Old Nov 29, 2011, 01:38 PM
SalamSyed is offline
Find More Posts by SalamSyed
Fly Low-Fly 3D-Fly Often
SalamSyed's Avatar
United States, DC, Washington
Joined Oct 2009
Voted! I would love to have an Extra MX around 70ish, 30CC equivalent electric for a 6 or 8S setup.
SalamSyed is offline Find More Posts by SalamSyed
Old Nov 29, 2011, 02:36 PM
ultimatetwo is offline
Find More Posts by ultimatetwo
Fly to live- Live to fly
ultimatetwo's Avatar
ROTA-CADIZ-SPAIN
Tx, very, very much Radio Rokie for that superb build up and flying report....
Good news.
I will open also a blog-thread of this bird on the spanish forums but my wife says now I must wait until Chmas. Anyway I need yet some spare parts like Savox servos on tail and motor...
Enjoy this bird my buddy...
Manolo.
ultimatetwo is offline Find More Posts by ultimatetwo
Old Nov 29, 2011, 02:41 PM
aerofundan is offline
Find More Posts by aerofundan
aerofundan's Avatar
Panama
Joined Jul 2005
Me too!!!
aerofundan is offline Find More Posts by aerofundan
Site Sponsor
Old Nov 29, 2011, 03:29 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
70 mx would be pretty neato for sure. them sized planes are the shizzle.
Manta1 is offline Find More Posts by Manta1
Old Nov 29, 2011, 04:54 PM
HaventFlownSince2014 is offline
Find More Posts by HaventFlownSince2014
DFC~ We Do Flyin' Right
HaventFlownSince2014's Avatar
USA, GA, Atlanta
Joined Nov 2008
Thanks RR! Cant wait to see you work it out in BT's next vid!
HaventFlownSince2014 is offline Find More Posts by HaventFlownSince2014
Latest blog entry: New Drone Movie :D
Old Nov 29, 2011, 04:56 PM
USA, GA, Atlanta
Joined Nov 2008
70" AMR... would be record-breaking light weight for a bipe in that class
Old Nov 29, 2011, 05:00 PM
kanans is offline
Find More Posts by kanans
United States, MN, Waconia
Joined Mar 2011
Does anyone know if there is a plane on Pheonix 3.0 that flies similar to the Bandit?
kanans is offline Find More Posts by kanans
Old Nov 29, 2011, 09:24 PM
awry is offline
Find More Posts by awry
awry's Avatar
Norway, Rogaland, Sandnes
Joined Oct 2009
I'd definitely buy that!
awry is offline Find More Posts by awry
Old Nov 29, 2011, 11:59 PM
Radio Rookie is offline
Find More Posts by Radio Rookie
Joined Jun 2006
Thank you for your kind words guys. Yup I am sure I will love the Bandit even more after a few more flights. Been a little cautious on the maiden since I really did not have enough sleep the night before and wasnt quite 100% behind the sticks when I was flying her.
The videos will have to wait the return of BT which is scheduled for either jan or feb. By then the rest of the Banditos....ammmm.... I mean Mafia should be in full force.
Shall we call the next Mafia movie:- Ali Blubber and the Forty Bandits?
Dan,
You know which size I am gonna vote for right? Wink...wink!
Radio Rookie is offline Find More Posts by Radio Rookie
Old Nov 30, 2011, 05:11 AM
Precision Aerob is offline
Find More Posts by Precision Aerob
Precision Aerob's Avatar
Sydney Australia
Joined Jun 2004
FiberFusion
Originally Posted by cayars View Post
I don't get the whole "FiberFusion" thing. Sounds like more marketing to me then anything else. Carbon is used by many manufactures.
Well, since you brought the subject of FiberFusion® up along with photos of different brands to compare, I have a lot of say as the designer of Precision Aerobatics planes.
To answer you, FiberFusion® is certainly not a gimmick but an accurate construction method that saves on weight and creates a lot more rigid planes.
It takes me a LOT of hard work to design each part. One bulkhead can take a week of designing sometimes. A small part for the fuselage (approximately 25mm/1” part) took me a full day of work to complete just the other day! So in times it can be quite challenging. If it was just a gimmick to impress, it would have taken me a friction of the time.
To get some better understanding of our designing philosophy you need to go back in time and compare other brands airframes to ours. Then you will see the “changes” other brands did on their planes. Sure they were “inspired” by PA, but at the end of the day, no one is inspired by a sheer gimmick. It’s the strength and other qualities that are inspiring others.
Apart from FiberFusion® construction which we developed, did you know we were the first to supply Carbon Fiber wing tubes on our EP planes (in fact all of our planes)? Back in 2005 when we started production of the Katana Mini, you could only find aluminum wing tubes in small planes - if at all as most small planes had one piece wing. CF wing tubes were only available as aftermarket upgrade for some giant scales. Now CF tubes are industry standard but still most factories supply fiberglass/phenolic wing sleeve, not like PA’s ones that are fully carbon. In fact, most factories wing tubes are not 100% carbon but a mix with fiberglass. Needless to say ours is 100% carbon.
Same happened with CF landing gears. We were the first to make them for small planes as part of our kits. Do the search…
Also we are the only factory that really makes high temperature CF LG in house (our own designs of course) while other companies buy LGs from one manufacturer in south of China (this is why they look alike, same molds).
To describe FiberFusion® construction in a short paragraph as accurate as possible would be the one we use on our website:
FiberFusion® aircraft construction is a sophisticated engineering method, pioneered and developed by Precision Aerobatics. Each variance of fiber used in our models is carefully selected and utilized in a unique way seen ONLY in Precision Aerobatics models, resulting in a much lighter yet stronger and more rigid aircraft that will fly like nothing else!
FiberFusion® is a lot more than adding carbon into the structure. It is not just a concept but a complicated engineering combining all the materials together along with the fibers of each one with the understanding of each of these materials, not just CF. Even the wood parts are highly designed in our planes. It is certainly not just throwing in some CF pieces to impress. Even things that may seem like a gimmick (as you mentioned the battery tray) are done in a certain way to make the plane light and at the same time extremely strong.
There are different ways to design the planes and construction (out of any material) if one knows how to engineer.
Give you one example; on the project I am completing now, I have been designing six different tray options (RX/rudder servo) in order to achieve what I was after. Each of them uses different materials and different grains (and of course they look different too). Parts can be designed from balsa, ply, L. ply, CF and any other material available if one knows his craft. They can all be good and impressive;
One thing though, looking at some online photos of the imitations out there I can tell you that most of them are nothing but a gimmick! The application is incorrect, the material is incorrect, and the engineering is incorrect. Just putting some CF or fiberglass parts doesn’t make a plane more rigid but actually heavier! That might impress the unskilled eye.
Looking at the trends of this industry over the last few years is very interesting. It shows you how much PA influenced the market and this answers better than any words I can post here why FiberFuion® is a lot more than a gimmick. And of course our planes don’t offer just construction, there is a lot more to it.
Shaun
PA Team
Precision Aerob is offline Find More Posts by Precision Aerob
Site Sponsor
Old Nov 30, 2011, 07:25 AM
Cuba is offline
Find More Posts by Cuba
Joined Mar 2010
Shaun
PA Team
Excellent post Shaun!
KUTGW and get in touch with me when you have some time.
Jakub
Cuba is offline Find More Posts by Cuba
Old Nov 30, 2011, 07:57 AM
Willie T is offline
Find More Posts by Willie T
What goes up, will come down..
Willie T's Avatar
United States, FL, Zephyrhills
Joined Jun 2011
Mine arrives tomorrow and I am looking forward to my first venture into 3D. I chose this model after much research and am looking more at the slower flight capabilities to begin with. I have seen other PA planes where I fly and am very impressed by the attention to detail. This will be my first PA plane but most likely not my last.
Willie T is offline Find More Posts by Willie T
Old Nov 30, 2011, 09:51 AM
Arcturus97 is offline
Find More Posts by Arcturus97
Retreating Blade Stall
Arcturus97's Avatar
United States, VA, Woodbridge
Joined Apr 2011
Willie - I'm pretty much in the same situation as you, though mine arrives today and I've had a cheap foamy 3D plane
Arcturus97 is offline Find More Posts by Arcturus97
Old Nov 30, 2011, 09:56 AM
Willie T is offline
Willie T's Avatar
Joined Jun 2011
Should be a fun time......Nerve racking at maiden though!!!!
Old Nov 30, 2011, 10:44 AM
dnahas is offline
Find More Posts by dnahas
dnahas's Avatar
USA, TX, Allen
Joined Jan 2011
Add me to the list of new Bandit owners in direct relation to the comments of repairs to the fuse. I smacked my "other brand" 51 good and ripped the spar tube out and a good bit of the balsa in the area. Sure it could be fixed, but not by me. My interest in the Bandit started by the fact that the other brand does not offer replacement fuses.
The Black Friday coupon was enough to get me to pull the trigger, thanks PA!
dnahas is offline Find More Posts by dnahas
New Product Precision Aerobatics Addiction X Official thread / Video just posted!!! aerofundan 3D Flying 5749 Feb 05, 2016 01:40 PM
Discussion Anyone else wish Precision Aerobatics would make a larger electric 3D monoplane! Neil_SC 3D Flying 19 Sep 24, 2014 12:14 PM
Wanted Precision Aerobatics Katana MD or Precision Aerobatics Mini Katana mixer911 Aircraft - Electric - Airplanes (FS/W) 5 Jul 16, 2009 01:52 PM
Found 3d hobbyshop/precision aerobatics/greatplanes**3d yak/suk/katana/edge/extra helifryer Aircraft - Electric - Airplanes (FS/W) 10 May 20, 2009 10:13 PM
Discussion Precision Aerobatics How To Series, 3D Aerobatics & Repair Guide aerofundan 3D Flying 22 Jan 03, 2009 10:52 AM
