Old Jul 18, 2011, 03:38 PM
skyjet is offline
Find More Posts by skyjet
Electric or Bust!
skyjet's Avatar
Mooresville, NC
Joined Mar 2008
I haven't been able to keep up with this tread and the search did not come up with any answers. I have a stripped elevon servo and would like to replace it with a Hitec digital servo. Does anybody have any recommendations?
Any recommendations from any manufacture? I haven't found and close to the same dimensions as the stock servo.
skyjet is offline Find More Posts by skyjet
Old Jul 18, 2011, 04:02 PM
nickelbn1 is offline
Find More Posts by nickelbn1
fly and then fly some more!
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
Originally Posted by dtacmed View Post
1st weekend flying the "Q".
Day 1 aggrivating Tried Overhand power off no luck, sidearm toss with 3/4 throttle 1 successful launch out of 3. Day 1 costs 2 props and a new nose cone.
Day 2 Great !! . Installed the front skid off a old Stryker for the hook and used a friends catapult (a homemade version of FanJet's "Jetapult"). Took care of the launching issues and it really looks cool and is a blast taking off that way. Made one last night for $26.00. The bungee cord is from a $7.99 cargo net from harbor freiight. Just untie all the nots and you have a very long bungee cord. Next is Catapult launched Habu.
I dont know what you are doing but I do the sidearm toss, more of a pull and toss like has been discussed on here a lot and even with zero wind it takes right off straight and away no problems. Done it many times. 75% throttle.
nickelbn1 is offline Find More Posts by nickelbn1
Old Jul 18, 2011, 04:50 PM
Eastcoast78 is online now
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
Originally Posted by murdnunoc View Post
HS65MG would be the bare minimum for this plane.
HS85MG or HS5085MG (digital) would be best if you expect power and speed upgrades.
If they don't quite fit...
dig a bigger hole.
(this is a running theme in Strykers.)
Here you go!!
Eastcoast78 is online now Find More Posts by Eastcoast78
Old Jul 18, 2011, 05:07 PM
pugsam is offline
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
Originally Posted by samste View Post
...Painted underside for better visibilty and orientation from a distance...
Yours looks great.
I'd like to do the same.
Can you share the name of the brand and color of paint you used?
Dave
pugsam is offline Find More Posts by pugsam
Old Jul 18, 2011, 05:14 PM
gr8taz nitro is offline
Find More Posts by gr8taz nitro
lawndart aerobatic ace!
gr8taz nitro's Avatar
Joplin, Misery
Joined Mar 2007
Just an FYI, graupner usa got their prop shipment in and they do have the 6x6, and the 6.5x6.5 cam speed props in stock and ready to ship. Mine are on their way!
gr8taz nitro is offline Find More Posts by gr8taz nitro
Old Jul 18, 2011, 05:22 PM
Dixie Normious
Can A da....Ehh!!
Joined May 2010
Nice..To bad they charge 30 Bucks for shipping too Canada...
So 40ish for 2 Props...lol
I don't think so...
Old Jul 18, 2011, 05:49 PM
Jwhatley is offline
Find More Posts by Jwhatley
Joined Apr 2010
I guess I never realized that hand launching this plane was really an issue. I have my radio on a string around my neck with my left hand on the throttle. I grip the thing with my right hand by the little finger grooves on the belly, power the throttle up to between half and 3/4 throttle, throw the thing over hand pretty hard I guess but not all out or anything and then immediately put my right hand on the controls and take on out. The plane takes a second or two to get some speed and it tends to veer slightly to the left on release but gains speed and altitude pretty quickly. My Q is completely stock and I throw/launch on low rates. You want to make sure you don't pull up too fast and stall it before it gets some speed. Wind does absolutely help but this plane flies pretty true.
I've seen the youtube video of some poor guys fingers all tore up and that really is unfortunate but I think that just makes people all tweaky, nervous and scared. If you over think it, you're much more likely to smash your plane than slice up your fingers. The key, like anything is to be paying attention to what you're doing. Once you do it a couple of times successfully, it's a piece of cake.
Jwhatley is offline Find More Posts by Jwhatley
Old Jul 18, 2011, 06:09 PM
alucard0822 is offline
Find More Posts by alucard0822
alucard0822's Avatar
Pennsylvania
Joined Jun 2010
I posted a lengthy description a few pages back, searc for "HS-85MG" or "servo" and read through the posts. More or less, the HS-85/HS85MG/HS 50-85 digital are almost an exact size match, just a hair longer, and the pigtail comes out in a slightly different spot, just a little foam shaving, and they drop right in. Use the longest arms in a dubro standard length super strength pack, and 3" connector extensions, and they practically drop in, just make sure your hinges and rods don't bind, the hitecs are about twice as strong as the stock servos.
alucard0822 is offline Find More Posts by alucard0822
Old Jul 18, 2011, 06:11 PM
Tom Hunt is offline
Find More Posts by Tom Hunt
got any foam to bash?
Tom Hunt's Avatar
Lake Grove,LI, NY
Joined Aug 2000
Originally Posted by Jwhatley View Post
I guess I never realized that hand launching this plane was really an issue. I have my radio on a string around my neck with my left hand on the throttle. .
Most guys hit their own hand because they do not "follow thru". Pretend you are going to put your hand in your front pocket after the trhow and you will never hit your hand with the prop.
or do what I do... throw the da_m thing hard with the power off. (does require a good throw however!)
Tom Hunt is offline Find More Posts by Tom Hunt
Old Jul 18, 2011, 06:15 PM
rcoconut is offline
Find More Posts by rcoconut
Do you see what I see?
rcoconut's Avatar
Rancho Cucamonga, CA
Joined Sep 2006
Forgive the rookie question, is there a substantial difference in performance between the 6 x 6 and the 6.5 x 6.5?
rcoconut is offline Find More Posts by rcoconut
Old Jul 18, 2011, 06:31 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
yah or else you and I'd be ordering some lol
shipping fees suck
I don't think so...
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Jul 18, 2011, 06:39 PM
Dixie Normious
Can A da....Ehh!!
Joined May 2010
shipping fees suck
Yea i hear yea!!
Old Jul 18, 2011, 06:40 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
has anyone tried the
APC 6.5x6.0 10-15 Pylon Propeller????
or
APC 6.5 x 6.5?
Old Jul 18, 2011, 06:44 PM
skyjet is offline
Electric or Bust!
skyjet's Avatar
Mooresville, NC
Joined Mar 2008
Thanks for the quick feedback. I found your earlier post. Great Info! I miss flying my Q. The HS-85mg's are on my list.
Old Jul 18, 2011, 07:18 PM
Joplin, Misery
Joined Mar 2007
I don't have and first hand so I can't answer that yet, but I'll have some information hopefully by friday. I know the 6x6 should be noticeably better than the stock plastic prop that comes with the Q. I'm running with a 4 cell setup so I'll have to see if the 6.5x6.5 is too much. It may not matter with temps here locally hitting triple digits with heat index's over 105, It may have to wait a while for the weather to cool off.
New Product Parkzone F 27Q stryker friz Electric Plane Talk 181 Nov 04, 2011 02:54 PM
Found Parkzone F-27c stryker PNP NIB rcwarrior Aircraft - Electric - Jets (FS/W) 0 Nov 11, 2010 07:48 AM
Question Please Help! Can I use 14.8V 2200mAH on ParkZone F-27C Stryker? rcwarrior Electric Ducted Fan Jet Talk 3 Nov 11, 2010 12:13 AM
Discussion Looking for plans for foamy similar to Parkzone F-27c Stryker CX2Mike Foamies (Scratchbuilt) 5 Oct 24, 2010 01:00 PM
For Sale Parkzone F-27c Stryker PNP or BNF beginner4life Aircraft - Electric - Airplanes (FS/W) 1 Sep 12, 2010 11:02 AM
