Old Mar 31, 2011, 01:13 PM
TeeJayBee is offline
Find More Posts by TeeJayBee
United Kingdom, Swansea
Joined Mar 2011
Look what Fedex brought
It's an Art Tech Genius 500, it's going to be very frustrating not being able to fly it until I've gone through all the on ground training here:
http://www.dream-models.com/eco/battery01.html
But I'm sure it'll be worth it in the end
Yes I know it's not the best 500 machine out there but I wasn't going to spend 1000 on what is basically a stepping stone to a Quad/Hexacopter
It's basically a training aid, but you never know I might get addicted
It is supposed to be fully ready to fly out of the box but I'd like to check it over before spinning it up, I can check blade balance and tracking but I think I'll need a pitch guage and look up instructions on what to do with it ?
TeeJayBee is offline Find More Posts by TeeJayBee
Reply With Quote  (Disabled)
Old Mar 31, 2011, 03:24 PM
kkellyheli is offline
Find More Posts by kkellyheli
Joined Mar 2011
ahhhhhhhhh....shes beautifull !!!
kkellyheli is offline Find More Posts by kkellyheli
Old Mar 31, 2011, 04:34 PM
Frank_fjs is offline
Find More Posts by Frank_fjs
2011 - Year of the clones!!!
Frank_fjs's Avatar
Australia, SA, Adelaide
Joined Nov 2010
Wow, she's big.
Interesting head. Are the blades clamped down with some sort of rubber?
Frank_fjs is offline Find More Posts by Frank_fjs
Old Mar 31, 2011, 05:40 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
It has a spacer which allows for inconsistency in the blade grips.
At least maybe it will liven up a town that is obviously looking for something to do...
This isn't really news is it? I mean, probably this house has been there for years, right?
http://www.dailymail.co.uk/news/arti...f-parting.html
jasmine2501 is offline Find More Posts by jasmine2501
Old Mar 31, 2011, 05:53 PM
Joined Mar 2011
Wow, she's big.
Not as big as most 500's, she's more like a 475 (yeah I know there's no such thing but it's between a 450 and 500 in physical size)
Some great Youtube clips, not that I'll be doing any 3D stuff, just want to develope smooth and controlled flight on instinct without having to think
Only time I'll ever go into Idle Up mode is when I want to learn autorotation to get out of trouble
Old Mar 31, 2011, 09:06 PM
chopper62 is offline
Find More Posts by chopper62
Joined Apr 2008
Congrats! Before spooling it up for the first time, please go over all bolts (without nylon nuts) for loctite.
Next, adjust the blades to "0" degree pitch at mid-stick and then adjust the high and low to be the same, whatever degree fitting your needs. Then check for cyclic pitch, running between 6 and 8 degrees.
Don't forget to set throttle hold and then fail-safe just in case the rx goes out. You want to set it so that the throttle goes to "no throttle" and blade pitch goes to zero degree.
chopper62 is offline Find More Posts by chopper62
Old Mar 31, 2011, 09:13 PM
arbilab is offline
Find More Posts by arbilab
Fly Runaway Fans
United States, TX, Fort Worth
Joined Jan 2009
Oh man CS, you are giving me delivery envy. Come back and tell us how it flies.
arbilab is offline Find More Posts by arbilab
Old Mar 31, 2011, 10:35 PM
Rocket Programmer
Joined Jul 2007
Yeah that's the problem with RTF helis... first you have to take them apart and build them again... so they can actually be more work than a kit. Good for noobs though because it's easy to see how everything goes together.
Seriously... re-threadlock everything down to the swash plate balls even...
Old Apr 01, 2011, 05:00 AM
hedgeheli is offline
Find More Posts by hedgeheli
hedgeheli's Avatar
Bournemouth - UK
Joined Feb 2009
Nice feeling opening the box and there she lies Looks like a good positive start, looking forward to the first spool up.
hedgeheli is offline Find More Posts by hedgeheli
Old Apr 01, 2011, 06:33 AM
Joined Mar 2011
Cheers folks
I spun her up after taking advice and checking all the nuts/bolts
I also had to double check the TX settings to make sure they were as set by the factory tester, all OK
I've had to put nylon tie wraps round the skid rubbers so that it doesn't grip the floor while I'm practicing walking it on the floor, I'm going to get to doing those excersises later today (quick finger count, yes all there at the moment, I'll check again later )
Oh by the way, great help and advice from the UK distributor for Art Tech - Century UK, they had taken the trouble to note down the correct TX settings in PDF format and pointed me in the right direction
Old Apr 01, 2011, 07:54 AM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
I guess you can give that Solo Pro to your wife now!
Balr14 is offline Find More Posts by Balr14
Old Apr 01, 2011, 10:44 AM
Rocket Programmer
Joined Jul 2007
Cool... looks like the bargain basement is coming up a little bit - that's good.
I don't advise doing the RADD-skidding thing - just get a simulator and learn to take off normally and hover it. I am no longer sure what the RADD skidding thing is about. I used to advocate it, but I've changed my mind about it, as I haven't actually seen any benefit of it, over just bunny-hopping around. The simulator is the best training tool other than the helicopter itself. I teach RADD myself - but nobody wants to stay on the ground, and I no longer see the benefit of scooting around, as it's not any easier than hovering with training balls on, and the helicopter isn't going to react the right way on the ground - particularly the newer ones.
Old Apr 01, 2011, 01:24 PM
Joined Mar 2011
Yes that's kinda true Jasmine
It does help to familiarise yourself a little with the sensitivity of the controls (to a degree)
It is designed for people who have never held a transmitter in their hand before though, so I may well be skipping a tiny bit ahead and weather permitting put my training gear on and do a battery or two on hovering, then move onto hoving left in and right in and if I can the batteries charged quick enough by Sunday PM I may be flying 2ft left to right and visa versa, the discipline in my mind will be that if it gets out of control at any point that's 35 for new blades
Oh yes bargain basement stuff is right
These retail at 279.95 over here (about $449), I bought it from a guy who had purchased it a month ago and hadn't flown it, he also threw in the extra battery and training gear
All for 132 ($212), as things over here are always more expensive, roughly $1 = 1 that's the equivalent of you paying $132 for it
Old Apr 01, 2011, 05:41 PM
Joined Mar 2011
Well it's too damned blustery out there (for a novice first flight0 even with the training gear on
Had a go but the controls are far too sensitive for my skill level yet
I'll have to try again on a calmer day or find a 20ft square indoor area (not likely)
Old Apr 01, 2011, 06:16 PM
james1300 is offline
Find More Posts by james1300
james1300's Avatar
Joined Feb 2011
Wow! Its got BALLS! BIG Orange ones! Congratulations! Have fun!
james1300 is offline Find More Posts by james1300
Discussion Look what Santa brought me! Ranfred Radius Scale Sailplanes 87 Aug 29, 2011 10:56 AM
Discussion Look what the postman brought! wparsons Racing Boats - Electric 52 Oct 13, 2010 09:04 PM
Yippee! Oh SNAP!!!! Look what the USPS brought. I'm Rick James Slope 14 Apr 30, 2006 11:42 AM
Look what Santa Brought!!! DbleX Fuel Warbirds 7 Dec 29, 2005 12:51 PM
Look what the NY Blizzard brought me. LESLIEx317537 Parkflyers 12 Feb 20, 2003 02:31 PM
