Old Aug 12, 2003, 10:54 AM
dmelton is offline
Find More Posts by dmelton
Joined Jul 2003
Can I build a battery pack from these cells?
I have a some cells here that I took out of a busted laptop battery pack, the pack had been in a laptop that was damaged and the pack shell was unusable so my brain went to work thinking about salvageable RC stuff. The laptop battery pack was labeled "NiMH Li-ION" I got a total of 8 cells out of it. Each cell is covered in a light green wrap. The only marking on the individual cells is "0303N", each cell is almost an inch longer than a typical AA cell. My question is, how do I wire these cells up for a rc airplane pack? Is it possible? I have a NiCD/NiMH charger at the house and a Slow Stick plane, could these be made into packs suitable for Slow Stick use? Anyone got a web page that shows you how to build packs? I have no idea what the mah rating of these cells would be nor do I know the voltage.
Thanks!
dmelton is offline Find More Posts by dmelton
Old Aug 12, 2003, 11:01 AM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
==battery pack was labeled "NiMH Li-ION" ==
That seems odd, NiMH and Li-on cells are two different types of cells. I would think they're NiMH because of the number of cells though. I'd be hesitant to make a flight pack out of those unless you know exactly what they are, you can't charge li-on cells on a NiMH charger and could even blow them up if you tried!
Moving over to Batteries and Chargers...
Tres Wright is offline Find More Posts by Tres Wright
Old Aug 12, 2003, 11:54 AM
Terry S is offline
Find More Posts by Terry S
Terry S's Avatar
Bridgwater, UK
Joined May 2003
I think they are NiMh cells too. It seems you have a thermal fuse there which is normal for these, a LiIon cell normaly has some electronis instead. If you check the cells on a meter you can find out, over 1.4v and you have LiIon unless they are flatter than flat !
Terry
UK
Terry S is offline Find More Posts by Terry S
Old Aug 12, 2003, 01:38 PM
dmelton is offline
Joined Jul 2003
They measure 1.2v on a fluke voltmeter, could I wire them in a set to get to 6volts?
Old Aug 12, 2003, 03:02 PM
dmelton is offline
Joined Jul 2003
Ok, they're definitely NiMH cells, 1.2V each, I think if I wire 4 together it might make a nice little flight pack. I'm going to try it and see how it works.....carefully.
Old Aug 13, 2003, 09:12 PM
dmelton is offline
Joined Jul 2003
Update: I built a small pack out of 4 of these cells. Total voltage measured about 5v. I charged it on my Intellipeak Pulse charger at the 1.0 setting and then tried it on my slow stick. It worked, sort of. It would power the servos just fine but would only push the prop speed to what I would think is about 1/2 throttle when I'm using my regular 600mah 7.2v NiCD GWS pack. If I wire 6 of them together to get near 7.2v would it up my throttle ability?
I'm using a standard GWS Naro flight pack.
Thanks!
Derek
Old Aug 14, 2003, 09:03 AM
Dylwad is offline
Find More Posts by Dylwad
Dylwad's Avatar
Phoenix,Arizona, United States
Joined Jun 2002
your regular 7.2 volt nicad pack is 6 cells, so yes you can make a 6 cell pack out of your new cells, you could even make a 7 cell and it wouldnt hurt much, just make sure the cells are close to the same voltage when you make your pack, and slow charge them to even out the voltages.
Dylan
Dylwad is offline Find More Posts by Dylwad
Old Aug 14, 2003, 09:06 AM
dmelton is offline
Joined Jul 2003
I made a 5 cell hump pack out of the cells, weird thing is, it would power the servos but not the engine. Any ideas why? Total voltage was about 6.2v
Old Aug 14, 2003, 09:56 AM
flatfour is offline
Find More Posts by flatfour
Right Honorable Member
flatfour's Avatar
Chicago Midway, Illinois, United States
Joined Jul 2003
A 5 cell pack is probably not enough for the low voltage cutoff of your ESC
flatfour is offline Find More Posts by flatfour
Mini-HowTo How To Build a Battery Pack from A123 Cells LBMiller5 Batteries and Chargers 460 Sep 15, 2013 01:35 PM
can I make a battery pack with 600 & 700 mah cells pc_pilot Batteries and Chargers 1 Apr 13, 2003 03:37 PM
Can anyone tell me what these cells are NIMH marked NT121AAM 1200 mAh The Other Dave Power Systems 3 Jun 04, 2002 10:07 PM
separate battery pack for 10 cells gliderdude Electric Heli Talk 0 Feb 02, 2002 11:57 PM
Can a CP8x1300SCR battery pack handle up to 40 amps? Ryan Nau Power Systems 3 Jan 31, 2002 07:30 PM
