Old Jul 05, 2011, 03:48 PM
gatorb8 is online now
Find More Posts by gatorb8
Registered Offender
gatorb8's Avatar
United States, FL, Gulf Breeze
Joined Apr 2008
Originally Posted by Buzzed View Post
Hey Stryker fans!
It was hot and windy here in AZ yesterday. We did some full throttle downwind passes and I got my Stryker up to 131 mph. The 4cell 2200 40c battery, stock prop, and Hacker 55 amp speed control helped me cook my motor though... Ughhh.
So, what motor fit for a 4 cell battery will attach to the stock mount??? I'm sure it's somewhere in this thread, so maybe someone can point me in the right direction.
-Buzzed
P.S. I have a lead thumb!
I'm sure I'm not to far behind you.....
gatorb8 is online now Find More Posts by gatorb8
Old Jul 05, 2011, 04:28 PM
alucard0822 is offline
Find More Posts by alucard0822
alucard0822's Avatar
Pennsylvania
Joined Jun 2010
Originally Posted by Benihama View Post
anyone arround with this servo problem?
you guys think that could be the end of the servo and needs to replace?
http://www.youtube.com/watch?v=RVYRJAEpjEk
Happens on occasion with the EFLR7140 /PKZ DSV130M digital servos, chattering is one of the issues they have. I've had about 3 dozen of them in various BNF models, and have had to swap about half due to failures of one sort or another. They have done everything from fail to center, walk away from center, chatter, strip, the gear shaft pockets wear, inner cases crack, or just flat out fail, all replaced by Hitecs that still run without a single one failing. They hold up OK on the smaller warbirds, but on anything aerobatic where large movements and more stress are involved, they fail early and often. At this point, I figure on replacing them when I am considering most any new aerobatic model, and weigh that into the cost. So far my elevon Stryker Q servos didn'tlast 5 flights before stripping on the right, and failing to center on the left, the rudder servos are still holding up, but for how long, I don't know, hopefully they last, but I'm not counting on it.
alucard0822 is offline Find More Posts by alucard0822
Old Jul 05, 2011, 04:31 PM
kuczy is offline
Find More Posts by kuczy
The Earth got in the way!
kuczy's Avatar
United States, OH, Canal Winchester
Joined Feb 2007
I flew mine 3x's today. I used a 3s 30c 2200, 3s 40c 2200, and the 4s 35c 1800. Stock motor/prop 60 amp ESC. I cleaned up the the battery bay for better cooling and cut away a little foam so the RX, ESC, and Battery all could move back. While the 3s 30c 2200 was by far the weakest speed wise it was the best for stunts. Making the Q do nice spins, parachute, Flip Flop(Don't know what it's called when you go into the parachute then keep going from upright to inverted, upright, inverted), and inverted parachute were all very, VERY nice. The 4s was of course the fastest. I find though that I like the 3s 30c and 40c 2200's better than the 4s. The C always made me want to go faster. With the Q I really end up doing stunts for the entire flight and I love speed. I'll take a pic of my bay later after Baseball is over.
kuczy is offline Find More Posts by kuczy
Old Jul 05, 2011, 04:52 PM
sickwitit is online now
Find More Posts by sickwitit
sickwitit's Avatar
Lewisville, TX
Joined Sep 2010
Hey Stryker fans!
-Buzzed
I really don't think this has been discussed yet, and I'm pretty sure nobody has posted anything about installing an aftermarket motor. It's shocking, but I think you are the first person to ask this question. So far everyone on the forum is still running the stock motor.
sickwitit is online now Find More Posts by sickwitit
Old Jul 05, 2011, 04:55 PM
llcoolg is offline
Find More Posts by llcoolg
Joined May 2007
Originally Posted by thinman View Post
Like this type of launch. Will it work as well with little or no wind?
Bob
Yes it will. I've launched it in low or calm winds before with no problems. Just make sure to give it 3/4 throttle.
llcoolg is offline Find More Posts by llcoolg
Old Jul 05, 2011, 05:09 PM
Killab is offline
Find More Posts by Killab
Youtube Johnbrum26
United States, TX, Celina
Joined Oct 2010
so what do you think smoked the motor? what was the amp draw you were putting out?
Killab is offline Find More Posts by Killab
Old Jul 05, 2011, 05:16 PM
ty_horn is offline
Find More Posts by ty_horn
Philippians 4:13
Seward, NE
Joined Nov 2006
Smoked motors???
ok wait a minute... I thought these things handled 4 cells just fine. Mine comes down just as cool as with 3 cells.
ty_horn is offline Find More Posts by ty_horn
Old Jul 05, 2011, 05:22 PM
Killab is offline
Youtube Johnbrum26
Joined Oct 2010
Originally Posted by ty_horn View Post
Smoked motors???
my buddy temp his at aroung 120 ish and it was about 95-98 out. that was on 3s nanotech battery on a 6 min flight.
Old Jul 05, 2011, 05:31 PM
Registered Offender
gatorb8's Avatar
Joined Apr 2008
I got no data
waiting on replacement props
have and ICE in there so I'll datalog the current, voltage, and rpm
heat is usually the killer, over current or bearings cause it
Old Jul 05, 2011, 05:40 PM
Chrisfunk is offline
Find More Posts by Chrisfunk
semi skilled noob
Joined Jul 2011
Bob
I bent my nose trying to launch with zero throttle on my maiden. I was gutted that I'd spoilt it before getting it in the air. Just been out tonight in no wind at all and launching at 3/4 power and aiming slightly up, about 10 degress above level perhaps, which seems to give me just enough time to get my right hand back onto the stick to correct any roll.
oh, also, i adjust my elevator trim slightly to give a little lift then adjust it back to centre during flight. my stryker seems to want to dive a little at low / mid speeds but climbs by itself at high speeds, not sure if that's normal? so i can do a massive loop at high speed with no stick input, yet when slow for landing i need to pull back ever so slightly to keep her level, ummmmmm.
Chrisfunk is offline Find More Posts by Chrisfunk
Old Jul 05, 2011, 05:54 PM
Benihama is offline
Find More Posts by Benihama
Joined Jun 2011
Hey Stryker fans!
-Buzzed
i guess its importand to use the right prop on 4s. i used an cam speed 6x6 and the motor realy gets hott compared to 3s. now i allways change the prop for the different batterys. 3s = 6x6 or 6.5x6.5 4s = 6x5.5
the motor on 4s with 6x5.5 got like no differenz on temperature
Benihama is offline Find More Posts by Benihama
Old Jul 05, 2011, 05:56 PM
pugsam is online now
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
Originally Posted by Chrisfunk View Post
....oh, also, i adjust my elevator trim slightly to give a little lift then adjust it back to centre during flight. my stryker seems to want to dive a little at low / mid speeds but climbs by itself at high speeds, not sure if that's normal? so i can do a massive loop at high speed with no stick input, yet when slow for landing i need to pull back ever so slightly to keep her level, ummmmmm.
Maybe it would be useful to have a throttle/elevator mix. Very slight -- just a few percent. Trim her for level flight at 50% or 75% throttle -- and the mix would help keep her level at WOT with neutral elevator (and help keep the nose up at low throttle for landings).
What do you guys think?
pugsam is online now Find More Posts by pugsam
Old Jul 05, 2011, 06:02 PM
Benihama is offline
Joined Jun 2011
hey alucard
wich Hitec Servos would you recommend for the Q? Dang this Stryker got a realy nice concept but at some points the quality isnt that good
Registered Offender
gatorb8's Avatar
Joined Apr 2008
I got no data
I datalogged my bent prop
51.7Amps
14Volts
725 Watts
25015 RPM
6" prop pitch speed = 142 mph
edit: forgot to add, I'm at 9000' elevation, current will probably be higher at lower elevation
Old Jul 05, 2011, 06:06 PM
kissfan is offline
Find More Posts by kissfan
kissfan's Avatar
Muscle Shoals, Al.
I think himax may have a motor option that will work.
kissfan is offline Find More Posts by kissfan
New Product Parkzone F 27Q stryker friz Electric Plane Talk 181 Nov 04, 2011 03:54 PM
Found Parkzone F-27c stryker PNP NIB rcwarrior Aircraft - Electric - Jets (FS/W) 0 Nov 11, 2010 08:48 AM
Question Please Help! Can I use 14.8V 2200mAH on ParkZone F-27C Stryker? rcwarrior Electric Ducted Fan Jet Talk 3 Nov 11, 2010 01:13 AM
Discussion Looking for plans for foamy similar to Parkzone F-27c Stryker CX2Mike Foamies (Scratchbuilt) 5 Oct 24, 2010 02:00 PM
For Sale Parkzone F-27c Stryker PNP or BNF beginner4life Aircraft - Electric - Airplanes (FS/W) 1 Sep 12, 2010 12:02 PM
