United States, NY, Shelter Island
Joined May 2011
Sorry to hear of the demise of your spitfire. I liked the Reno racer look. Got any video of the new paint scheme in the air. I agree that this plane is grumpy. 900mm planes are not versatile like the bigger 1400mm versions. The larger they are the more forgiving and well behaved they are. This plane definitely likes a coordinated turn and is a pain in the ass to land. I've glued my rudder and wing tips as she is is rough and tumble on landing. Mine is still together but I'm on my 3rd prop. Everything else still stock 1300mAh battery, gear removed. Harold |
ArtTech HobbyKing Spitfire
Hi and I have to make an corection. About flying this plane mine was very very stable in the air and gentle when landing it. I had no problems flying it and even with less speed she was easy to fly. I think it's because I flew it with 3S2200 and when it;s balanced than she flies like a dream.
I in the proces of rebuilding the plane but the nose part is realy damaged and a lot of parts Ha ha but I will manage this also. I will let you know after I managed to get in in the air again about my findings. greets hans |
Motor update arttech/hobbyking spitfire
I can say this is the real thing for this plane. greets Hans |
update rebuilding my Spitfire
Hi Spitfire fans
I couldn't trow my spit into the trash and I am not an person to give up that easy. So my spit is almost ready to fly again. At pics you can see it really has some beating of flying the Battle Of Britain haha I'm waiting for my new RCVR and than I will perform a new test flight ...... if you see my spit now you couldn't imagine that front of plain was one mess. I giant puzzle but as you can see I did full fill my task. So next time flying this wonderful plane greets Hans |
Having fun flying Spitfire
Thanks for reply and great to hear that you both will fly Spitfires. A flier at our club also has an PZ and we fly together sometimes. By the way I also fly Durafly Hobbyking and a Ripmax Spitfire....yes I'm a Spitfire addict ha ha..... ![]() greets Hans
Spitfire Comments
Flown my Hobby King (HK) Spit a few times now and have some observations and comments for the Group. Nicely detailed plane but it's still an HK/Art-tech machine. Down on power and lacks a decent landing gear.
I've broken one strut just trying to straighten it out on the bench. Those meager spot welds really compromise the integrity of the wire strut even though they're buried in those mock plastic housings. Had to use cold weld epoxy and additional landing gear wire to get it back together. I've tried three props, the stock OEM tri-blade, an APC 10E7, and an APC 9E9 all using the stock power train. Out of all the props, the 9E9 is working the best but still not satisfactory for a (semi) scale warbird. In my humble opinion this little plane should have unlimited vertical right out of the box but no such luck. For this reason I decided to upgrade the motor with one that's a direct bolt-on replacement from Hobby Partz for the Airfield Hellcat. It's the brushless Motor for their F6F 1100mm 1050kv. http://www.hobbypartz.com/93a806-10-brushlessmotor.html Not a huge jump in size but better than the stock 700kv motor. Also put in a 30A ESC to help with the increased power output of the "bigger" motor. I'm also using 1800 mAh batteries for a little longer flight times than the (recommended) 1300's. Had some issues trying to get a 2" Dubro plastic spinner set up to work but I think I've got that handled. I'm using parts from an E-flite prop adapter and it seems to be holding on the threaded shaft securely now. I haven't flown it with the new power set up but if "feels" like it's got more guts than before. I'm also going to experiment with flaperons to see if that makes any difference for lowering the airspeed for landing approaches. In stock form it flies OK, but it's very underpowered. Hopefully, these latest mods will wake this lil' warbird up and get some unlimited vertical in the mix. Landings need to more speed than typical sport planes but (not) too much more. Just need to be a little more conscious with the throttle to get the plane to settle into a nice glide angle. Looking forward to my next flights with the new power train set up and the 9E9. I'll let you know how it goes. |
motor modification
http://www.rcgroups.com/forums/showp...2&postcount=22 http://www.youtube.com/v/O72v5fLiqLc?version=3&fs=1 greets Hans |
| Thread Tools | |
| Discussion Art-Tech Spitfire | Ta152 | Electric Warbirds | 30 | May 24, 2011 01:25 PM |
| Discussion Reinforcing Art Tech Spitfire | ttuzun | Electric Warbirds | 1 | Aug 11, 2009 03:51 AM |
| Discussion Art-Tech Spitfire ad at Hobby Lobby | Ta152 | Electric Warbirds | 14 | Apr 15, 2009 02:46 PM |
| Discussion Art Tech Spitfire. | Atra | Parkflyers | 0 | Sep 23, 2008 04:23 AM |
| For Sale Art Tech P-51 RTF & Parkzone Spitfire RTF; Price Reduced | Codehead | Aircraft - Electric - Airplanes (FS/W) | 2 | May 06, 2008 11:07 PM |
