Old Nov 08, 2011, 05:39 AM
poring's Avatar
Joined Jun 2006
Nice shots. I like the plane coming straight at the camera.
poring is offline Find More Posts by poring
Old Nov 08, 2011, 04:07 PM
I'm torquing to you!
Mr Kamikaze's Avatar
Wattle Grove NSW Australia
Joined Nov 2006
Originally Posted by bring the thunda View Post
Hi guys,
all done and ready for the maiden tomorrow if the weather is good
Geez the blue sure is a sweet colour. How did the maiden go with that motor?
Mr Kamikaze is offline Find More Posts by Mr Kamikaze
Old Nov 09, 2011, 03:50 AM
Jerry McFlyer-Show Me The Lipo
bring the thunda's Avatar
Australia, QLD, Gold Coast
Joined Dec 2010
Hi Mr K,
It certainly was interesting
Even with the lipo as far forward as possible, the CG was too far back and this made the elevator super sensitive for the first flight.
I had to add 57g of ballast to the motor box to get the CG forward enough. It flew much better after that. I'm off tomorrow morning for more flights so I can trim this baby out perfectly. It sure is a good looking plane.
Quite floaty for my short little "runway" at the park where I fly, so I'm gonna have to practice those super-slow harrier landings
How are you enjoying flying that West Tigers Mango beauty?
bring the thunda is offline Find More Posts by bring the thunda
Old Nov 09, 2011, 04:30 AM
Joined Nov 2006
Yep I love it. For its size I'm still amazed how well it flys IMAC or pattern type sequences. It really holds super straight lines and has no hint of stalling and I think it looks and flys like a much bigger plane when doing this kind of flying. I'm happy to fly whole batteries just doing big smooth flying.
Then it becomes a 3d animal. Easy as harriers and hovers, rollers as well. Currently playing around with death slides from about 100ft down to under 10ft the rudder and power giving complete confidence to do it. Oh and my fave with it at the minute is a full power wall, zero the power then as it stops slam power back on and push over the top straight into a rolling harrier. It does this move tighter than any other plane I have seen.
Did I mention I love it!?
Old Nov 09, 2011, 08:25 AM
Real Men Fly Pink Planes...
kepople's Avatar
United States, TX, Rockwall
Joined Jun 2001
Mines ready to go. So how are you guys finding the 12 degree low rates?
it sure seems like a lot of difference. I fly a mix of 3d and precision so I wonder if 12 degrees on aileron is enough roll rate?
kepople is offline Find More Posts by kepople
Old Nov 09, 2011, 09:01 AM
aerofundan's Avatar
Panama
Joined Jul 2005
10-12 degrees is perfect for the elevator low rate. For ailerons low rate it really depends on what you like, if you like faster snap rolls, i would suggest you go to about 20 - 25 degrees of aileron throw or adjust to where you like it. Then for high rates, definately go for as much throw as you can on everything!
aerofundan is offline Find More Posts by aerofundan
Site Sponsor
Old Nov 09, 2011, 10:38 AM
Joined Nov 2011
Are any of PA's electric aircrafts suitable for a beginner flyer with a little skill on RC helis?
adrictan is offline Find More Posts by adrictan
Old Nov 09, 2011, 10:54 AM
3D flying at 120%
United States, TN, Sharps Chapel
Joined Apr 2011
Probably the Electric Shock, set up for low rates (dual rates) would be an inexpensive starter plane if you're trying to avoid the super light weight foamies. And getting a lot of training flight time on a good SIM will help a bunch too.
-Byron
3DeltaFly is offline Find More Posts by 3DeltaFly
Old Nov 09, 2011, 11:55 AM
Precision Aerob's Avatar
Sydney Australia
Joined Jun 2004
Hi Mr K,
The dead weight is not needed
Here is the thing with the Bandit,
Unlike other planes the Bandit is VERY neutral plane and will fly wherever you point its nose. It takes a bit of time to get use to it but it doesn’t hurt its precision ability. It is a very precise plane but the concept of flying the Bandit with a "nose heavy" feel is not applicable.
Ask Aerofan Dan he will tell you! He didn’t want to take my advice (when flying the pre-production plane at SEFF and Joe Nall) blaming the tail servos and CG but after getting use to the plane his battery is exactly where it should have been from the first place and he is happy with the CG . Just a matter of getting to know the Bandit better.
One thing to confirm is that the elevator linkage is not binding (activate it manually after detaching the servo arm) and then check the centering of the servo. Obviously if the servo is not centering well it will contribute to trimming changes.
Also verify that the ailerons are in neutral position (no Flaperons or Spoilerons in neutral position).
Lastly check that the motor sit flush with the firewall and there is no undesired "down/up thrust" angle. Make sure there is no epoxy on the firewall where the motor sits. Also make sure that the balsa triangles (behind the firewall) are trimmed so they don’t obstruct the motor from sitting flush with the firewall).
Lastly, trim the plane in a very calm day and not gusty as it will certainly confuse you.
Shaun
Precision Aerobatics Team
Precision Aerob is offline Find More Posts by Precision Aerob
Site Sponsor
Old Nov 09, 2011, 12:11 PM
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Hi Mr K,
57 grams of noseweight?Sounds like something is amiss.By all means if you like the plane with that much wieght in the front thats how you should enjoy it.But,it has to have something going on wih how the motor is mounted,or maybe not enough expo or maybe too much expo in the elevator?dunno but usu if using the manufacturer recommended setups you dont add static weight to their planes.I have seen those servos not center well.(sorry pa) but it happens with any servo.also motor thrust angle if it is not correct can cause weird issues.
Manta1 is offline Find More Posts by Manta1
Latest blog entry: Lil repair work.
Old Nov 09, 2011, 12:23 PM
www.3dextratime.be
3d extra time's Avatar
Belgium, Vlaams Gewest, Dessel
Joined Oct 2011
very true Shaun,
It is a pitty to add extra weight to get the right CG. PA did a great job by creating such a well balanced airframe.
This plane is absolutely neutral. We fly this plane even on 3 as on 4s with a different weight of battery and in both of the cases, it flies very neutral.
It is better to place the esc as far as possible in the nose (just like the manuel says) and make the batterywires a bit longer.
3d extra time is offline Find More Posts by 3d extra time
Old Nov 09, 2011, 02:59 PM
What will happen if ....Oh....
OSOFAM's Avatar
Australia, VIC, Sale
Joined Oct 2007
-Byron
Hey adrictan, how much skill do you have on the heli? If your ok with nose in hover, figure 8's and circuits, I would recommend the Addiction or AddictionX over the Electric shock.
The electric shock is very responsive, and it is small so is best suited to close range flying. Also the landing gear is not really suited to grass landings.
Loving the photos and maiden stories fellas!
OSOFAM is offline Find More Posts by OSOFAM
Old Nov 09, 2011, 07:14 PM
Joined Dec 2010
Hey guys,
Thanks for all the helpful advice. It flew better today with slightly more nose weight.
I'll strip it down and change some servos around and double check the fit against the firewall of the motor as well as checking the elevator moves freely when disconnected.
I may also move the Rx to just behind the lipo on the tray. If it flies nose heavy sports style, I'll start reducing nose ballast and hopefully be able to get rid of it all.
Thanks again guys for the advice
Old Nov 09, 2011, 09:10 PM
Australia, WA, Perth
Joined Sep 2011
Hi Adrictan,
I also had some experiance with RC helis and flew a high wing trainer about 10 times before i recently moved to the bandit. I started off with a tamer 13x5 prop and found it to be a great beginer plane. As long as you have some experiance with your orientation it really isnt much harder to fly on low rates than a trainer and its a great versatile plane that can grow with you.
Marcel
roooost is offline Find More Posts by roooost
Old Nov 10, 2011, 09:22 AM
Joined Nov 2011
Thanks guys for the reply so far.
I've not started long in heli and am currently flying a Mini Titan E325. Over the course of a month plus, I'm comfortable in hovering at any time with zero crash since starting. Am currently learning to fly it from left to right & vice versa.
I was looking at the Kyosho Redbull series until I saw the Bandit. The Kyosho is available in Singapore but I suppose the only way to get the Bandit is to order thru U.S or Australia.
Any more thoughts & comments?
New Product Precision Aerobatics Addiction X Official thread / Video just posted!!! aerofundan 3D Flying 3659 Yesterday 03:27 PM
Discussion Anyone else wish Precision Aerobatics would make a larger electric 3D monoplane! Neil_SC 3D Flying 18 Apr 17, 2011 06:04 PM
Wanted Precision Aerobatics Katana MD or Precision Aerobatics Mini Katana mixer911 Aircraft - Electric - Airplanes (FS/W) 5 Jul 16, 2009 12:52 PM
Found 3d hobbyshop/precision aerobatics/greatplanes**3d yak/suk/katana/edge/extra helifryer Aircraft - Electric - Airplanes (FS/W) 10 May 20, 2009 09:13 PM
Discussion Precision Aerobatics How To Series, 3D Aerobatics & Repair Guide aerofundan 3D Flying 22 Jan 03, 2009 09:52 AM
