust their end points. That will most certainly cause excessive travel that over time will damage them. And it'll damage them faster than if they adjust the end points. Just my $.02 guess.
Here's an unusual question for ya'll. Has anyone tried a wooden prop?
I think someone mentioned it way back in the thread, but reason I'm asking is (to make a super long story short), I'm currently in possesion of about 60 props by Zinger & Top Flite. All are anything from 7x4.5 to 7x8, and there's a BUNCH of 7x5 & 7x6 props as well. (The long story): An elderly member of our club passed away, and we're in charge of inventorying & auctioning all his RC stuff to raise money for his wife & our club. She said she want's 40% of the sales and the rest goes to our club. If these wooden props will work, I'm going to buy them all. |
It was more at the beginning!! |
I love woodies, but IMO it is simply a waste on this belly lander as you will be changing props after every several flights (if not every flight). Buy the props anyway, sell them to your buddies who need them at the field for $4ea and everyone wins! I think those props are probably $8ea retail.
But did you check to be sure they are "electric" wooden props? Ones designed for gas are different... Quote:
Latest blog entry: Burned Retina Shorts
United States, GA, Newnan
Joined Aug 2010
Raceman...pretty cool, bro. So....how do you steer on the ground? Does the nosewheel pivot? Our club has a runway so this might be fun for giggles. |
This is my son's first plane, so I want to do anything to make it easier for him to fly. He's been flying my T-28 and HawkSky and the SIM, but he's still a relative beginner. I did try to discourage him from getting a faster plane, but he had his mind set on the Stryker.
Joined Aug 2010
Thx...I had just found the link at HL. The Q's not that tough to launch, once you kinda get the hang of it. That said, steerable LG on the Q is a novel idea....and kinda kool. A couple more q's if you don't mind...1st, have you flown it both with & w/o the gear? I'd be interested in how she performs in the air; eg- cg, the added weight, the added drag, etc etc Next: takeoff & landings...any suspense w/ these? In sum...my thinking is, what the heck??? As long as I don't have to carve the foam up too much, for $20, some LG could be fun! ![]() Thx for the info Jeff |
Orlando, Fl
Our attempts at hand launching lead to the nose breaking off on our 2nd flight attempt, so that's when I decided to give landing gear a try. No real issues on take off or landing. He had a relatively steep take off angle, but the prop did not strike the ground. The landing was a bit on the rough side (need to work on flaring it at the end). The front gear did bend a bit, but it was easy enough to straighten. The install was pretty easy. The main gear just glued on over the foam, using plywood mounts that I made up. The nose gear went where the belly wheel was. Dug out the foam down to the plastic battery tray. |
| Thread Tools | |
| New Product Parkzone F 27Q stryker | friz | Electric Plane Talk | 181 | Nov 04, 2011 02:54 PM |
| Found Parkzone F-27c stryker PNP NIB | rcwarrior | Aircraft - Electric - Jets (FS/W) | 0 | Nov 11, 2010 07:48 AM |
| Question Please Help! Can I use 14.8V 2200mAH on ParkZone F-27C Stryker? | rcwarrior | Electric Ducted Fan Jet Talk | 3 | Nov 11, 2010 12:13 AM |
| Discussion Looking for plans for foamy similar to Parkzone F-27c Stryker | CX2Mike | Foamies (Scratchbuilt) | 5 | Oct 24, 2010 01:00 PM |
| For Sale Parkzone F-27c Stryker PNP or BNF | beginner4life | Aircraft - Electric - Airplanes (FS/W) | 1 | Sep 12, 2010 11:02 AM |
