No Edge767,
I really don't want to get into even mini-mass production . Either buy one of the many commercially available (though it is hard to get good ones already painted) or make your own! It was easier than I expected and the materials required (like the original pilot!) you either have already or are easily obtainable. The skills learned are very useful in general modelling. For painting the pilot I followed this very useful guide: http://www.justpilots.ca/painting_guides-LUFT.htm You just need a good magnifier, a fine brush and a reasonably steady hand, but mistakes with acrylics you just wipe off with a damp cloth. I attach the instrument panel .jpg, which is just a photo of the real thing printed at the right size and of which there are many available with a web search Best of luck
Joined Jul 2008
I want to upgrade the Spitfire's stock bell motor to another bell motor, 900kV, same dimensions, same mount. What's the best way of doing it?
Accessing the 3 screws on the bell motor mount is impossible with the huge bell in the way. So is it better to remove those 4 smaller screws that secures the plastic mount to the firewall, in order to get the old motor out? Or should I just loosen the set screw on the old bell motor mount, and just "change the bell", so to speak? |
Joined Jul 2008
But unluckily, the new bell motor could not fit into the metal mount of the original bell motor. Anyway, turns out I had no choice but to remove the original bell motor, mount and all - which involves removing the attached plastic mount as well... Good news is that the new motor is IN, with a 30A ESC, and it is really charging up the Spitfire! This new motor is a 900kV meant for the Art Tech 1100mm F6F Hellcat...
Correct CG question
My neighbor just ordered this as an ARF and it didn't come with a manual. I found one in Chinese online and it says 11 - 11 1/2" from the front of the nose cone...
I thought that odd as CG is usually measured from the leading edge of the wings. Anyway...can you tell me what the proper CG measurement should be. Running stock with the 1300mah stock battery and the pilot in. Much appreciated! |
Australia, SA, Aldinga
Joined May 2012
Prop/Spinner Advice
Morning all
First post. Relatively new flyer here. Dabbled a few years ago and used to fly control line when I was a kid. Now I have the bug (doesn't my credit card know it!, but hey, I can afford to indulge myself.) So far I am learning on a Mini-Swift and a Wilga 2000. These are my crash and smash learners :-). Using a Turnogy 9x and a DX6i. I have ordered this Spit (and a P51, both Art Tech) and also have a T28 sitting in the spare room as well. I have recently discovered that the prop is the most consumable item; not surprising really. So, I want to keep the original props on both planes for static display (especially as they'll sit on my storage rack for a few months while I compete my training) but have been trying to work out which prop/spinner to buy (2 bladers) to use when I actually get around to flying these 2 planes. Seems 10x5 (Spit) and 10x6 (P51) are good options from what I have been reading. Question is, will either of these 2 options do for both planes? And what spinner will suit? Is a prop adapter required? I have no idea about these things. And the more I read and look on here and the HK website, the more confused I become. I'm also trying to consolidate my HK Hong Kong purchases so i'm not putting in an order every week. Not looking for speed so much. Scale flying is more my style at this stage. Any advice appreciated. Thanks Mike |
Hi Mike, been there and done this!
The Art Tech Spit is a nice plane. The big question on Prop/Spinner is whether you will use it with or without wheels. My l/g (the plastic bit under the wings) broke on the first grass landing so I was forced to go without gear, but I was going to do this anyway as the plane looks much better in the air without it. If you land on a paved strip it is a different story. Anyway, post your reply and I will respond if you plan to land on grass without the l/g - the other I have no experience with. |
Well, I use a this 10 x 5 APC type prop from HobbyKing and a 50mm spinner that I bought at a Hobby fair, but have since seen through Google. I actually mount my prop via home made adapters on a prop saver, but you could probably get away with a standard mount as the APC type props are quite tough. The eternal curse of mounting props is that most prop mounts are in metric while most prop rings are in imperial - who knows why! You need super accurate drilling or good luck to drill out props.
Best to use a prop reamer instead of a drill to keep centered |
| Thread Tools | |
| Discussion Art-Tech Spitfire | Ta152 | Electric Warbirds | 30 | May 24, 2011 01:25 PM |
| Discussion Reinforcing Art Tech Spitfire | ttuzun | Electric Warbirds | 1 | Aug 11, 2009 03:51 AM |
| Discussion Art-Tech Spitfire ad at Hobby Lobby | Ta152 | Electric Warbirds | 14 | Apr 15, 2009 02:46 PM |
| Discussion Art Tech Spitfire. | Atra | Parkflyers | 0 | Sep 23, 2008 04:23 AM |
| For Sale Art Tech P-51 RTF & Parkzone Spitfire RTF; Price Reduced | Codehead | Aircraft - Electric - Airplanes (FS/W) | 2 | May 06, 2008 11:07 PM |
