Old Jul 05, 2011, 08:37 PM
wgarman is offline
Find More Posts by wgarman
More Planes Than Sense
wgarman's Avatar
United States, PA, Wexford
Joined Feb 2010
What a Plane!
Picked mine up a week ago and have been waiting for a good day to maiden. Finally yesterday was the day. WOW! What a fun plane to fly! I've only been flying about a year, but after a couple of shaky take offs, I had a ball! Landings went well, too. Can't wait to learn more about flying the great plane.
wgarman is offline Find More Posts by wgarman
Old Jul 05, 2011, 08:50 PM
Buzzed is offline
Find More Posts by Buzzed
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
Originally Posted by Killab View Post
so what do you think smoked the motor? what was the amp draw you were putting out?
Amp draw was around 61. But it's SUPER hot out here in Phoenix right now and I didn't let up on it. We were doing Doppler passes downwind at sunset. Really fun and now all my buddies want one.
Anyway, I was WOT a lot, so I'm sure the magnets may have shifted in the can because it was grinding a bit when I tried to spin it.
I usually fly Scorpion motors in all my planes because they can take the Arizona heat. May look into a Scorpion replacement that can handle my abuse...
-Buzzed
Buzzed is offline Find More Posts by Buzzed
Old Jul 05, 2011, 08:55 PM
chevypower1930 is offline
Find More Posts by chevypower1930
Fly it like you stole it!
chevypower1930's Avatar
USA, NC, Raleigh
Joined Jun 2009
Just had my first 40c flight
This was definitely the best fit battery for the plane performance wise, but I also got my CG dead on this flight. I brought the plane vertical and throw the sticks into opposite corners, and the Q whipped around and went into a perfect flat spin. I wasn't able to get it to do such great flat spins in my past flights.
Anyways, The Q keeps on getting more and more enjoyable, I had it crawling across the flight line at a walking pace, the flight envelope of these wings are ridiculous!
chevypower1930 is offline Find More Posts by chevypower1930
Old Jul 05, 2011, 09:01 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
-Buzzed
I heard 118 degrees in Phoenix the other day. I used to live there. When it's that hot you will burn a motor night flying when it goes down to 98.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Jul 05, 2011, 09:03 PM
AeroControl is offline
Find More Posts by AeroControl
AeroControl's Avatar
Grand Rapids, MI
Joined Mar 2008
Prop suggestions for stock setup
I bent my stock 6x6 prop during my maiden launch learning curve and want to get some spare props. My LHS's don't have any PZ 6x6 props in stock. Does anyone have any suggestions for some alternative props for the stock setup (ESC and Motor). Will an APC 7x5e prop work? I searched through the thread and only found prop discussions for modded setups..... Thanks.
AeroControl is offline Find More Posts by AeroControl
Old Jul 05, 2011, 09:47 PM
alucard0822 is offline
Find More Posts by alucard0822
alucard0822's Avatar
Pennsylvania
Joined Jun 2010
APC 7X5 sport(not thin electric)
Graupner cam 6X6, or speed 6.5X6.5
You need to ream them to 8mm, and either use a 1/8" spacer or the E-flite 5mm adapter, if you use the E-flite adapter, you don't need a spacer, but need to ream the prop to 10mm 1/2 way through with a stepped reamer. Posted the numbers a couple pages back, but these are safe for use with the stock 3S setup, and offer improved performance, the 7X5 has a lot more thrust, the 6.5X6.5 graupner has more thrust and speed. APC makes pylon props that look promising, but seems nobody has found any yet.
alucard0822 is offline Find More Posts by alucard0822
Old Jul 05, 2011, 09:55 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
very nice
I may have to try those sometime.
Originally Posted by Rickn816 View Post
Anderson PowerPoles. You need the crimper, but they are awesome. No soldering.
Rick
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Jul 05, 2011, 10:03 PM
MikeRx is offline
Find More Posts by MikeRx
MikeRx's Avatar
Dallas, Texas
Joined Dec 2009
APC 6.5x6.5" pylon are available from many sources including tower.
The 7x5e is the best prop 3s.
"Sport" (glow) props are best for higher power levels
MikeRx is offline Find More Posts by MikeRx
Old Jul 05, 2011, 10:16 PM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
APC sells direct, in addition to Tower and other online retailers.
http://www.apcprop.com/SearchResults.asp?Search=6.5
6.5" diameter and pitches from 2.9" to 6.5".
5" through 6.5" pitches are in 1/2" increments for fine tuning.
Prices are good on their site and shipping is fair and quick.
No excuses now!
murdnunoc is offline Find More Posts by murdnunoc
Old Jul 05, 2011, 11:01 PM
Eastcoast78 is online now
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
Rick
Id also like too try these as well!!
Eastcoast78 is online now Find More Posts by Eastcoast78
Old Jul 05, 2011, 11:03 PM
Dixie Normious
Can A da....Ehh!!
Joined May 2010
Originally Posted by Benihama View Post
hey alucard
wich Hitec Servos would you recommend for the Q? Dang this Stryker got a realy nice concept but at some points the quality isnt that good
Yea id like too know aswell!! I think i recall someone saying HS55's ,don't quote me on this!!
Old Jul 05, 2011, 11:11 PM
noobiznessflying is offline
Find More Posts by noobiznessflying
Fly more, bitch less.
noobiznessflying's Avatar
United States, CA, Arcadia
Joined Nov 2010
So still having a blast with my Q. I noticed that the fin/landing skids on mine are getting real beat up and have gotten severely flimsy after multiple landings. This is my first Stryker so is this just a normal "wear and tear" part that needs to constantly be replaced or are my landings too harsh? I've probably flown her about 25-30 times already.
noobiznessflying is offline Find More Posts by noobiznessflying
Old Jul 05, 2011, 11:17 PM
Dixie Normious
Can A da....Ehh!!
Joined May 2010
Nice, I'm going too Maiden mine at the field tomorrow!! Im still waiting on my 2200mah's so all i have now is a Nano 1800Mah. So ill should be able too squeeze a 4-5 min Flight. Im going to be taking it easy anyways. Im working on my Wings with the club and the CFI is there lol. I'm also going too Maiden my NextStar .40 Glow!!
Ive been flying for 8 years but only last year decided too join a Club!! There all excited too see the Q!!
Wish me Luck!!
Old Jul 05, 2011, 11:25 PM
Joined Nov 2010
Wish me Luck!!
Good luck man and get ready for an adrenaline rush!
Old Jul 05, 2011, 11:26 PM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
HS65MG would be the bare minimum for this plane.
HS85MG or HS5085MG (digital) would be best if you expect power and speed upgrades.
If they don't quite fit...
dig a bigger hole.
(this is a running theme in Strykers.)
New Product Parkzone F 27Q stryker friz Electric Plane Talk 181 Nov 04, 2011 02:54 PM
Found Parkzone F-27c stryker PNP NIB rcwarrior Aircraft - Electric - Jets (FS/W) 0 Nov 11, 2010 07:48 AM
Question Please Help! Can I use 14.8V 2200mAH on ParkZone F-27C Stryker? rcwarrior Electric Ducted Fan Jet Talk 3 Nov 11, 2010 12:13 AM
Discussion Looking for plans for foamy similar to Parkzone F-27c Stryker CX2Mike Foamies (Scratchbuilt) 5 Oct 24, 2010 01:00 PM
For Sale Parkzone F-27c Stryker PNP or BNF beginner4life Aircraft - Electric - Airplanes (FS/W) 1 Sep 12, 2010 11:02 AM
